Question about Fujitsu Desktop MPG3204AH 20.4 GB Hard Drive
Recovering files from a bad drive using external hdd enclosureh
Hi. I need to access files from my laptop hdd, which gave me an error 'Operating System not found' during reboot. I put the 'problem' hdd into a Vantec NexStar SX 2.5 external hdd enclosure, connecting to USB ports of another laptop running Win XP. In 'my computer' I see the 'problem hdd' as Drive E: Local Drive with 26.4GB capacity, healthy (Active) status when viewing under 'computer management'. However, I can't see any files under this 'problem drive'. When I click on drive E, I get the message asking me to format the drive. Since I want to access the files from this disk, I click 'no'. Can you suggest a way to access the files from this disk? Thanks.
    Brigadier General:
  • 6,966 Answers
Hi, I usually use GetDataBack (2 versions FAT and NTFS). I have used this program to recover files from HDs similarly connected (external case > USB). The freeware versions will allow you only a limited number of files at a time, the paid version will allow you to recover all (including purposely deleted files). There are similar programs/freeware but my experience with GetDataBack has been super so far that I really have no reason to look for another one. Pls refer to the 2nd image on this link where GTB was recovering files from an HD that is not even recognized by Windows XP in "My Computer". http://www.fixya.com/support/t191153-device_recognized Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Sep 11, 2007
  • Louie  Role
    Louie Role Sep 18, 2007
    My posting did not answer your query "Can you suggest a way to access the files from this disk"?
My laptop cannot detect my hard drive. It no longer vibrates and the light doesn't blink anymore.
the drive could be potentially corrupt.
plug in your HDD and run recurrva and try to recover files if you cant do that remove the HDD from the caddy and plug into a PC and test if you can access your files if not reformat by right clicking on the drive in my computer (ntfs is recommended) you will loose all data but you may be able to recover your HDD
Jan 04, 2014 | Toshiba 500GB STORE ALU2 PORTABLE USB2.0...
Iomega 80GB external HDD not read because of I/O errors. This occurred after the drive was checked for volume errors
Try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files. download it from
http://download.cnet.com/Asoftech-Data-Recovery/3000-2248_4-75328850.html
Sep 07, 2011 | Iomega Portable 80GB 4200rpm 480Mbps USB...
I lost all data on my external hd and tried to do a recovery for files and said it lost data and cannot rcovery data on hd. After restarting computer and hardrive is connected w/usb and power is on it does...
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files.
http://www.asoftech.com/adr/
May 20, 2010 | Fantom Drives GForce GreenDrive 1 TB USB...
New computer won't recognize my Firelite, works on old computer
You need drivers for USB, if you remember when you bought smartdisk you got the installation disc, that you now need for a new computer.
Oct 31, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
Sony Vaio laptop could not access 1TB external hard drive
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
Oct 20, 2009 | Western Digital Computers & Internet
The hard drive is not being detected on our laptop it turns on and everything but its not being detected what is the problem its not even a year old yet.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
Oct 09, 2009 | SimpleTech 1TB SimpleDrive USB 2.0/eSATA...
External hard drive does not display icon in My Computer
Mar 03, 2009 | Verbatim 160GB USB FireLite: The "drive...
Recover Data
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Nov 16, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Won't recognize on windows XP(SP3)
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files.
Aug 10, 2008 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Can't open HDD drive
Hi
1. Start > Run > type in cmd then click OK to get a command prompt.
2. Type in chkdsk e: /r (replace e: with the drive letter of your external hard drive).
This won't do any harm, it will fix errors on the disk and try to recover data from bad sectors. It might not solve the problem but it's worth a try. Jyo
Jun 19, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Fujitsu Desktop MPG3204AH 20.4 GB Hard Drive Logo
198 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Carlo Barzo
Carlo Barzo
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
