Question about Westinghouse Refrigerators
Fridge freezer not cooling
Our westinghouse freestyle bj424t isn't cooling (fridge top freezer bottom), turning the temp dials does nothing, made some strange sounds and now the compressor is making no noise and is hot. any ideas what may bew wrong and how to fix it? ;-}
(bad news) Repair man came today and said the compressor has died ;- (
(good news) Westinghouse will replace compressors less than 5 years old with a new one, just ring them with your serial number (inside front door) or supply a receipt and you only have to pay for the labour ;-)
Posted on Apr 15, 2009
Hi I have Westinghouse freestyle 450 my problem is that no matter how low I have temp the begs freeze in crisper other wise been very happy I have had this fridge for 20years
fridge settings work in reverse to freezer settings
1 for a fridge is almost freezing where it should be around 4
cold air sits at the bottom of the fridge so the setting will be colder in the crisper draw that at the top shelf
May 26, 2017 | Westinghouse Refrigerators
Westinghouse freestyle fridge &freezer work but warm after being turned off fo 90 days
What happens in that 72 hours is the evaporator coil get's so much frost built up on it that the fan in the evap. freezer fan has no where to circulate the cold air (where the cold is produced). Basically you have a restriction between freez/fridg. sections you have defrost problem> It is one of three things d heater,d t stat, or your d timer.I need the model # to tell you what my sugestions would be and where to start.
Nov 15, 2013 | Refrigerators
My Westinghouse RS662V fridge is not cold at all. I have turned the dial to full cold but it has made no difference. The freezer seems to be working OK. Could it be the thermostat in the fridge?
Yes you need to adjust the thermostst located inside the fridge compartment to change the temp. setting of the fridge.
Regards.
PLZ. dont forget to rate my suggestion.
Jul 19, 2011 | Frigidaire FRT18G4A Top Freezer...
Have replaced broken hinge but am stuck getting both fridge and freezer door back on. can do one or the other but not both. westinghouse freestyle fridge/freezer
srack from bottom up- bottom hinge - bottom door- tape door with duck tape- middle hinge- top door- tape top door- top hinge- remove tape- done
May 25, 2011 | Refrigerators
I have a Westinghouse frost free fridge with freezer on top.(RJ340M) Freezer part is working great but the fridge is not performing well at all. Thermostat was my first thought but wouldn't that be...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 23, 2010 | Westinghouse Refrigerators
Top half fridge not cold freezer department fine
I had the same problem; the top fridge compartment was warming up to 14C while the freezer compartment was starting to defrost (frozen stuff was starting to become soft. I took the rear wall off the freezer compartment and found it all iced up. I defrosted it with a blower heater then powered it back up. It all worked fine for a month when the same thing happened. I figured that the defrost cycle wasn't working. I located the defrost timer on the rear right-side of the fridge. I rotated it several times and found that the fridge was turning on and off. I rotated it until the fridge turned off. I waited 5 minutes then stuck my head into the freezer compartment and felt the rear wall at the bottom where he drain is; it felt warm so I guessed the defrost heater element was ok. I ordered a defrost timer and installed it. I haven't had a problem since.
Nov 09, 2008 | Westinghouse Refrigerators
GE not Cooling
FREEZER ON THE TOP OR BOTTOM ?
Dec 19, 2007 | GE GDS20KBS Bottom Freezer Refrigerator
Refrigerators Logo
695 people viewed this question
Top Westinghouse Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
