Question about Audiovox CDM8910BM
BATTREY LEAKING RED FLUID
CAN YOU HELP ME MY PHONE IS LEAKING A RED FLUID FROM WHAT LOOKS LIKE THE BATTERY
  • 41 Answers
Get a new battery mate, before the fluid damages the phone. have a look on ebay or check out a cell phone store.
Posted on Sep 11, 2007
SOURCE:
How do i fix leek under dash looks like around speedometer cable?
Can i get a little more information. Is this a steady leak? There shouldnt be anything leaking from that region unless there is water pooling in the air intake for the hvac that has rusted through the fire wall.
Mar 26, 2015 | 1985 Nissan Pickup
2005 Jaguar s-Type Couple of weeks ago red light came on to indicate engine coolant low. Went by Goodyear and they put in anti freeze. Yesterday and today, the red light and same message are coming on...
You are leaking fluid. Check to see that the hoses don't have residual fluid on them indicating a leak. Also check to see if your water pump isn't leaking out the seal. Another thing to check is the oil dip stick. Make sure the oil looks normal and not watery indicating a crack in the block. These are only a couple of things I would start with.
Oct 28, 2013 | Cars & Trucks
I have a 2005 dodge caravan and is leaking red fluid under the engine what could cause this problem help?
Check all the fluid to see which one is low. Red fluid can be transmission fluid or red coolant fluid.
Feb 03, 2013 | 2005 Dodge Caravan
Leaking red fluid humming sound when accelerating
Transmission fluid! You need to find the leak and stop it; top up the transmission before it is damaged. Check the lower pan for a gasket leaking and examine the transmission fluid cooler lines running to radiator or to in front of radiator.
Jan 17, 2013 | 2002 Mazda MPV
I have red oil leaking from the bottom of my engine looks like its coming from the sump
Red oil might actually indicate that it is actually automatic transmission fluid coming from the gear box and not the engine. Either way you need to see a mechanic quickly.
Oct 07, 2012 | Cars & Trucks
I just hit some kind of animal it broke off my front guard on the right side by my radiator hose something is leaking looks like something is missing
You should have someone knowledgeable look at your vehicle. There are cooling lines for the transmission and oil coolers for the Power Steering in that area. If the part is leaking, look at whether the fluid is red or green or orange. The steering and trans fluid is red, the rest is coolant. Brake fluid is basically clear.
You don't want to lose any fluids and you should monitor the fluid levels depending on the color of the leak.
The Auto insurance appraiser would look under your vehicle. Or you could go to a Collision shop and they would check it out in the estimate process. Some of the underside parts could be replaced with Salvaged parts to cut costs. They do not show and it could absorb your deductible.
Dec 27, 2011 | 2003 GMC Envoy
2002 T-fird fluids leaking
Not really sure what your asking. But if your leaking from the power steering unit but it looks like tranny fluid it's because it is tranny fluid. Power steer fluid and tranny fluid are the same except that tranny fluid has a red dye in it.
Sep 07, 2009 | 2002 Ford Thunderbird
Leaking red fluid
The red fluid is transmission fluid, check the transmission fluid level, if it get's to low the transmission will burn out and your looking at a expensive job.
The fluid could be leaking from the transmission cooler line to the radiator in front of the car. Have it repaired and keep an eye on the fluid level to the transmission. Note: transmission fluid is flammable and may catch fire if slashed on to any hot area's like the exhaust.
Good luck and hope this helps.
May 26, 2009 | 2002 Dodge Intrepid
Leaking fluid
it could be your automatic transmission fliud. normally this fluid is color red. have it checked right away because you may have bigger problems if you ignore it.
you can check your level by running the truck on neutral and check your dip stick on your transmission fluid.
tnx 4 using fixya.
drcool
Aug 24, 2008 | 2005 Ford Escape
Red color on screen is warped on my LCD projector TV.
Normally the oily fluid coming from a picture tube, is the coolant from the tube. It's very combustible and have been known to start a fire. You have two problems in this set. A leaking blue picture tube. A convergence circuit that needs repaired. Call a local servicer and see if they will give you an estimate over the phone. It's time to start looking for a new digital set. Good Luck.
Jun 23, 2007 | Hitachi 50UX58B 50" Rear Projection...
Audiovox CDM8910BM Logo
120 people viewed this question
Top Audiovox Cell Phones Experts
Marvin
Marvin
Spud Howell
John Porter
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
