My 1987 warrior will not rev out in any gear and will still idle fine all as it will d is spit and sputter beyond half throttle...iwas told that maybe half of the stator is pooed it being two pieces
Sounds like leak in high pressure side of turbo to inlet manifold tube. Results in gutless or no performance but idle & revving in neutral ok. Check for splits or loosened joints.
If it is old enough to have points then I would check them and make shure they are clean and gapped at .020. if that is noth the problem then it sounds like a fuel issue. Either a weak pump or a dirty carb.
Try checking the switch for your parking brake. It is the top wire in the clutch handle boot. This wire connects to your CDI box, and restricts the RPM's while the parking brake is engauged. To find out for sure, trace the wire down to the plug under the headlight assembly and disconnect it. Now try starting you machine and give it some throttle!
