Question about RCA F32650 32" TV
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Posted on Sep 11, 2007
SOURCE:
Rca 32 rca 32
The repair of this problem will be near to or exceed the cost to replace it with a new flat screen. With TV prices at an all time low due to slack demand it is not cost conscious to repair it.
Jan 24, 2012 | RCA F32650 32" TV
My RCA F32650 32" TV keeps turning on and off. I
hi there! i hope this will help u find the solutiuons:
1. replace the power transistor at the horizontal section of your tv by desoldering . and buy with the same value, the store assistant in your area will do help you replacing the defective part of your tv. Thank You.
Feb 06, 2011 | RCA F32650 32" TV
I've had a rca model l32hd31yx12 and recently began to get white vertical lines after a minute they fade but certain screen changes like volume adjustments and the lines come back and fade again same thing...
Sounds like the power supply has filtering issues, in other words bad capacitors. its best to have a tv shop take a look at it. they shouldn't charge you. good luck
Nov 06, 2010 | RCA L32HD31 32 in. LCD HDTV
After a while their was a white line that appeared on the screen and now we cant watch TV. We can hear sound and everything but the only thing we can see is a bright white line
Your vertical IC may have bad grounds. Resolder the pins on the vertical IC. You will also need to replace a capacitor or two that are located next or very near the vertical IC. I would guess you are concerned about a horizontal line that runs east to west across the screen. The info just mentioned will fix your problem. Give me a few hands and thanks for asking me!
Sep 03, 2010 | RCA F32650 32" TV
I have a 1993 36 inch RCA, model # P46151WK. TV was on and suddenly heard something pop and it started to smell like something burned inside. It wont turn on anymore.
You may have a fried horizontal output transistor and a defective flyback transformer. If indeed this set is 17 years old.......cheaper to replace him...sorry!
Mar 01, 2010 | RCA F32650 32" TV
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
RCA TELEVISION
Heres the fix for your set, replace the following 2 parts:
1) flyback transformer RCA part number 257805
2) horizontal output transistor RCA part number 237470
you must be proficient at soldering & un-soldering or you can`t replace these yourself, be advised that the anode lead coming from the top of the flyback transformer can carry a VERY NASTY shock if not discharged properly before trying to remove it from the picture tube, I`d strongly advise you to call a tech unless your familiar with this type of repair, BMW Rider
Dec 09, 2007 | RCA F32650 32" TV
RCA F32650 32" TV Logo
713 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
