Question about Home
Too much noise from the motor, can we replace for a quiet one?
Attn: Customer Service,
We have a Maax, Agora whirlpool and air massage combination tub with an electronic variable speed pump. It currently has a Gimini Plus model #R100-cc, Spec #0005E00cc motor on it. We need to replace the existing motor for a quieter one [it works but it’s way too noisy]. What would you suggest for an easy replacement and installation?
NOTE--We have a bed and breakfast and it is important to get the quietest motor possible. The current controls have a variable speed capacity but if we could use the same control panel but with a simple on and off operation that would be our preference.
Please contact my husband Paul Antozak, a licensed builder, to discuss possibilities @ 616.560.1469.
Warmly,
Cheri Antozak
We also have that tub and the motors are blown on the pump. Did you ever replace the motor? I can't find anyone who carries these pumps anymore as they're discontinued. Does anyone know of anything that will work in replacement? Please let me know if you have any information. 203-395-5868 Thanks Ferdy
Posted on Dec 13, 2012
    Scholar:
  • 80 Answers
Unfortunately I have yet to see a "quite" motor for a jetted tub. The only soultion I have found for the noise is to use rigid or fiberglass insulation on the inside of the tub platform. Care needs to be taken so as to not block the back of the pumps or blower, this will restrict airflow and cause damage to pumps/blowers.
Posted on Aug 19, 2009
Water sensor needs to be replaced. 8 yr old unit. Maax doesn't carry old parts unavailable HELP PLEASE!
Parts for Maax Spas‎
www.spaguts.com/
(714) 764-0014
Pumps, packs, heaters, controls,
ozonators for Maax hot tubs.
# 27 Hot Tub Heater Replacement for 240 volt hot tubs ...
? 6:27
https://www.youtube.com/watch?v=xNWjM8c_b-8
Oct 10, 2011 - Uploaded by softcellelectrical
27 How to replace an in line or flow through heater for an above ground ... I just changed out the water in my spa when I discovered the heater element ... Is there a hose that should fit on it? ... I figure it will run similar to a whirlpool setup. ... tests on the unit...but, it sounds like 1. your sensors may be DC and
Jan 18, 2016 | Maax Home
Can't turn on Whirlpool
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
Rod
US Parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
May 09, 2014 | Maax Home
Replace air hoses on whirlpool?
What size of air hoses? What do they go to?
Is this an Air tub?
US Parts Center
Mar 06, 2014 | Maax 101054-004 Topaz Whirlpool Bath Tub -...
Aerofeel does not work on maax tub model 105359-055
I asked the same question to the tech guy at customer service and he said no, because the water detector switch is actually a density switch, so the temperature really doesn't matter. The tub just has to be filed with water.
Feb 16, 2014 | Maax Home
Maax Hydro massage bathtub Model 05-001, electric motor hums but does not turn, what is the fix?
If your pump is just humming this is an indication of a bad motor. You will need to provide the name of the pump and a model number to the supplier so they can match up the exact replacement for you so you won't have to re-plumb to put it back in.
Rod
US Parts Center
Jan 14, 2014 | Maax Home
Cold air blowing into Maax Velvet 6032 Bubble Tub
The air coming from the blower will be cool, but should not be cold. Turn on the blower or bubbler feature (no water necessary) and go to the access panel ( as specified by install instructions), reach in and feel the tube connected to the blower, the tube should be warm, if not the heater coil is not working and the blower assembly needs to be replaced.
Aug 16, 2009 | Home
Broken back massage jet unable to purchase locally
Hi robrezza,
Here's the number the Pearl/maax Plant.
For maintenance, installation or general technical queries about your MAAX products, we encourage you to contact us at: Tel.: 1-888-957-7816 option # 2 Fax: 1-800-201-8308 (418) 387-9086
Have your tub model when you call. They usually are pretty helpful. Sometimes it goes to voice mail for the tech person but they call back after a bit
Please rate this response and Good Luck, Phil
Jan 18, 2009 | Whirlpool Pearl Ballade True Bathtub with...
Home Logo
323 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
