Question about GE 24 in. PDW9880LSS Stainless Steel Built-in Dishwasher
Beeping sound There is a constant beeping sound coming from the dish hinge area. The control keys on top are not functional and are not lit. The only way to get rid of the noise is to unplug it or turn it off at the breaker. Thanks Moreno
0 characters
1 Points
My Lxi won't maintain the water level after initial fill. Every load it loses water.
more than probable
if the solenoid for the water exit control is not functioning the water will drain past and lower the level in the machine
get a technician to get a proper diagnosis and a quote to fix.
Sep 13, 2015 | Hobart Dishwashers
Top half of my dish washer beeps when i push the power button
you will find this diagnostic service document useful.
The likely reason for top drawer not starting wash program when you press start button is the drawer home sensor is either faulty or the drawer is misaligned. This means controller thinks the drawer is open and does not start the cycle.
Apr 28, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel Dishwasher beeps while it washes dishes. Any solution?
Here is a suggestion: I had problems with the top drawer on a model 603I, I found that the control board under the drawer cover (at the upper right corner) had a broken latch. This allowed the control board assembly to drop down at the right side which caused the electronic eyes at the side of the drawer to become misaligned. This was giving false information to the control board indicating that the drawer wasn't closed properly. My problem was fixed by securing the control board back in place making sure the electronic eyes were lined up properly. (Note: The electronic eyes I am referring to include two clear plastic tubes about an inch and a half long to the right of the control board. These tubes must be properly lined up with the led and photocell on the side of the control board) It sounds complicated but if you take the drawer cover off you will notice the control board alignment immediately. Its an easy fix if this is your problem. One way to fix it is to take a piece of string and tie the board back in place. (That's what I fixed mine with and it has worked like new ever since.) NOTE: MAKE SURE THE POWER IS TURNED OFF BEFORE YOU BEGIN THIS REPAIR!
Nov 21, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Constant beep, stops and switch to rinse program
Can be related to a fault in the program controller unit as none of the preset programs are working bbut the fault appears universal in all the programs.
The best you can do is to remove the panel and reset, check on the inlet valve and the sparying arms and pump. check for clogging in the drain or the pump which seems to set off the alarm.
Nov 12, 2011 | Dishwashers
My single Fisher & Paykel dishwasher drawer DS603I (Integrated Panel) turns on by itself even after turning off the light switch that controls both units that sit on opposite sides of the sink. The...
Yes ,you may be able to restore function by completely drying the area and PC board located under drawer.Use a hair dryer.
However , you will still have a leak and the problem will return.Usually the leak is drawer lid not closing properly. Suspect lid actuators have failed.Very common.Or some kind of obstruction.The drawer can be removed easily by removing 2 large plastic scews at drawer front.If lid actuators have never been replaced go ahead and do that.It is normal for other drawer to work fine.
Hope this helps you
Aug 16, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & paykel double dish drawer top draw just beeps...
The controllers get very brittle & can break away from their housing, the reason it's rapidly beaping is because it thinks the door is open. PLEASE TURN IT OFF FIRST AT THE POWER POINT. Take the front draw panel off by pulling the plugs situated on the front behind the draws, the controller is at the top right hand side if it is loose then thats the problem, double sided tape will work but lots of it or try a wedge type arrangement. I know this is an old post but people refer to these for solutions much later.
Mar 09, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Difficult to pull door open and loud click coming from left hinge
I would check for obstruction in the path of the door spring areas. If appropriate, remove the bottom access panel (typically 2 screws); open/close the door in attempt to observe the inside bottom left and right for the clicking sound.
If not already done so, also ensure your dish-washer is raised of the floor a little bit; leveled and properly secured to counter top with 2 screws.
Fremont, CA
Jan 30, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
The Fisher Peykel dual drawer dishwasher : the top unit LED is off and the setting for length of wash is not lit up and is not functioning. There is power to unit because when I hit the lock button it...
can you see a small lock inside the display panel??? the control may be locked. another issue might be a broken heater plate, not a very home owner freindly part to change( heater plate has a fuse inline that would kill power to function
Nov 16, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
F&P dish drawers model DD6031
It may be that the DW thinks the drawer may have been pulled open. On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. This is how the drawer senses whether the drawer is open or closed. Wipe these areas with a clean dry cloth.
Apr 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwasher not working
disconnet power to unit....circuit breaker...wait 30 minutes....try again
Jun 02, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
GE 24 in. PDW9880LSS Stainless Steel Built-in Dishwasher Logo
21 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Michael Thomas
Michael Thomas
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
