My York AC unit is making a humming noise, but will not enguage the motor. The motor is new. The indicator light flashes 6 times. Can some one help???
  • 374 Answers
this is the signed of the compressor motor can't start,the running is functioning there is no starter to torque to run the winding,either the starting capacitor is not functioning or no supply source on starting line.this shuold be done by certified a/c tech.if you fix your self there a lot of tools to provide and knowledge of using this,since the motor is new,there should be warranty on this you can claim on this to minimize the repair cost claim it to your service center,have a nice day dont you forget to rate me,thank's
Posted on Apr 12, 2009
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
Indesit dif 04 wont work it just make a humming noise and wont empty
Hello
Unplug the device from AC power outlet, and replug it after five minutes. If the problem perists, the motor of the unit is faulty, and should be replaced.
Feb 01, 2012 | Indesit Washing Machines
Made pop noises screen flashed considerable hum then no power no sound no nothing
This model no. is known for AC power adapter problem. Pop noises, flashes of the screen is an indication of out-of-regulation condition on its power supply. If there's no LED light lit, then high chance that the fault came from the AC power adapter.
This model no. used AC power adapter with a 12 Volts output feed to the unit. You have to confirm the 12V output using the multimeter set in DC measurement.
If the 12V output voltage is not present, then you have to replaced it with new one. This model no. is already discontinued, only substitution is available online which will work also for your unit. You may inquire/call Sears hotline no. (1-888-213-5824) to confirm and order the AC Adapter.
Please let me know if the Adapter is intact to assist you further.
Please rate only if you feel I've gave you the best answer. If you have any question, please let me know.
Have a nice day!
Jdvillanueva
Oct 30, 2011 | Proscan 19LA25Q 19 in. LCD Television
I just had a new Dometic roof air conditioner installed it works good for about 10 min. the the fan stops and makes a humming noise .After about 10 min the air will work ok again. The repair tech saya the...
I have over 35 years in the A/C business and am ASC certified. The motor will normally draw 4 to 6 times it FLA (Full Load Amps) or RLA (Regular Load Amps) when first starting up or is seized. This is called LRA (Locked Rotor Amps). These specs can be found on the motors nameplate and can be checked with an amp meter. If the motor hums and won't start while pulling these high amps, Try giving it a spin with a stick. (in the right direction of course). If it keeps running when helped to start, its probably the capacitor. They normally run about $7.50 wholesale. If its tight in both directions while humming, 1 or more of the field poles is out of balance and the motor will need replacement. Good luck and be careful when spinning it.
Mar 31, 2011 | Dometic Rooftop RV Air Conditioner
I have a howling noise when the A\C is turned on ?
just take the fan motor off and run it over to your local electric motor shop for a exact replacement and yes replace the capacitor with one that matches your new motor. The bearings are dry on this one, it sounds like you caught it just in time Good Work Soldier. Those york guys do not make any money sitting around answering questions over the phone that knocks them out of a service call charge. ITS JUST buisnnessLOL. You might want to go ahead and do your condensor coil cleaning while the motor is out of the way, if you have not done that in a while, do you have some coil cleaner? If you let those York guys come out they can probably spot some other areas that need attention also. Hey its like my old Boss told me back years ago "Son its only Money" I have found that it is a lot easier to spend other peoples money for some reason hmmmm
Sep 22, 2009 | Heating & Cooling
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
Motor noise and flashing light
The problem you may be having is an ice build up. Defrost the unit and take out the back wall of the freezer. Cut the insulation off as in the picture and it will solve the problem. What happens is a little bit of water gets trapped and then over time it becomes a massive ice ball that can block the fan. First you hear the ticking noise and then you get ER FF error.
Sgt 48
May 16, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Candy Fridge freezer
How old is ur unit? Often the motor mount you need to check that rubber make sure its not broken (bushing)or the motor directly touch the rest of the panel below. Or else you need a new motor to eliminate that noise. Good luck Hope this help!
Aug 06, 2007 | KitchenAid KTRS22EM Top Freezer...
Humming noise
humming is the motor powered up but not turning. burning smell is the motor overheating. cause may be the motor capacitor which is a cheap part. try replecing it and hope thge motor survived. could also be a foreign object in the pump impellor
Mar 13, 2007 | Zanussi 24 in. DE6744 Free-Standing...
Heating & Cooling Logo
683 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
