Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
No sound I have installed AC 97 audio drive in my pc and it also accepts the drive, and if i play a song in winamp the song is played, but I cant hear the sound 1 I already un-checked the mute option 2 I have connected speakers to the system that has been checked in another system also. plz help
    President:
  • 2,961 Answers
Click start>run then type dxdiag, press enter then go to sound tab and click test. If no driver problem shows then you have a sound chip fault.
Posted on Sep 11, 2007
SOURCE:
CD drive is not working correctly
Hello try to download the manual from here:
http://www.asus.com/Motherboards/AMD_Socket_939/A8NSLI_Deluxe/#download
Please select your windows system.
Open the manual folder, and click on global for download.
You will need adobe reader, to read the content.
Check the bios settings for the audio, try to change the setting to
ac 97, instead of hd audio.
Try also to select the setting plug and play os. to yes.
Remember to save your work when leaving the bios.
Why are you useing both a cd and dvd drive ???
A dvd drive does also plays cd`s.
Are you useing sata or ide connection ??
If so the ide cable could be failing.
Update any drivers, if some missing.
Good luck
Jan 06, 2013 | ASUSTeK COMPUTER A8n-sli Deluxe Socket 939...
I cant hear the music from gom player
In an earlier post I mentioned I was switching my PC music players from Winamp to GOM player. Well, GOM player is not far enough along in its development for me to use it on a daily basis.
I have 3 issues with GOM player today: a bug in mp3 decoding, and a bug in sound-driver-playing, and buffering.
Some of my music (actually, a large portion of it) plays fine in Winamp, but flickers badly in GOM player. What I mean is, a little chunk of audio is skipped (like 1/10th of a second's worth), so the song "speeds up" by 1/10th of a second, which sounds horrible to the ear; it messes up the beat of the music, especially if you're trying to sing to it or follow it in your mind while listening to it.
I know there's a ton of different mp3 encoders that can generate mp3 files in a wide variety of ways, including CBR versus VBR differences; Winamp just seems to handle them all perfectly, today.
There's some bug in how GOM player talks to my sound driver, in a way I've never seen before. Let's say I load up an m3u file (which is a list of many mp3 songs to play, in the order to play them). GOM player plays the first song. Then, it switches to the second song, and begins "playing" it - except no sound is coming out of my speakers! I can see the little thumb/bar moving horizontally, showing that the music is "playing" from GOM's point of view, but I can't hear a thing.
If I grab the little thumb and drag it ANYWHERE (including right to the spot it was just at), the sound immediately resumes playing through the speakers! So, I have to baby-sit every song - grabbing the thumb and dragging it back to the beginning OF EVERY SONG, to get that next song to play. Frustrating.
The last issue is that GOM player isn't buffering up enough decoded music ahead of the play-point. I know this because when I start launching apps and opening windows, even IE windows, the music cuts out for fractions of a second, then resumes. The music gets choppy like that, over and over, until the CPU is back to "idle", then the music plays continuously again. Winamp never did that. I assume it's a buffering issue; perhaps Winamp is multithreaded, with one thread doing playback, and another doing decoding; the decoder must run fast enough to be ahead of the playback by a wide margin, for times when CPU becomes scarce. Then the playback can read its data from the buffered-up audio, play it, and not hiccup.
Really intelligent software will even do internal "low-water-mark" measurements to see how well the buffer size is working; if it ever runs out of buffer entirely between decoding and playback, it tweaks an internal setting so it remembers to keep a larger buffer next time! That way it can prevent hiccups in the future by learning about how this particular machine works.
Yes, I'm running this on a machine with not quite enough memory (512MB Windows XP; it's the max this poor box can have). But if Winamp can do it, I would like to think GOM player can, with the proper programming.
So, I guess I don't have a good music player after all.
Yes I've tried VLC media player, which is awesome for movies, but has a sucky user interface in my opinion. You can't display a playlist of upcoming songs you've queued up, such as when you open a m3u file which VLC player does understand just fine.
I'm going to look around some more.
Mar 01, 2010 | Gomadic (BCK-0477-AG) for iriver H10 (5...
My winamp doesnt produce any sound it will just play
..check whether your sound is muted?
..sometimes your winamp sound files are missing better re install winamp
Jul 14, 2009 | Microsoft Windows XP Professional With...
Problem while playing songs on laptop
your sound card driver is need to re-install or uninstall the old driver then make a new install the sound card driver or try to re-install and update the laptop drivers...thanks...
Apr 25, 2009 | Compaq Presario Notebook
No hear the sound in ACER 4520
First you just play the songs in VLC player.If sounds comes then ok,otherwise cheack below that i have written......
I think either the (XP)sound drivers doesn't match or the problem in your sound device. So it's better to go to the nearest service station and cheak your laptop. If it is OK then, search for proper sound drivers from them or in google.
Mar 14, 2009 | Acer Aspire 4520-5582 Notebook
No sound device installed
Plz check the sound drivers.Reinstall it and install according to your motherboard.
Jul 27, 2008 | Microsoft Office Outlook 2003 for PC
Sound problem
if ur usung win xp OS U shold restore OS (pgm-accessories-system tool.restore )to back date while it in workinfg fine
Jul 19, 2008 | Edirol UA-4FX External Sound System
Removing songs from Ipod Nano using Winamp
Seems the playlist detais arent geting removed, only the songs.
So basicly you need to remove the deleted songs from the playlists ? you could probably do it on the ipod screen manually.
if my solution fixed your problem please give me a fixya rateing, becouse im trying to reach the guru status and its up to the voters(you) If I get there or not. I have over 700 solutions here and most of them are unrated!
So thanks alot for rateing!
Apr 03, 2008 | Apple iPod nano
Bad direct drivers.
Dear sir,
I ahve problem like My laptop is C700 series of compaq(C772TU) I ahve changed it OS from vista to XP and now there is no audio output whenever I try to play a song it gives msg like " Please installproper device or select another device in configuration Error code: 88780078"
please suggest me proper solution
Mar 22, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
85 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
