Question about Home
Screechy shower curtain
We have a new shower curtain rod, metal as opposed to our previous plastic rod. The decorative curtain holders are metal and the screech when the curtain is moved is unnerving. We've tried oils, wax and soap with no luck. Any ideas?
  • Frank
    Frank May 11, 2010
    inspect the rod and the cutain ring. make sure there are smooth as possible where they touch. the noise is where the un-evenness on the rod or on the ring.
    Problem Solver:
  • 12 Answers
They do make chrome plated, plastic curtain rings.
Posted on May 01, 2009
TENSION SHOWER CURTAIN ROD INSTALLATION
Extend the rod until it reaches both sides. Hold one side of the rod while turning the other end until it expands and has tension. Good luck!
Oct 30, 2016 | Home
I need a shower curtain rod that won't rust/corrode
For rods that won't rust you might need a rod made of stainless steel or even nylon. This site sells these type of shower rods:
http://www.showerrods.com/
Nov 30, 2012 | Home
The pipe that has shower head does not fit tightly into the facuet; I am installing a new facut with a hand shower and a shower head system
Try screwing it in opposite of normal threading. Left to tight not right to tight. Usually with anything liquid especially water connections threading is opposite.
Mar 05, 2011 | Franklin Decor Bathware Shower Rod
I PUT UP A CURVED CURTAIN ROD. IT KEEP CUMMING OFF THE WALL
These rods need a little more support than a standard rod because of their shape. I'm assuming you used a plastic wall anchor in the gyproc or plaster. If so get rid of it and use a butterfly style anchor. The butterfly provides superior support and will allow to tighten the screws more tightly than with the plastic wall anchor. Good luck with your project and let me know if I can be of any further help.
Jul 30, 2010 | Rocky Mountain Hardware Shower Curtain Rod...
Adjustable (tension) shower curtain rod too long
Yes you can ! You only have to pull off the rubber end cap and cut it , file off ant burrs. Cut the SMALLER diameter end only, the other end contains the spring !
Nov 16, 2009 | Rocky Mountain Hardware Shower Curtain Rod...
what I would try is putting a strip of glue from a glue gun. It is barely noticeable. But us enough to stick.
Apr 12, 2009 | Watts 0392262 FS-CWM-S-HH 3/4" x 3/4" x...
How do i install an arc shower curtain rod
you cant you need studs.get the spring loaded rod.
Apr 04, 2009 | Home
Polder Duo Shower Curtain Rod Instructions
Cindy,
This might help you out.
http://common.csnstores.com/common/marketing/uz1194manual.pdf
Feragola
Nov 22, 2008 | Home
How to Install Shower Curtain
If you are going to use both a shower curtain and a shower liner, you have two options for installation. You can either use one rod and one set of rings, or you can use two rods and two sets of rings. If you used one rod, line up the liner and the curtain so they are facing one another and thread one ring through each of the corresponding grommets on the both the liner and the curtain. The curtain liner will move as one unit. If you use two rods, you need one set of rings for each, and the liner and the curtain will move independently.
Aug 27, 2008 | Moen Sienna Towel Bars Black Bathroom...
Home Logo
288 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
