Question about GE Dishwashers
DISHWASHER STARTS THEN AFTER A MIN OR 2 AN ERRER COMES UP OE
  • LORRAINEBURR Apr 15, 2009
    hope this helps someone else with this problem and they have a handy son to pull off the hose for thrm lol
Pulled of the draining hose and unclogged it and it workes great
Posted on Apr 15, 2009
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
After starting the dishwasher with time 56 min, the time goes down to 55 min and after that time remains 55 min. After few min there it showed 0E in the display bar and it stopped working. Is that...
1. If the drain hose is kinked, water will not drain properly. Kinks will also catch food debris as it passes, clogging drain hose. Straighten any kinks or bends in the hose. Make certain that drain hose does not exceed 10 feet for proper drainage.
2. Check the drain air gap anytime the dishwasher is not draining properly. if the air gap is clogged the unit will not drain. The air gap is not part of the dishwasher. It is located on the sink and attached through the drain hose and garbage disposal. Not all homes are required to have an air gap installed.
3. Food residue or particles can prevent proper draining of dishwasher. Remove bottom rack and check unit for food debris or items that may have fallen into the bottom of the unit. Remove any items or food debris that may be preventing proper drainage.
4. If the unit is not leveled properly, OE Error may occur. Use a level to check sides and top of unit. if the unit is not level, adjust the leveling legs in the front and back (use leveling kit). Also check the mounting brackets. If one is tightened more than the other, it will offset the cabinet.
May 02, 2011 | LG Dishwashers
What does the error code OE mean on a LG dishwasher model number LD14At3?
OE drain Error Not fully drained out in spite of 5 min. drain operation The Drain Hose kinked or blocked. Wiring connection is OK? The drain outlet of sump is blocked. The Drain Pump/Motor or circuit is troubled...
Remove the cause of kink or block. Check the wiring connection. Measure the electric resistance of Drain Motor. (20-40 ) Replace the Drain Motor or repair the Circuit
Sep 22, 2009 | LG Dishwashers
LG dishwasher with error code OE
Drain Error OE
Remove the cause of kink or block. Check the wiring connection. Measure the electric resistance of Drain Motor. (20-40 ) Replace the Drain Motor or repair the Circuit.
Sep 20, 2009 | LG Dishwashers
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
DISPLAYING OE ERROR CODE
What did the original poster with the OE error find?
An OE error = Dishwasher not fully drained out in spite of 5 min. drainoperation
Remove the cause of kink or block in the drain hose.
Remove the filter and confirm that there is no debris in the sump area, especially the drain pump outlet.
Check the wiring connections, especially in the wiring harness in the door panel. Look for "melting" insulation.
Measure the electric resistance of Drain Motor. (good=20-40 ohms) Replace the Drain Motor if out of spec.
Good Luck!
Jan 12, 2009 | LG 24 in. LD-12BW5 Free-standing...
Lg frontload wash
I removed the top panel of washer(4 screws and slide). Then found the small 1/4" hose that goes from drum to drain hose to be pluged with goo. I cleaned inside of hose and washer worked fine.
Dec 30, 2008 | LG WM-2277HW Front Load Washer
OE fault in Dishwasher model LD-14AT2
suggest you take the drain pump motor out and inspect. either a blockage or its defective.
Jun 15, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwasher stops after rinse
Seems to be an error with the float switch on the anti flood device http://www.smeg-service.co.uk/support/index.php?a=1&cat=4
Apr 18, 2008 | Smeg 24 in. STX2 Built-in Dishwasher
Dishwashers Logo
51 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
