Question about Sharp AR-153E Copier
No power When I turn-on the power, there's nothing on the control panel, I dont hear mechanical parts moving, but on the top where you place the documents, I can see a white light. Now I tried pressing the Scanner button, the lights, number zero came ON, but I cant change the number of copies up/down button. I hope it's now the mainboard problem.
  • 163 Answers
Plese you press the copy key an error code will blink tell that error code
Posted on Sep 13, 2007
Tc3000 not calibrating
Sounds like it's the controller. Those are very hard to find parts. Most repairs on Bowflex are nearly impossible after the machine is about 4 years old.
May 26, 2017 | Bowflex Treadclimber
Hotpoint WMF760 fills with water but doesn't move through programme
Bad motor/ DC power inverter control assembly. My suggestion is don't buy electronically controlled washing machines. They're designed to stop working and for corporate to sell you parts and service again and again and again, until you go buy a rebuilt second hand fully electro-mechanical good ole reliable mechanical top load washing machine.
Feb 07, 2014 | Washing Machines
Users manual for admiral atw4475xq
ATW4475XQ - Admirial Water Saver washer - Adjust Rinse cycle water level
The rinse cycle water level can be adjusted. Unplug the machines power.
You can youtube a video on how to remove the top control panel, its just 2 screws on the back of it,
phillips head. Swing the control panel up, and find something to support it so you have both hands free.
(http://www.youtube.com/watch?v=MYn0_qCFdec)
You'll see a clear plastic tube coming up from the back rear like 3/8 in diameter, to a "T"
connection. The one that goes to the left, thats the wash water level switch it connects to. The one you
can adjust, large, medium, small, from the front of the panel . The other off the T goes to the rinse
water level switch. There is not a knob to adjust it. But if you look at the bottom of the lever
mechanism/cam pickups of both switchs, you will see that they are the same. Rotate the wash load size
(knob on outside of control panel) from small to large, back to small, notice how the mechanism changes?
The rinse water level swtich acts the same way, although it is only a 2 position switch, small and
large. Once you watch the wash level mechanism move from rotating it back and forth a few times, you
should be able to see how to rotate that same mechanism on the rinse switch 1 click. It will click into
place, there are only 2 positions as I said and from the factory its in small, so once it "clicks in"
dont go any further. I did mine with a very small screw driver without removing the rinse switch.
Once you get that hidden switch turned to the other position, put it back together, fire it up and now
your rinse is the large level, all the time.
NOTE: There is a white plunger out of the end of each switch with a screw located in place. Dont mess
with the screw or that plunger. As you adjust the lever mechanism/cam this adjusts the amount of that
plunger sticking out, which changes the pressure pickup for water level.
May 17, 2012 | Admiral Washing Machines
How do you take the control panel off of a ATW4475XQ admiral washer
Pulled this together from two other posts & added some details that I found as I performed the fix successfully!
Mar 17, 2012 | Washing Machines
Hi, i got a used Manhatten Catalina Spa from a friend...it was working fine for him, just not using it enough..so he gave it to me. Had it moved to my place, wired it, filled it, turned on the diconnect...
Check to see if something inside the control panel circuit board came apart or broke from being moved. These things were not designed to be moved around a bunch so you probably have a soder joint come loose or get disconnected.
Apr 19, 2017 | Balboa Instruments Duplex Digital Panel 2...
I moved the latch for my jtp15 ge oven and now it won't open. What do i do to move the latch back over?
The latches on this model oven have a very high failure rate. Once the latch fails it is permanent. To open the door you have to access the control panel to reach the door look. To do this first turn the power to the oven off at the service panel by turning the breaker off.
  • Step 1 Remove the three screws from the control panel. The control panel is on the outside of the oven, above the door handle. Pull the bottom of the control panel toward you, then lift it up. This action will release the control panel cover's tabs.
  • Step 2 The mechanism that operates the door latch during the self-cleaning cycle will be behind a smooth, square plate held in place with two screws. White, black and red wires, as well as a grounding wire, will be protruding from the face of the plate. These wires will be twisted together with other control panel wiring and covered with electrical wire caps.
  • Step 3 Remove the failed part by removing the caps and untwisting the wires. Using an appropriate wrench, extract any screws holding the plate in place. The cylindrical-shaped mechanism will be attached to and behind this plate.
  • Step 4 Visit a store or contact GE at (800) 626-2224 to acquire a replacement part. To reassemble, slide the new mechanism into where the old one was and reattach the plate with the screws. Reconnect the wires by twisting them together and replacing the electrical wire caps.
  • Step 5 Replace the control panel by slipping the top of the panel into its groove and angling the panel downward, dropping the tabs back into the slots. Replace the three screws.
  • Aug 14, 2010 | GE JTP15 Electric Single Oven
    Lexmark Impact S305 control panel problem
    We had same problem and this helped us. But you have to move your finger just to the right of the ridges and press firmly- you'll hear it click as it releases
    Mar 25, 2010 | Office Equipment & Supplies
    Any idea how to reset it or at leat open the lid?
    1. Disconnect the electrical cord from the wall.
    2. Move the washer forward about 12 inches.
    3. Lift the lid and grasp the front of the washer top with both hands.
    4. Place your knee on the front of the cabinet and pull the washer top forward and up.
    The lid lock mechanism is secured to the bottom of the washer top with two screws. Remove those screws and the wiring will be exposed. Unplug the harness from the old mechanism and connect to the new one.
    Secure the new mechanism to the washer top and let the top down.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Jun 26, 2009 | Kenmore Oasis HE 27082 Top Load Washer
    Sunroof will not close
    If you hear motor hum than it's probably a bad rail part. I have the same plastic rail part and both sides broke. Can't find a replacement anywhere.
    Mar 25, 2009 | 1990 Toyota Celica
    Sharp AR-153E Copier Logo
    Top Sharp Office Equipment & Supplies Experts
    k24674
    George Mclaughlin
    Ed
    Ed
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
