Question about Kenmore 24032\24036 Top Load Washer
How do you compress the spring that holds apart the spin brake on the drum of a whirlpool washer?
Got a spring compressing tool that kinda looks like a channel with a hinge at one end and a bolt halfway down that you loosen to open up the "mouth," stick in the spring, then screw down the bolt, compressing the spring. Once the spring is in place, you loosen the bolt and it releases it onto the brake calipers and voila! The spring is in place.
Posted on Apr 14, 2009
How to remove and clean and replace the rear brakes on a 2008Toyota yaris
REMOVING REAR BRAKE DRUM SUB-ASSEMBLY
1. Release the parking brake and remove the rear
brake drum.
If the rear brake drum cannot be removed easily,
do the following:-
2.Remove the hole rubber and insert a screwdriver
through the hole into the backing plate, and hold the
automatic adjust lever away from the adjuster.
3.Using another screwdriver, contract the brake shoe
by turning the adjuster.
4. Take out the brake drum from the flange.
5. remove the shoe hold down spring cup, shoe hold down spring, pin and front side brake shoe.
6. Remove the tension spring. Remove the shoe return spring from the rear brake shoe and remove the parking brake shoe strut set.
7. Remove the shoe holding spring cup, shoe hold spring, pin and rear brake shoe.
8. separate the parking brake cable.
9. Remove the automatic adjust lever tension spring and remove the automatic adjust lever.
10. remove the C-washer and remove the parking brake shoe lever.
NOTE: Do not use any solvent like gasoline to wash the brake parts.
Always wear safety goggles and mask before using compressed air.
Dec 28, 2013 | Cars & Trucks
The agitator works well during the wash cycle. When the drum spins, the agitator will not if the clothes touch the agitator. The water empties, but the agitator prevents the drum from spinning.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following Whirlpool Service manuals for top load, direct drive washers. They describe what happens in the transmission when the washer goes into spin mode:
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Also see the Whirlpool Parts list for their Commercial washers, although the consumer models use the same transmission.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Basically whats happening is this.
When the washer goes into spin mode two plastic cams are forced together and raise a gear on the main agitator shaft that is supposed to keep the agitators from spinning. If the cams are worn (not necessarily broken) the gear doesn't lift high enough to completely disengage the agitators. We had the same problem. Ours was a major gear noise but a clicking could also be a symptom as well as the agitator keeping the drum from spinning. A set of Whirlpool Agitate Cams (part number 62580/01) cost about $15.00.
It's a bit messy to fix (15 oz. of 80-90 weight gear oil in the transmission available at auto parts stores) but very inexpensive.
See the following for how to remove the transmission.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators.
The top agitator uses a plastic 1/2" drive bolt. A 1/2" socket extension works well.
You don't have to remove the drum.
You can also see this site for removing the transmission.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 15 Oz of 80-90 weight gear oil. (Available at auto parts stores)
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
I'd also check the Motor Coupler (a $15.00 item that tends to wear) while you have the transmission out.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Jan 20, 2011 | Kenmore 22422 Top Load Washer
Washing machine works but when it comes time to spin it gets stuck the water drains but wont spin you can hear it trying but its like the brake is stuck if I open and close the lid then it will spin and...
Assuming that you have a Kenmore / Whirlpool top load, direct drive, neutral drain washer.
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Also check the Sears parts site for your washer:
Enter your model number and you'll see a list of major sub-components.
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 16Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, the kit cost us $15.00 which is a lot less than the $170 for a new transmission.
Jan 06, 2011 | Kenmore 24032\24036 Top Load Washer
Washer has been making a loud noise when spinning like a bearing noise for several months, it finally jammed up- what do you think has happened? The washer is about 12 years old and has had at least 2...
One possibility is damaged / worn Agitate Cams.
When the washer goes into spin mode two plastic cams are forced together and raise a gear on the main agitator shaft that is supposed to keep the agitators from spinning. If the cams are worn (not necessarily broken) the gear doesn't lift high enough to completely disengage the agitators. We had the same problem. Ours was a major gear noise but a clicking could also be a symptom. A set of Whirlpool Agitate Cams (part number 62580/01) cost about $15.00.
It's a bit messy to fix (15 oz. of gear oil (auto parts store) in the transmission) but very inexpensive.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, (Check that the clutch bands are OK. If not, Whirlpool and Sears have replacement bands. I'd also check the brake and drive tube assembly with the transmission out.) the 8 screws carefully the transmission holds 15 Oz of 80-90 weight gear oil. (Available at auto parts stores)
With the transmission apart, check that all the parts look like those in the service manuals and that nothing else is broke.
Jun 17, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer drains but wont spin
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If it will drain (AND AGITATE) but won't spin the problem is likely in the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for top load direct drive washers.
When ours had a similar problem, we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
May 13, 2010 | Washing Machines
Top load 80 when spin is complete and drum noise
KENMORE top load, direct drive, neutral drain washers are made by Whirlpool.
Assuming that the springs are OK and that the vibration pads are in place and not worn, (See the Sears diagram or the following Whirlpool Service manual)
the problem points to the brake.
The washer uses a brake system to stop the basket at the end of the spin cycle.
Just like a brake on a car, it's designed to slip a bit so that the basket / car doesn't come to an abrupt halt.
Over time, the brake shoes can jam against the brake drum and bring the basket to a halt too quickly with a lot of noise.
A way to solve this (that I tried and it works) is to pull the basket tube / brake assembly and if the brake shoes look OK, spray a small amount of silicone spray on the inside of the brake drum.
Following is a description of how to remove the cabinet, pump, motor, transmission and basket drive tube on Whirlpool / Kenmore / Roper direct drive washers.
As an aside, you don't need a special spanner wrench to remove the spanner nut. I've found that a short (10") pipe wrench hooked over one of the spanner nut tabs and tapped with a hammer will usually loosen the nut. Also, rather than hitting the Drive block directly with a hammer, put a short piece of wood under it first to protect it.
Following are the Whirlpool Service manual for this type of washer and the Whirlpool parts list for their commercial washers although the consumer models are basically the same. Whirlpool (and Sears) have replacement brake pad / spring sets.
May 12, 2010 | Kenmore 24032\24036 Top Load Washer
Model 2485-2300 Top Load Washer I have to
First, see the Sears Parts site for washer model 110.24852300 which I assume is your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.24852300
Whirlpool / Kenmore top load direct drive washers use a clutch to start the Spin Tube which turns the tub.
They also use a Neutral Drain Assembly in the transmission which allows the washer to drain most of the water out before starting the spin.
Two possibilities:
First, See the following for how to remove the cabinet, pump, motor and transmission in order to check the clutch.
Check the clutch for wear as well as the springs. If the clutch is worn or the springs are broken, Sears has a "rebuild kit" for the clutch.
If the clutch is OK, the problem points to the Neutral Drain Assembly in the transmission.
This is a Whirlpool PDF on how these washers operate. It has a detailed section on how the transmission works.
It also has a troubleshooting guide.
Manually turning the drum apparentlthrows the cams into the right gears so that the washer will spin.
Nov 29, 2009 | Kenmore Washing Machines
Kenmore Elite Washer Does Not Spin
This a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20992991
The brake on these washers is driven by the clutch on top of the transmission.
If the washer drains the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again or stopping and starting the cycle knob, and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Apparently, by opening and closing the lid, or stopping and starting the washer torque from the motor starting throws the cams into the right gears so that the washer will spin.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
Nov 16, 2009 | Washing Machines
Washer all over the place.
In addition to the springs, I'd check the suspension plate and base assembly pads. These are also used to keep the washer from walking.
See the Whirlpool / Kenmore installation and maintenance manual for these washers.
When we took ours apart to work on the transmission, we broke one of these and the washer walked all over the place.
$10.00 for a replacement set solved the problem.
If you removed the drive tube to fix the brake, make sure that the two tabs on the drive tube fit into the slots in the basket drive block.
Oct 05, 2009 | Kenmore 23822 Top Load Washer
Drum shakes during spin cycle
I have a 7 year old duet washer. It started to shake during the spin cycle. It is level and the shocks and springs holding the drum are working. When the washer gets to the spin cycle, it is apparent that the drum is off center.
I tore the machine apart and found that there is a bracket at the back of the drum. This bracket sits in water so it was covered in slime. I found several large cracks in the bracket. Once these cracks occur, there is now way the drum can spin correctly. The bracket is welded to the back of the drum, so it has to be completely replaced.
What a poor design. I would guess that many, many other people will be seeing the same problem within a couple years. I was lucky in that I did not pay for a repairman to try to fix it.
Oct 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
131 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
