Just a consumer quesstion.
Would it be a bad idea to mount my LCD tv above my fireplace? There is a recess in the wall above it and it seems like a natural fit. Will i pay for it in the long run?
    New Friend:
You should try giving Embers Sleaford a call or have a look on their website for their contact info. I'm sure they'd be able to point you in the right direction... http://www.embersuk.com
Posted on Aug 01, 2011
    Problem Solver:
  • 5 Answers
Not knowing the architecture of your house and what type of fireplace you have it is hard for me to answer this effectively. You say you have a recess, was this recess designed for televisions as is commonplace in recently built homes? And what type of fireplace do you have, is it wood burning or gas? By any rate I would not mount a TV above a fireplace unless I was sure it would be safe there. Try putting a small thermometer where you'd like the mount the TV and check how hot it gets while you use the fireplace. Also, do a visual check for the amount of smoke that escapes the fireplace back into the room and not through the vent/chimney. If after doing this it seems reasonable to mount your TV there go for it.
Posted on Oct 07, 2007
    Sniper:
  • 50 Answers
Heat rises and smoke has particulate matter in it. And heat is the enemy of electronics. So personally, I would not mount any expensive TV over a fireplace. However, if you have nice glass doors covering your fireplace opening, good updraft in your fireplace, and a large mantel that projects out over the opening, you will probably get reasonable life out of your LCD TV.
Posted on Sep 11, 2007
I live in Iowa, where can I get my Olevia TV repaired? I have audio, but a black screen. I have had this set for only 2 1/2 years.
Posted on Dec 15, 2007
SOURCE:
Can you give me some advice on, how to mount a 46in tv above my non working fireplace mantle?
You would have to use a mounting bracket specifically designed for the type of installation you describe and it certainly would have to be fastened into the studs behind the sheetrock. A TV of that size will be heavy to lift and install in the bracket
Mar 04, 2013 | Universal Bedroom Mounting Bracket For...
I just bought a 46 inch SAMSUNG LED HD TV from Best Buy and will be mounting it on a brick wall above the fireplace. The fireplace has gas logs with a an 8 inch mantle that extends 8 inches off the...
it is not safe to mount the TV 8 inches above the mantle.
Secondly, the heat will certainly be a danger if the TV is mounted above the mantle.
I would advice you look for another position to mount the TV.
I hope the above is clear.
Regards.
Sep 27, 2011 | Televison & Video
WILL BE BUYING LCD TV IN NEAR FUTURE, BUT NEED TO MOUNT IN ON WALL WITH FIREPLACE, SEVERAL FEET ABOVE EYE LEVEL. CAN DO?
Absolutly, I have wall mounted a few dozen above fireplaces in the past 5 years; I can even send you over some pictures and suggestions come time for the install.
What is the wall material? Brick mantel or drywall with wood studs?
Although a TV looks attractive about a fireplace you have to consider that it is fatiguing to watch from such a high height. The optimal average height for a TV is 45" to centre (depending on furniture). If you exceed that by a few feet watching a lot of TV is awkward.
The advantage is it combines the focal point of the room, and instead of having a picture about a fire place, your TV becomes the work of art and can be used as a digital picture frame.
Jan 01, 2010 | Samsung LN52A850 52 in. LCD HDTV
Can I wall mount my Tv above a gas fire?
If your talking about enclosed fireplace with the glass front and the vents from it are facing down. Then yes you can use your judgment though. Just make sure their is enough space between the tv, and the fireplace so their isn't direct heat blowing on the tv. A good 4-5 feet above the fire place or more would be fine.
Sep 29, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
I want to mount my 42" LCD TV above the fireplace mantle. Will the heat from the fireplace damage the TV. How far should it be recessed?
it's not a good idea to mount any tv above a fireplace mantle. Anytype of excessive heat added to the tv besides what it generates itself can cause distortion and loss of use in the tv by saudering or melting of connections that you cant see. If in doubt, is there a place where youve seen a tv mounted above the fireplace mantle, and ask them about any issues they may have come across, or are they also restricted to keeping the fire very low.
Aug 24, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Samsung tv wall mounting
For a true flush mount installation, you will need to recess your connections (i.e. power, HDMI, S-Vid, etc). Most tvs have the connections coming out of the bottom to allow flush mounting.
If your wall is not drywall, or you really don't want to bother with the expense of recessing your outlets and cable connections, just get a swivel arm mount. It will allow the TV to sit a bit further from the wall and still look ok.
Go to www.monoprice.com for great deals on mounts. I have 3 of them in my house and they are excellent quality.
May 22, 2009 | Samsung LN46A650 46 in. LCD HDTV
Can i mount 40in lcd tv on wall above open wood/coal fire?
The question is not whether you can, but what will it do? I wouldn't recommend it for a couple of reasons. First, the additional heat will be very bad for the electronics. Second, the backlight inverter boards generate high voltage which will act like a magnet to attract and soot and dut kicked up from the fireplace, eventually causing problems. Unless you plan on having the fireplace for decoration only, don't do it.
Nov 08, 2008 | Televison & Video
Wall mount for 52in tv ?
Here is a mount rated for your size TV http://www.bhphotovideo.com/c/product/518312-REG/Bentley_PLAW_6000FB_PLAW_6000FB_32_60_Flat_Panel.html
Also, be VERY careful mounting ANY plasma above a fireplace. Plasma sets are typically convection cooled to avoid the noise of fans. The heat from a fireplace will GREATLY reduce the life of the set. When people I know insist on putting a set above a fireplace I usually insist they install a cooling fan with ducting that will vent fresh air to the set. If you are concerned about the temp of your set simply consult the owners manual for operating temperature and measure the air above the fireplace yourself. BHphotovideo.com typically has good prices on mounts along with amazon. most other places like bestbuy or circuitcity will stick you on the price of the mount because they make their money from accessories. Also, why did your last set die? plasmas are typically rateed for 10+ years, did yours over heat and start to change colors?
May 17, 2008 | Televison & Video
Distance over gas fireplace
Both LCD TVs and plasma TVs get hot, though plasma TVs tend to be a bit hotter in my experience. Also, plasma TVs are going out of fashion.
A lot will depend on the construction of your fireplace. If it's brick it should insulate fairly well.
Either way, I would recommend a mounting solution that does not put the back of the TV flush with the wall. Get one that tilts. I would avoid the "arm" style ones as that will put additional strain on the mounting.
Remember to think about how you want to run your power and video cabling as well!
Apr 06, 2008 | Televison & Video
Loss of the color Red....Possibley others on my plasma
If you are lucky, it could be an open resistor or defective IC. Otherwise, I see a new TV in your future as the Plasma display would cost nearly $5500 for the part alone. If the fireplace is used much, I would not mount a TV above it, especially a plasma set which generates a lot of heat all by itself. If the fireplace is only used occasionally and you want to put the replacement set in the same spot, then I would consider a LCD model instead.
Jan 10, 2007 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Televison & Video Logo
427 people viewed this question
Top Televison & Video Experts
Ekse
