Question about MagLite 3 Cell D Blue Flashlight S3D116
Keeps turning itself off when adjusting beam
Hi, I use the 3D Maglite at work and have found lately the beam has been turning off when I adjust the beam by turning the cap or even if I just move the torch around. Have tried new batteries etc, but no help.
This is my second Maglite after the first one did the same thing after about 18 months of use.
  • Anonymous Mar 29, 2014
    When attempting to adjust the beam diameter on maglite, it will not adjust.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 75 Answers
It sounds like the spring in the tail cap may be depressed which would cause intermittent contact with the negative end of the Batt. Shake the flashlight vigorously, you should NOT hear ANY noise. If you DO, take the end cap off and pull on the spring, you are trying to stretch it out a bit, replace the cap and shake it again. Go through these steps until it is QUIET when you shake it.
Also make sure there's NO CORROSION at the Positive and Negative ends of the contacts.
Maglites are pretty user friendly and the best light money can buy. I have the rechargeable model which I carried for 21 years during my tour in law enforcement.
Anyway, if it still refuses to work properly, go to; www.maglite.com they are based in California. They will help you get it going. Good luck. :)
Posted on Apr 25, 2009
Hi I got a problem with my Volvo V70 headlights. When i turn on highbeam, the lowbeam reflector adjust itself up, providing more light to the high beam. After i mounted a h9 55w xenon kit into the hi
it may need reset at the dealer to accomodate the new style/type of lamp..unless the cars', original factory setting does not allow for that change to be made.. they can tell you either way..
Dec 24, 2013 | Volvo Cars & Trucks
Mazda Astina 1991
Find level ground with a wall. Drive up to the wall and mark where the centre of your headlights are on the wall with a piece of tape. Back up 20 feet and turn your headlights on high beam. Using the adjusting knobs make each light shine directly on the spot. Low beam adjusts itself down and to the left/right (away from oncoming traffic depending on what side of the road you drive on)
Nov 17, 2013 | Ford Cars & Trucks
Which way do the headlight vertical adjustments turn to raise the beam?
Turn on your headlights and locate the two adjustment holes that have the adjustment screws inside them on the sides of each headlight. The top hole has the vertical adjustment screw and the bottom hole has the horizontal adjustment screw. Turn the vertical screw clockwise to raise the beam and counterclockwise to lower; turn the horizontal screw clockwise to move the beam right and counterclockwise to move the beam left.
click this link for more help:--- http://technoanswers.blogspot.com/2011/05/how-to-adjust-headlight-beam-on.html --------- This should help.thanks.Helpmech.
May 29, 2011 | 2002 Chevrolet Corvette
How do I adjust the low beam headlght on a 2006 Sabaru Tribecca B9
I have a similar problem. The adjustment screw adjusts both the high and lof beams. After changing the passenger side low beam, both sides then pointed at the ground. High beams were fine. I adjusted so the low beams are fine but now the high beams point straight up.
In talking with Subaru Service he said there is a "module". He said after changing the bulbs they should point down then auto-adjust back up. That didn't happen. I haven't found anything on such a module. He said it woul be $109 for adjusting the lights OR for the module.
If I find anything more I'll let you know.
Apr 10, 2011 | 2006 Subaru B9 Tribeca
Bought a maglite 2-cell D today, put batteries in..no power at all.. help :)
make sure battery is good. Did you install batteries correctly? flat side (-) in first. Try adjusting the head where it screws on.turn in both directions. Last if this doesn`t work -return it for an exchange where you bought it..
hope your not in the dark..
Feb 25, 2011 | MagLite Mag Instrument Mag Lite 2 "D"...
I Have an Audi a4 Quatro 2004 model. Adjust Low Beams?
There are two adjustment points (screws). For example left headlight: you will see one point near the end of left wing, at bottom side through a wing hole. This is for vertical plane headlight beam adjustment (up-down). Another one point is against water radiator side. This is for horizontal plane headlight beam adjustment (left-right).
Nov 19, 2009 | 2004 Audi A4
How do you make adjustments to a 99 bonneville headlights. Repairs were done to the front end and the headlights don't shine on the road now.
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
Oct 01, 2009 | 1999 Pontiac Bonneville
How do i change the bulb
Unscrew the bottom portion, where the batteries go. Then unsrew the top where you can adjust the beam width until it comes off. Very carefully pull the bulb out and replace the old bulb with the new. The Reassemble is the reverse of the procedure.
Jun 23, 2009 | MagLite RX3019 Rechargeable Flashlight...
I have a renault clio 98 and the headlights are pointing low.how do i adjust them.the wheel inside the car does not adjust them?
drive your car and stop in front of anny wall aprox 2 meter, turn the low beam on, the beam supose to be not highes than the hood level adjust it with a screw driver on the ligth itself
Dec 22, 2008 | 2005 Renault 181
Adjusting light
Hi, Maglite should replace this or repair at no charge. They are a very good company to deal with. Try calling customer care. Hope this works.
Nov 16, 2008 | MagLite Mag-Lite& Largehead Flashlight
MagLite 3 Cell D Blue Flashlight S3D116 Logo
475 people viewed this question
Top MagLite Camping, Backpacking & Hiking Experts
John Egan
John Egan
David Black
David Black
Level 1 Expert
 steve
steve
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
