Question about HP Pavilion dv8000z Notebook
My HP Pavilion laptop will not boot.
A message appeared on my laptop stating that it was running low on virtual memory. I went to exit out of the message and the monitor froze and the laptop rebooted itself. Instead of loading properly, a message appeared giving me this series of different loading options:
Safe Mode
Safe Mode With Networking
Safe Mode With Command Prompt
Last known Good Configuration
Start Windows Normally
Whenever selected, all of the options bring up the Windows XP Loading Screen, but the laptop reboots before it finishes loading.
Also, When the laptop first loads it briefly brings up the 'HP Invent' screen that has a few options.
to change the boot order
to enter setup
to boot from LAN
I've explored all of the options and none of the changes that I make seem to have any effect.
This happened to me once before, about a year ago. I couldn't figure out what to do so I reinstalled the operating system. It worked, at least for a while.
This time around, I have some sensitive data on my hard drive that I would like to keep so I'd like to know if there's a way I can fix my laptop without reinstalling my operating system. If I have to reinstall my operating system I'm hoping someone could tell me how to back up the contents of my hard drive first.
I appreciate any and all help that I can get with this,
Thank You
    Novelist:
    Sniper:
  • 63 Answers
Usually the message about low virtual memory is because there isn't enough RAM and it was using up all the designated space on the hard drive as Virtual memory. (Uses a part of the hard drive like RAM)
That shouldn't account for being unable to boot into any Windows options though.
The one trick with HP computers, you can try is to take the battery out, make sure the Laptop isn't plugged in with an AC adapter then press and hold the power button in for 10 seconds with no power going to the laptop. This is doing a power drain. Then put the battery back in and try to power on and boot up the computer.
When you choose safe mode, does the computer ask which operating system you want to boot into and does it give you the option to choose "Recovery Console"? Or is there an option on the screen with the safe mode options to Choose your Operating System? If not then the recovery console wasn't installed. If you can choose the recovery console, you might be able to replace the failed files that are not allowing the computer to boot into any version of Windows. Unfortunately, the computer isn't reporting which files are the problem, winlogon.exe/userinit.exe/etc.
You can get a hardrive enclosure at a computer store that allows you to put the laptop hard drive in the enclosure, then plug the enclosure into another computer with a USB cable then you can copy the sensitive data onto the other computer.
If you aren't comfortable taking the Hard Drive out yourself, you can take the laptop to a computer store, and they will take the Hard Drive and hook it up to a second computer as a Slave (Secondary Hard Drive) and copy the data over for you
Posted on Apr 13, 2009
Loaded two patches from HP. One to deal with a printer timeout issue and second to ???Screen went to geo pattern. Forced shutdown. Now tries to reboot, blue lights flash go out and flash again every 3 secs...
Remove the battery and disconnect from power source.
Disconnect any USB or external devices.
Remove the hard drive and memory. Disconnect the CMOS battery in the memory compartment.
Flip unit over and hold power button for 30 seconds.
Re-install memory and hard drive.
re-connect your CMOS battery.
Power up unit without battery installed.
Boot into safe mode.
Go to a command prompt.( start, programs . Acc. , dos prompt or command prompt.)
and type chkdsk /f
You will get a message that says can't run know but would you like to run a next bootup ? Say yes.and and type exit.
Next, reboot unit.
Hope this works for you.
Oct 05, 2009 | HP Pavilion dv9700t Notebook PC
Stop 0x00000007b appears on my hp pavilion dv2000
Try removing and reseating the memory.
Try to boot into safe mode ( F-7 ).
If you are good in safe mode, try a F-11 restoration and reload from factory.
Another idea, is to run the Hard disk utility in the BIOS setup. ( Last page )
If this message is not a memory fault error, it may be lost or missing data on the hard disk and will need to be reloaded.
Hope this helps.
Oct 03, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
I was on the internet the other night an a popup said that my memory was low so what should i do an its really slow...
If too many applications are running in the background memory is reduced. Verify that you let Windows manage the paging memory.
For WINXP
Rigt click My computer on desktop.
Click Properties
Advanced Tab Click on Performance Settings.
Under Visual effects you may ask OS to adjust for best performance Under Tab Advanced make sure that Processor scheduling and Memory usage are set for Programs.
Verify on same tab that virtual memory is about equal to physical memory (or just let windows manage it)
Hope it helps
Sep 13, 2009 | HP Pavilion MX70 17" CRT Monitor
HP pavilion dv2025nr do not boot
Hi
please press DEL to set the bios settings then choose the Bios set up! then click the bootable device SCSI.
Thanks!
Jun 07, 2009 | HP Pavilion dv2000t Notebook
Low Memory
remove all programs that start at boot up by running msconfig and clearing all checked boxes for the programs that load at boot up. Also, remove all but the system icons from the desktop by creating a folder in "My Documents" called "Desktop". Cut and the paste all but the system icons into this folder, then right click on the folder and create a shortcut to this folder on the desktop. re-boot and see how it goes.
Apr 09, 2009 | HP S3120N Pavilion Slimline Desktop...
Windows Virtual Memory Minimum is Low
fairly normal occurrence but you should have a look at your performance settings
go to control panel
double click system icon
click the advanced tab at the top
by performance click settings
in pop up window click advanced tab
at the bottom you'll see virtual memory
click change
most common option now is to set the radio button to system managed size
you should then ok each window.....
Dec 30, 2008 | HP Pavilion a620n (PC028A) PC Desktop
I have an IBM thinkpad T20 running windows 2000. The computer is on and booted up but the monitor is not lighting up. It is running on 256mb ram and I was getting a lot of virtual memory is low warnings...
To determine if the laptop has a problem with the inverter of low virtual memory issues, plug an external monitor in to the laptop and you can change the virtual memory by following these instructions, right click on my computer, select properties, then select advanced, click on virtual memory and change the settings to system detemined, save settings and reboot the laptop without the external monitor to see if it is virtual memory or inverter.
Please keep me informed
kind regards and please don't forget to rate us
Dec 03, 2008 | Computers & Internet
Virutal memory
Try this.
In Windows XP
1.Click Start, and then click Control Panel.
2.Click Performance and Maintenance, and then click System.
3.On the Advanced tab, under Performance, click Settings.
4.On the Advanced tab, under Virtual memory, click Change.
5.Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under Paging file size for selected drive, click to Custom size check box. You can enter the amount of memory you would like to reserve for Virtual memory by entering the initial and maximum size.
7.Click Set
When you are prompted to restart the computer, click Yes.
Aug 19, 2008 | HP Pavilion dv6000z Notebook
Virtual memory low
naz2172, Buying memory is always a good idea.
Buy as much as your laptop can handle, to eliminate your problem.
Feb 19, 2008 | Computers & Internet
HP Pavilion dv8000z Notebook Logo
180 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
