Question about Campbell Hausfeld PW2102 Gas Pressure Washer
Does anyone know what the spark plug gap setting should be for a campbell hausfeld model pw1755v3le pressure washer should be?
  • 154 Answers
Most gas engines will work fine at .030 to .035 sparkplug gap
Posted on Apr 16, 2009
How to hook up a pressure washer by Campbell hausfeld
Hook up the water hose and plug it in I assume it is electric.
Oct 11, 2016 | Campbell Hausfeld Garden
Campbell Hausfeld 2200 psi pressure washer doesn't build up pressure
2 possibilities. It is not getting enough water from the hose or your pressure regulator is bad. Does it sound like the engine is developing full RPM? Could be and engine problem if not coming up to full speed.
May 04, 2015 | Campbell Hausfeld Garden
Motor quits when pull trigger
It's the spark plug more than likely. If engine turns but won't stay running its more than likely spark plug. If that doesn't fix its the gas. Empty gas out get some fresh gas.
Jul 13, 2013 | Campbell Hausfeld PW2102 Gas Pressure...
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
Where to find replacement carbon brushes Campbell Hausfeld pressure washer pw1350
Parts for Campbell Hausfeld can be found at www.chpower.com. Campbell Hausfeld does not however, sell motor parts for many of their tools. You would have to call their 800 number and speak with a parts person to determine availability. You may be able to purchase a close match at a local True Value hardware store. They sell a variety of brushes for many major brands of tools. Purchase a slightly larger set of brushes and sand them to size. If the connector is different, cut off the old connector and solder it to the new brush.
Dec 15, 2011 | Campbell Hausfeld Garden
Gun
Replace the wand (Gun) The valve is not repairable.
Jun 16, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
Pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
the unloader valve is deffective , this has a small metal rod which activates a microswitch to turn the machine off , replace the unloader valve
Nov 18, 2009 | Campbell Hausfeld 1,350 Psi Electric...
I have a campbell hausfeld pressure washer without a manual. The model is PW1755V3LE. I want to know exactly where the port is for using chlorine or detergent. I'm not sure I see one. Can you help me?
You won't see one. You can not pump chlorine or detergent through the pump. What you can do is get an injector kit which will siphon solution into the discharge from the pump. The problem is that it will be at low pressure. When you are applying a solution, it is done at low pressure to do a wet down. You allow that to work for a few minutes then you pressure wash after the solution has done its job. If you try to apply the solution at high pressure you will only waste your product as it will have no benefit being in contact with the surface but for a few hundredths of a second. There are pumps that will apply chemicals under pressure such as a golf course might use to spray fertilizer on the greens. These type pumps are pressure sprayers and you mix your chemicals in a tank and the pump pulls the solution from the tank, These pumps are made of chemical resistant materials and are fairly expensive. They however are not pressure washer type pumps.
Sep 20, 2009 | Garden
Campbell Hausfeld PW2102 Gas Pressure Washer Logo
360 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
