Question about Nokia 9300 Smartphone
I have Nokia 9300 and even when it's closed "phone" outside when I try to type says: "PLEASE CLOSE COVER"....
Posted on Jun 16, 2010
  • Joseph Trek Oct 03, 2010
    Problem is in phone board and cannot be repaired, i recommend to replace mainboard or try nokia service to make software override.
My nokia 9300 showing message close cover on the screen
So, your phone is telling you what to do, and you don't believe it? I'm going to take a guess here....try closing the cover.
Hope this helps.Randy
Aug 31, 2012 | Nokia N71 Cellular Phone
I have a nokia 9300 mobile now i m having a problem in my cell problem is when used front display it get pleas close cover tell me answer quickly
Hello Abhay,
There is no problem in your phone.
You can not view both the display at time.
This feature is not provided in phone by the Nokia.
So you have to access one display at a time.
Mar 19, 2011 | Nokia 9300 Handheld
How to format my nokia 9300i
This process erases from your Nokia 9300 all of your user data and settings, including your phone book, calendar, email, downloads, recordings, and certain factory installed programs such as Instant Messaging and BlackBerry Connect.
REMEMBER: Create a device data backup or synchronization before formatting.
You can restore device data and settings later. See the Nokia 9300 User Guide for further instructions.
STEP 1 - Format the Nokia 9300 memory
* Remove the battery for 10 seconds
* Replace the battery
* Open the Nokia 9300 to view the inside display
* When you see the screen with "NOKIA" in blue text,
* Press and hold the following four keys until a Format Message is displayed:
CRTL + Shift + F
* Confirm the process by selecting Format
* Formatting will begin
* After formatting is complete the Nokia 9300 will reboot with some basic settings. If prompted, accept the request to reboot
* Follow the instructions on your Nokia 9300 to set the time, date and city and to enter your contact information.
STEP 2 - Download the install-cingular-default-603.SIS to a compatible PC.
STEP 3 - Prepare a Multimedia Memory Card (MMC)1
* Transfer the .sis file from your PC to your device using MMC, data cable, Bluetooth or infrared. For instructions see the Nokia 9300 User Guide.
STEP 4 - Install the file install-cingular-default-603.SIS to your Nokia 93002
Note: This step is required to install Cingular specific settings and programs to your Nokia 9300.
* Insert the Multimeda Memory Card created in Step 2 to your Nokia 9300.
* Replace the battery cover (so the Nokia 9300 can read the MMC)
* Open your device, then open the File Manager:
Press the Desk application key
Scroll to and select Office
Scroll to and open File Manager
* Using the arrow keys, scroll to Memory Card
* Highlight the file install-cingular-default-603.SIS
* Press Open to start the installation process
* Follow and accept all prompts and requests
* Reformatting is now complete
(1) You may choose to install the file above using Nokia PC Suite. Please see the Nokia 9300 User Guide for general instructions to install software using Nokia PC Suite, and follow those instructions instead of Step 4 above.
(2) CAUTION: The .sis file above is ONLY intended for use with a Nokia 9300 with the appropriate software version. DO NOT install this file to a Nokia 9300 with any other software version. DO NOT install this file to any other model device.
Oct 14, 2010 | Nokia 9300i Cellular Phone
Nokia 9500 communicator - get message please close cover
my nokia 9500 communicator says close cover when the cover is already closed what should i do?
Jun 08, 2010 | Nokia 6030 Cellular Phone
Phone works fine if you use keyboard on outside of case. When you open phone, LCD screen displays whitescreen permanently across entire LCD.
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-5 or 6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Jan 08, 2010 | Nokia 9300 Smartphone
Sir, My mobile is Nokia 6500 model. In contact settings,at first it was set as contacts>>settings>>"memory in use"-PHONE AND SIM. By mistake I have changed the option of "memory in use" to...
usually the phone memory security code for nokia mobiles will be 12345, until it is changed manually. try this code... else, u have to consult the service provider i guess.
memory card not detecting....
First you open gallery on screen. If the memory card ok the first item will be the name of your Card. If it is not found that means the card not detecting. You may do this.:
Open Gallery, then press the back ( battery cover ) of the phone and hold for one second, now see the screen, you can see the card name on first line. But when you take your hand back form the battery cover the display revert to the same as before.
The point of pressing:- near to the lense ( Just right side of the lense) . You know why ?. The memory card is located inside of that place.
This means there is a switch (Battery cover open / close) located just left side of the memory card, and there is a TIP projected in the same place at the Battery cover. When we close the back cover the switch become ON. Here is the problem.....!. The switch will not contact even you close the cover. When you press the cover hardly the switch become contact. when you remove the hand again it become open.
More clarification:-
In a new phone if you open the battery cover the memory card will not work at all. It will detect only after closing the cover.
this may help you.
Jan 08, 2010 | Nokia 6500 Slide Cellular Phone
Hi i have nokia 9300, but a few days ago cannot send the sms they said system not enough memory. Close some applications and try again. But still cannot i deleted all the inbox, sent and everything but...
ALL YOU HAV TO IS TO FORMAT YOUR NOKIA 9300 USING KEY CTRL+SHIFT+F, YOU MUST TYPE THIS KEY WHEN YOU PHONE STILL APPEARING THE WORD NOKIA ON BOOTING SCREEN DONT WAIT TO SEE THE HANDS IF SO U R LATE
Dec 20, 2008 | Nokia 9300 Handheld
How to restart nokia 9300
No direct restart method is provided by the manufacturer.
The best method for restart is to switch off the telephone(Cover)
then remove the battery and re insert it as quickly as you can to prevent the time to get resetted.
If the phone is not started automatically, press the switch-on key on the cover and wait for it to start.
you can also install applications like appman to be able to restart the phone by the press of a button.
Please rate.
Oct 22, 2008 | Nokia 9300 Smartphone
Front Panel not working
there is one magnet placed in the cover when u rmove the front portion the magnet will fall off without your knowledge so plz close cover will be displayed put new magnet it will be allright
Jul 29, 2008 | Nokia 9500 Communicator
Nokia 9500
hi there is a magnet in the cover if that is missing it says plz close cover. you need to replace a magnet
Jan 24, 2008 | Nokia 9500 Communicator
Nokia 9300 Smartphone Logo
324 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
