Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
LG wm1832cw Washer IE error
By ducmis on Sep 11, 2007
I keep getting IE error around the rinse part. It keeps giving me the error and I keep repeating it and it won't ever finish. I looked at the manual and it tells me that water is insufficient and check the inlet and water hose but nothing his wrong. I looked at a couple of forums and it says it may be the water fill valve but I am unsure. The water (both hot and cold) runs fine when it begins. However, I notice that the water drizzles in the main wash when the rinse start, but the water flows real well in the softener and prewash. Is this common. if it is, then why am i having this problem over and over... ???can someone please help.
Comments:
Sep 11, 2007
- Can you please tell me where is the outlet filter? Is it the filter in the front of the washer at the left bottom hand? if this is the one you are talking about then I already cleaned it. I will open rear cover and see if the thin tube is blocked or not.
Sep 12, 2007
- Oh, one more thing, the water drains fine. The error occurs when after the water drains from the first main wash, the IE normally comes on when it is refilling the tub to rinse.
Sep 13, 2007
- Thanks, i will try this on the weekend. Sounds complicated but better than giving my hard money away without giving it a chance. Again, thanks for everything.
Sep 17, 2007
- it turns out the that the water inlet supply valve was broken. The cold water is drizzling in and it should be flowing. the water inlet is broken. Just ordered the part. ..
Best Solution
posted on Sep 11, 2007
Very Helpful)
premm
Rank: Guru
Rating: 93%, 3324 votes
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit.
When u hav rinse problems, it is usually the outlet filter.
Comments:
Sep 12, 2007
- Here is what i got from the net for you:
Pull the cover off the back.
Remove the stator with the big nut in the middle. Use a screwdriver to stop the entire tub from spinning while removing the bolt.
You hv to remove a screw or two and unclip some wires.
Pull the stator out, and remove/replace the sensor.
Apparently LG is seeing a bunch of these, but the motor is solid, just a cheap sensor.
Another:
Im not sure of what sensor they're talking about but the stator is in the back of the washer. There is an access cover with 4 screws that secure it. Remove the cover and the motor is right there in back of the drum. LG uses a direct drive motor. So you will need to take the rotor off to get the the stator. First thing I would do is to make sure the connector to the stator is secure. I would disconect it and reconnect.Then try to do a load of laundry. In my experience with LG that code seems to pop up a lot. Most people unplug the washer for a few minutes and then start the load again and they have no problem. But yes the code is to do with the stator.
Complicated ducmis?, but the fault is with the great LG. All the best -premm
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Aug 07, 2009
Helpful)
cswain22
Rank: Apprentice
Rating: 88%, 2 votes
Could you have changed the supply lines??? The new braided lines for the supplies are directional. What I mean is you can only install them in one direction, with the tag to the water shut off. They have a built in back flow preventer built into the hose. If one or both are backwards the IE light will come on. Hope this helps.
Was this helpful?
Yes
No
Solution #3
posted on Jun 14, 2008
Not Rated)
breyes
Rank: Apprentice
Rating: 0%, 0 votes
I need a copy of all the codes to a LG wm1832cw front load washer. Can anybody pls send me one. Thanx sooo much!
Was this helpful?
Yes
No
Solution #4
posted on Nov 01, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same error. It was the filter and it was FILTHY!!! I removed the top panel where the water hose enters, used plyers to remove the filter, rinsed the filter and the machine is rinsing away!
Thanks so much for the money and time saving tips!!!
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
Whirlpool Cabrio WTW6300 worth the $$?
Answer
elite oasis is that a quaitly machine
Answer
motor hums drum wont turn
Answer
light on door on machine flashes and wont start the washing cycle ? :(
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Washing Machines:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
