Question about Dell PowerEdge 1600SC Server
Dell PowerEdege 1600SC not recognizing IO devices
I have a Dell PowerEdge 1600SC device that was turned on. I needed to leave without waiting for it to power down, so I pressed and held the Power button until it shutdown. :-(
Now, when I turn it on, it does not recognize any of the I/O devices (i.e. monitor, keyboard, or mouse). The monitor, keyboard, and mouse were directly connected to the Belkin Omni Cube 2-port device, which in turn was connected to the server at the time that I shut the server down.
To eliminate the possibility that the Omni Cube device was the problem, I connected the monitor, keyboard, and mouse directly to the PowerEdge 1600SC server. However, again, the server didn't recognize any of those input/output devices.
I then disconnected the monitor from the PowerEdge and attached it directly to my laptop to make sure that the monitor is working. The monitor is working as I was able to use Fn + F7 on my laptop to display contents from my laptop onto the external monitor.
My Dell PowerEdge 1600SC has the software for my Linksys Wireless-G 2.4 GHz Broadband Router and my internet connection installed and I am able to still access the internet. Therefore, I know that the PowerEdge server is still functioning....BUT it won't recognize the I/O devices.
What can I do to force it to recognize the monitor, keyboard, and mouse...as it previously did?
Any help or insight would be GREATLY appeciated...and thank you!
  • ccunni2189 Apr 13, 2009
    I cannot do that as the server is not recognizing any of the I/O devices...i.e. monitor, keyboard, or mouse. As such, nothing appears on the monitor at all...as if the server is not sending any signals to the monitor. Pressing F1 on the keyboard doesn't help as the server is not recognizing the keyboard.
    Is there any way of overcoming this?
    Again, any help would be GREATLY appreciated...thanks.
  • 679 Answers
Just go into the bios and insert the correct parameters. you shut it off before it could save the settings. Or hit fi on boot and it should take you into the bios and you cand sort it out in there. If you want an easy way, just do a system restore. Start,Programs, accesorys, system tools, system restore, just go back a day or two before you had that issue, and you should be good to go, good luck
Posted on Apr 12, 2009
  • 1 more comment
  • George Bill
    George Bill Apr 13, 2009
    The bios screen is before windows boots, as soon as you hit the restart button u have to hit the delete key, tht's how you get into the bios screen, you use the arrow keys esc, and enter keys to manuver , this is where you can set your default parameters. Forget the windows screen this is the bios screen that controls your settings, somehow from playing around you messed with your system settings. In the bios you will be able to turn on you usb ports which will give you back the control of the keyboard and mouse. Unless you somehow messed up the bios, but in order to do that you would have had to have tried to reflash them You will also need to shut down and unplug first. then remove the motherboard battery for 5 minutes,not the laptop battery the motherboard, you will need to open the bottom of the laptop, but try to get into the bios first. Remember as soon as you restsrt you hit the delete key you will go right into a bios setup screen. We do this all day that's what you have to do.
  • George Bill
    George Bill Apr 14, 2009
    You have to follow the instructions or take it to a tech, it sounds like you just aren't up to doing it, that's ok you are only going to make it worse, my advice is if you feel you cannot understand this stuff just take it to a local repair store, your probablly looking at $250-$350
  • George Bill
    What you describe can only be fixed if your machine can be diagnosed by a tech, as there are too many things it could be to keep going back and forth like this. Normally if you cannot get in the bios your machine is not going to be able to fixed like this, there are too many variables. Did you clear the settings in the cmos?, take out the motherboard battery wait a few minuter and replace, that will get rid of any bad settings on startup, then try getting in the bios again
Scsi controller devices
Yes Doug. What is your problem with your Scsi controller device?
Feb 01, 2014 | Dell PowerEdge 1600SC Server
Dvd player doesnt recognize dvdin my dell poweredge 1300 computer
the dvd may be damage or bad or the dvd player is bad or damage
Apr 24, 2010 | Dell PowerEdge 1600SC Server
PowerEdge 1600SC long beep and hang
check the Cmos battery. or levae pluged in over night and then check setup setting you battery went dead
Oct 12, 2009 | Dell PowerEdge 1600SC Server
How to open front panel of Dell Poweredge 1600Sc without key
The lock on the Powerledge is not too difficult to pick. A home made pick or buy a small lock picking tool set (less than $20). Without any training you can pick it in five minutes.
Jun 04, 2009 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600sc server is running
What operating system is the server using? What roles is the server doing (DNS/DHCP/DC/Exchange/etc). If it's a Windows 2003 SBS box, you're supposed to be able to run upto about 75 users. I would never run more than 30 users on an SBS box (and it'd have to be a very high spec). You may consdier bringing another server to do an aditional role (file/print) and leave the primary to be an SBS box
Oct 10, 2008 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server problem
I had the same thing happen in a 600SC about a month ago.
Replaced the memory, and it fixed the problem.
It did the same hang. Would run fine for any where from a hour to 3 hours, and then quit (hang). And I got the same message. Talk to them and it was a short in the memory module, so some times it would read the entire stick, other times it would "not see it", and that would lock the OS.
Sep 03, 2008 | Dell PowerEdge 1600SC Server
1600sc second CPU
Hi
Yes, some systems (newer PowerEdge Servers, generally 6/7th Generation and above) have onboard VRMs.
1600sc is a 6th gen PowerEdge (with Simple Computing). I can checked and be absolute certain from within Dell. I'm on VAC until Saturday.
In the meantime, check the PRC model and revision and ensure that they match. Given that a single PRC POST/Boots, try upgrading (if not already) the system BIOS to latest revision.
If the PRC model/revision does match and you have the latest BIOS version, also if the VRMs are not needed, then from the Troubleshooting you have already done, we may conclude that the PRC 2 slot is faulty.
I will confirm the VRM query on Saturday.
PowerEdge 1600SC, BIOS A12 Update Package for Microsoft Windows - http://ftp.us.dell.com/bios/PE1600SC-BIOS-WIN-A12.exe
PowerEdge 1600SC, BIOS A12 Floppy Update Package - http://ftp.us.dell.com/bios/PE1600SC-BIOSA12.exe
Mike
May 14, 2008 | Dell PowerEdge 1600SC Server
No Video Signal on 1600sc
Disconnect from the network and all other accessories, and power up the system, this might be due to a faulty device attached to the system, eg: when you connect a usb faulty device the boot takes very long time, sometime it does not boot up.
Dec 30, 2007 | Dell PowerEdge 1600SC Server
Can not access bois
It hangs there probably becuase one or more of the drives are dead or are almost there. Check and see the lights on the drives are falshing funny or too long or are yellow. If you find one of them that are that way, pull it out and then reboot.
See if that helps.
Nov 07, 2007 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server Logo
401 people viewed this question
Alun Cox
