Question about Freezers
This model does not show up on the u-line product list present or discontinued . just obtained this and am trying to find out as much as i can about it. any info would be greatly appreciated. u-line ice make model uln-clr-60ss-40 serial no. 002545-06-0028 1/5 hp 60hz 1 phase r134a 5.25 oz 4.oa total 5.5a harvest 115v mikekwoods@yahoo.com
  • Freezers Master
  • 3,361 Answers
Can't find the manual for my Iberna Upright Showcase. Model: GD350 and No. 201205. The temperature is much higher than it is meant to be and I can't adjust it.
a UK brand
probably discontinued
cant find a user manual on line for it
my guess is you need to replace the thermostat or the control pad
contact this company
http://www.partmaster.co.uk/iberna/fridge-freezer/catalogue.pl?shop=iberna&path=499408
Apr 30, 2016 | Freezers
STAINLESS SIDE PANEL
Go to any Home Depot store and check the appliance section for technical specs on the Whirlpool models. A salesperson can easily obtain that info for you because they have that info right there.
Most stainless steel refrigerators come in 22 gauge and have various color finishes to choose from.
Yours came in several finishes (including two types of black and white finishes) but if your finish is stainless steel, then most likely you have either the Monochromatic Satina or Monochromatic Steel. You can tell by looking at the surface. The "Satina" has a more refined and smoother look to it than the other one listed.
Hope this helps!
Pen
P.S. They're no longer making that model with that finish.
Aug 14, 2014 | Whirlpool WRF989SDAM 29 cu. ft. French...
Figidaire model lffh21f7hwg lost manual don't know how to set digit inst. to set temp.
Free Frigidaire Freezer User Manuals ManualsOnline com Try this website. I know it is discontinued, but the manufacturer will be able to email you something.
Mar 16, 2014 | Freezers
Product thawed to cold in freezer...
If you had the door open for that long you will need to unplug and allow the ice buildup that happens when door is left open to thaw. After this you need only to plug the refrigerator back into the power source.Let me know what happens It is not going to work correctly until this is done. Sea Breeze
Jun 15, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
Exterior door presents condensation (a vertical line in the middle)
Normally when there is insufficient air flow in the room the freezer door will condensate and show wet spots.Have that often when testing a fridge in the workshop. Once the door is wide open, the wetness on the door goes away.
Dec 14, 2012 | Whirlpool 19.6 cu. ft. Upright Freezer...
JENN AIRE LEAKING WATER ON FLOOR. NOT SUPPLY LINE PROBLEM. HELP
Open freezer, remove lower crisper & look for solid ice on freezer floor & area at rear of freezer. If present, defrost drain is restricted. Depending on make & model remove ice, remove rear wall and clear defrost drain trough and drain path. Verify by removing kick panel, pour a cup of near boiling water through drain and watch as it drains into pan. Once clear, pour one ounce of bleach into drain tube. Also check as water is draining into pan that the pan is not leaking due to pan cracks. This solution is based on the fact that you are stating no hoses are bad.
Mar 27, 2012 | Freezers
Water pressure at dispenser too low
I am assuming with this answer that you have already checked your line tap from the water source to the fridge to make sure it is fully opened.
This is usually caused by an overloaded filter or a kinked hose.Some refrigerators use a large coil of ice maker hose placed in the Fridge box which acts similar to the older model water tank/resevoirs. The problem inherent to this cheap solution is that the hose itself has a narrow diameter hole which can freeze easily or become clogged with sediment. Check your filter first, them try removing your coiled hose if present and flush with water or air pressure.
Remember that heat rises and cold sinks, so it is quite possible that the resevoir/coiled hose has become frozen.
Mar 05, 2010 | Freezers
Ice maker has stopped making ice
Check the ice maker to see if there are ice cubes in the ice maker. If so, there is a problem with the ice maker heater and / or motor. You may be able to rebuild the ice maker by replacing defective parts, but it might be easier to replace it as a whole unit instead. If there is no ice present, it is likely a problem with the ice maker water lines / solenoid.
There are usually two solenoid valves and tubing systems for these types of fridges. One actuates on demand for water whenever requested, and the other operates automatically to make ice cubes until the ice cube reservoir is full.
Carefully push/pull the fridge away from the wall.
Unplug the fridge from the outlet.
Shut off the water supply to the fridge.
Remove access cover (usually the on the bottom) from the back of the fridge. Follow the tube that comes from the top of the fridge (for the ice maker) down to the bottom of the fridge.
Inspect visually for sources of the leak on tubing and related parts. Carefully check by hand for leaks in areas not readily visible - including the back sides of all the tubing, too. There may be sharp edges that can cut if not paying attention. If a leak is found where the tubing connects to other parts, you may be able to simply remove the tube and cut it back an inch or so if there is enough slack.
It may require that some special fittings and parts be obtained to reconnect and some compression type parts are designed for single use. If this is the case, gather the parts and bring them to a local hardware store for assistance obtaining replacements.
If a solenoid valve is found to be the culprit, due to a crack, etc. a trip to an appliance parts store will be required - unless able to purchase online. Part prices can vary widely , depending on the source.
Once replacement parts have been secured, reconnect after disconnecting power & water supply lines. When satisfied with the installation, reconnect power and water lines and test.
Carefully slide the fridge back into position - taking care to not crush the power or water lines.
Dec 31, 2009 | Freezers
Freezers Logo
128 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
