Question about Brother MFC-230c Printer
I dont know how to connect the MFC-230C printer to my Dell Computer...HELP!
  • David Miller
    David Miller May 11, 2010
    http://welcome.solutions.brother.com/bsc...
    There is the quick install guide for your Printer, you can download the PDF file and open using Adobe's Acrobat Reader.
    Hope this helped
    Scholar:
  • 73 Answers
Use the USB Cable supplied with your printer then connect it to your computer....your computer will automatically detect the new hardware then will ask if you have the install CD of your scanner, insert then install.....
Let me know if everything is going fine....
Posted on Apr 12, 2009
How to clear 'prirnt unable 51' in 230c printer?
The purge cam switch does not come ON or OFF even after the purge cam has been driven by the specified number of pulses.
Switching arm assembly not engaged correctly Ink cartridge/purge switch harness not connected correctly Purge cam switch broken Gear(s) on the maintenance unit broken Paper feed motor broken Main PCB defective.
best of luck
Jul 26, 2014 | Brother MFC-230c Printer
How to clear "unable print 51" in Brother MFC 230c printer?
SeeTroubleschooting and Routine Maintenace chapter in user's quite.see clean unable 51 to MFC-230C
Hello and Welcome to FixYa!
"Unable 51" is most likely a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
Your problem will be solved.
For any further help, you can take my valuable,professional help by taking my Service
Thank You for using FixYa
Mar 02, 2012 | Brother MFC-230c Printer
Brother MFC-230c with error message Clean unable 4F What do I need to do to correct?
4F message indicates that the printhead is RIP, you will need to replace it to make it work again. Before you replace it, you may want to try this, see if it will remove the clean unable error message: Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3. This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Feb 07, 2011 | Brother MFC-230c Printer
IT IS A BROTHER MFC235C AND THE DISPLAY KEEPS SAYING NO CARTRIDGE, INSTALL BLACK AND OTHER COLOURS LOW. THEY ARE ALL NEW BROTHER CARTRIDGES. PLEASE HELP IM READY TO THROW IT OUT THE WINDOW
you need to go into the menu and reset the error count this tells the printer the print cartridge has been changed otherwise it does not know
hope this helps
Robb
please leave feedback
Apr 26, 2010 | Brother MFC-230c Printer
Have lost disc and owners manual on MFC 230C, can I get another copy of cd and instructions?
All drivers, software & firmware are available for download at this link:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_index.html?reg=us&c=us&lang=en&prod=mfc230c_us&type2=-1&os=all&flang=all&dlid=
Manuals are available for download at the same link, but you have to click the link in the "Manuals" tab to see them.
Dec 22, 2009 | Brother MFC-230c Printer
My brother mfc-230c keeps saying "paper jam" and there is no paper jammed in the printer
this is an error that could get stuck in the memory, try removing the paper tray then unplugging and replugging the printer then when it's warmed up replace the tray.
if problem persists you may have a broken sensor
Sep 27, 2009 | Brother MFC-230c Printer
Need to re-install my printer
Follow the link below and you can download the whole CD from this site, make a copy of that using ur CD/DVD writer and reinstall the printer.
http://welcome.solutions.brother.com/bsc/public/as/as_ot/en/dlf/download_top.html?reg=as&c=as_ot&lang=en&prod=mfc230c_as
Hope this will solve the problem
Sep 20, 2009 | Brother MFC-230c Printer
Brother MFC-230c Printer Logo
258 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
