Question about Zenith DVP615 Portable DVD Player
Screen won't show anything
My zenith dvd protable player will turn on but the screen won't turn on what do i do to fix it?
    President:
  • 814 Answers
You need to test the video output circuits with the help of the supplied cables and your television. Hook up the audio video cable supplied with the dvd player from the dvd player output circuit to the television input circuit.This set up is explained with a diagram on page 17 of the owners manual.After completing the connections, place a dvd in the player and play it. If you can see the video and hear the audio, then your video and audio circuits are still working correctly. You may just want to use this set up for the dvd player instead of attempting the repair process.The problem will be with the connections between the main board and the lcd display. This problem may be a bad connection or dirty contacts in the connection.You can take apart the dvd player and clean the connections.There is a chance that a connector is damaged and will have to be replaced.These connectors are usually ribbon cables and should not be that expensive to replace.The connector will have a part number on it. This is the number you need to look for a repalcement part.When you take apart the dvd player you should completely clean and remove all the dust and debris from the inside of the player. This can be done with small brushes and a can of compressed air. If you cannot see the playback then you are having a problem with the video output circuits. This problem will have to be repaired in a service center. The repair may not be worth it as the cost may be as expensive as a new player..The telephone number for Zenith customer support is 1-800-243-4994. They will be able to tell you how you can get service and repalcement parts for your dvd player. I hope this information helps you with your problem.
Posted on May 30, 2009
Dvd player screen rolls on playback
try and change the PAL/NTSC settings (sometimes P/N button on RCU)
Apr 14, 2014 | Orei Protable DVD-P901 Player
Craig portable dvd player
looks like your lcd is either bad or the plug has come loose. If you can get it apart, try reseating the cable to the display.
Jun 26, 2013 | Televison & Video
Help??
go to the repair store near your block
May 01, 2013 | Audio Players & Recorders
My protable dvd player has a dark screen. I can
there should be a menu button on the controler u can access the brighten button simply turn up the brightness
Dec 17, 2009 | Polaroid 7'' Portable DVD Player
My screen has a green hue and cannot seem to correctit is a protable dvd with lcd screen
One of the possible things:
a loose/bad/dirty connector contact or a bad solder contact inside the case (possibly the LCD screen connector at either side). This may show up as the problem you're having with your unit. Checking and/or cleaning/resoldering the connector pins might solve this.
It may also turn out to be something else (like a bad output from a chip or a bad component inside or near the video section, which might require component replacement.
regards
3rq8 (Triarcuate)
Jul 22, 2009 | GPX PD808B Portable DVD Player with Screen
No image on screen
Definitely take it in. Not much room for error inside.
May 30, 2008 | Zenith DVP615 Portable DVD Player
All I see is a blank blue screen on polaroid dvd player
try pressing the in/out button that should fix a blank blue screen
Jan 30, 2008 | Polaroid PDV-0701A Portable DVD Player
No picture but has sound
Hi If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service. Good Luck!
Aug 14, 2006 | Zenith DVB312 DVD Player
Zenith DVP615 Portable DVD Player Logo
223 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
