SOURCE: Need to know the gap for my ignition module on my
Your ignition should be gapped a .010 to .012. thank You
SOURCE: BROKEN BRAKE PAD UNDER FLYWHEEL ON TORO LAWN MOWER
If you had replaced the flywheel key & did not engage the saftey bail it would brake the brake. Make sure the bail is engaged befor installing the flywheel.
SOURCE: Electric Starting Difficulty on Toro mower with Tecumseh engine
it sounds like to me that the starter pully is getting caught up on the worm gear ,this could be because of dirt or grass getting in the way make sure that no grass or dirt is around the worm gear
SOURCE: how to set timing on a push mower with a tecumseh
if it is an older machine, yes, the points are underneath the flywheel---it can be removed without a puller---just a little patience will get it off
