SOURCE: riding mower problem
What is the name brand and model? On most riding mowers there are several switches that must be actuated before it will start. First, make sure that blades are disengaged. If there is a handle that engages and disengages them, you might try holding it in the dis-engage position in case the switch is out of adjustment. There is probably one under the seat also. This switch kills everything if you are not sitting in the seat for safety reasons. Also, make sure the parking brake is set, and the gear is in neutral, and not forward or reverse. Also, you should check the battery. It is possible that you left the key on by mistake and drained it.
Hope some of this helps.
C
SOURCE: 4 year old mower, kept
Is it possible the key was left on and the battery went dead? Maybe try jumping it off of a car battery to test it.
SOURCE: I mowed my yard two
check 2 c if it low on oil some mowers hav safety switch it will stop the spark
SOURCE: Poulan 38" riding mower.
Battery is likely dead - or has built a sediment bridge - shorting the anode and cathode.
Jump-start the tractor with your vehicle - or another battery to check.
Or - use a multimeter to ensure your battery is not draining to 0V when you attempt to start.
This also indicates a failed battery. It may have a decent float charge - but when the load starter) is applied - the voltage will drop right out.
Thanks for using FixYa!!
SOURCE: fixya
Turn the flywwheel, see the doesn't turn over. When was last time y ou
adjust the valves?
