THERE IS A CLEAR HOSE THAT CAME OFF AT ONE END DURING A SPIN CYCLE. I NEED A DIAGRAM SHOWING WHERE IT HOOKS.
  • Washing Mach... Master
  • 3,361 Answers
Model number please.
The clear hose goes to the water level switch in the control console and to the air dome on the side of the wash tub.
If you run the machine without replacing it correctly you will flood your laundry room.
Posted on Apr 12, 2009
Washer does not completely spin out the water on the spin cycle.
Output hose might be plugged, water can't get pumped out if end of hose or internal in hose has crud in it. Does water pour out during spin or just trickle, if trickle it has a plugged section.
Feb 15, 2015 | Kenmore Washing Machines
Tip
Washing machine showing F4 on display.
<span>Hi.<br /><br />This tip applies to Whirlpool built washer, including Kenmore and other brands.<br /><br />F4 means that the problem is caused by a defective pressure switch. The problem is often coming with troubles in the spin part of the cycle.<br /><br />The following is an extract from the washer service manual:<br /><br />"F4" flashes and the cycle signal beeps when the recirculate pressure<br />switch is not working properly during the Catalyst, W ash or Soak cycle.<br />If "F4" is flashing, check the following:<br />- Plugged recirculate hose (black hose).<br />- Plugged or disconnected air tube (clear tube).<br />- Wires to the recirculate pressure switch disconnected or not<br />connected correctly.<br />- Failed recirculate pressure switch. Switch (black wire, tan wire)<br />contacts should be open with pressure applied and closed with<br />no pressure.<br /><br /><br />Try disconnecting power by tripping the circuit breaker or disconnecting power cord for five minutes. If that does not clear the error check the thin clear rubber hose connected to the pressure switch and extending into the tub. Try blowing into pressure hose and clean it. If that does not fix the problem replace the pressure switch.<br /><br /><a href="http://www.searspartsdirect.com/partsdirect/index.action">To locate parts and diagrams, please enter the full model number, as witten in service tag, in this website.</a><br /><br />Regards.<br /><br />Ginko.</span>
on Jan 13, 2011 | Washing Machines
Suds and then f35 error code shortly afterbstarting any wash cycle.
SUDS error = SUDS LOCK (OVERDOSE OF DETERGENT
DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained
and it will try to spin or drain again.
If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
F35 error = ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Dec 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water is in the drum after a complete washing cycle, you can't see the water but you can here it slushing around and leaves a foul order when not used for several days.
Make sure that the outlet hose is not blocked and the filter is clear.
If this is OK then the following from Maytag may be helpful. If not call a repair man for service.
Is the Delicate or Hand Wash cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such as the Delicate or Hand Wash cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to protect the delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was Max Extract selected?
Ideal for heavy loads such as towels and bedding, Max Extract removes more water from loads during spin.
Were you washing one bulky item, such as a rug or large blanket?
Consider adding more items to help balance the load during spin. Select Drain/Spin or Spin Only cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
Are excessive suds present?
Use only HE High Efficiency detergent. Using non-HE detergent or more than the manufacturer's recommended amount of detergent can cause excessive suds. The excess suds can cause the washer to run at a reduced spin speed, which will result in very wet loads.
See also: Why HE High Efficiency detergent is required
Is the drain hose kinked or is the drain clogged?
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form or hose retainer on the drain hose, and secure the drain hose. See the Installation Instructions for details.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manuals and Literature search below.
Is your outlet voltage low?
Check the electrical source or call an electrician.
Sep 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washers fine but doesnt drain water and go to rinse cycle
Check the drain hose may be kinked. Washers have been known to eat socks, they go in to the the tub during the spin cycle and down in the pump. If you are so inclined to look dome pumps are clear and you can see the sock. There is a hose clamp to remove and you may be able to remove the sock. Reassemble and test. Remember as always to unplug the washer first before doing any work. This exploded view has a washer and if you hover over the bottom right it will show what the pump looks like.
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram Good luck
Aug 21, 2009 | Kenmore 22422 Top Load Washer
WSSH300G0 won't spin - filter is clear
Check your lid switch, and the strike, which is the other half of the switch, and is attached to the lid (the switch is on the machine).
Regards!, --W/D--
Jul 20, 2009 | General Electric WSSH300G Front Load...
Hotpoint VBXR1060T5WB
TOOK THE FRONT OF THE MACHINE OFF, FOUND OUT WHERE THE CLEAR TUBE HOOKED, PUT A CLAMP ON IT SO IT WOULDN'T COME OFF AGAIN. AND IT WORKS FINE. THANK YOU ANYWAY.
LINDA J GRIFFIN
Apr 12, 2009 | Washing Machines
Err02 shown during spin cycle on 1400 haier washing machine
WHEN I INVESTIGATED FURTHER I FOUND THE DRAIN TUBE FROM MACHINE WAS BLOCKED BY SOLID SOAP LUMP BUILT UP AT THE MACHINE END -AMAZING .
Apr 09, 2009 | Washing Machines
Clothes are wet at end of spin cycle
Dear Customer
Please perform the following
Clothes are too wet after spin cycle:
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Dec 17, 2008 | Maytag Washing Machines
Water not pumping out and spin cycle not working.
it sounds like you have something obstructing the pump. does the machine eventually empty? or does it remain with water in it. you need to remove the hose that leads from the tub to the pump and clear any debris. if you continue to run with debris in the pump you could burn out the pump motor
Jul 02, 2007 | Kenmore 44072 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
