Hotpoint VBXR1060T5WB While in spin cycle, a clear hose came into the drum where clothes go. I need a diagram to show me where it hooks up
TOOK THE FRONT OF THE MACHINE OFF, FOUND OUT WHERE THE CLEAR TUBE HOOKED, PUT A CLAMP ON IT SO IT WOULDN'T COME OFF AGAIN. AND IT WORKS FINE. THANK YOU ANYWAY.
LINDA J GRIFFIN
Posted on Apr 13, 2009
LG washer WM2501HWA quit mid cycle and had an OE error message. The drain filter was checked and was clear. I drained out all the water through the drain hose. For a time, the drum would not spin. When...
i believe if the water outlet is still good,,,,,u will have to loose out the pump from its cup , mayce something hooked its propeller inside the i cup or replace the water pump
Jan 25, 2015 | LG Washing Machines
Hi, my Hotpoint Aquarius wma56 washes, but drum wont spin in rinse and wont spin...any advice?
you need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear.
Jun 10, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
My hotpoint washer has quit spinning all the water out of the clothes. Drum still spins but you can feel it hitting the sides of the machine as it goes around. What do I need to do to fix this?
THE DRUM SPINNING HAS NOTHING TO DO WITH MACHINE NOT EMPTYING..........
there is a seperate pump at the back of the machine....just follow the waste hose.........it may be blocked inside a small coin is perfect to clock it.........just clear it and see if it works..........
cheers
Mar 31, 2011 | Hotpoint Washing Machines
I have a hotpoint wm54 and it is not rinsing or spinning properly, at the end of the cycle the clothes are dripping wet & soapy, however if i manually put on to rinse and spin it seems to work!
You need to check and clean the pump filter.
Remove rear panel od washer, locate and remove large black hose on bottom of drum, remove and clean filter inside the hose.
Nov 15, 2010 | Hotpoint Aquarius WF000 Front Load Washer
The machine doesnt spin with clothes in it
Could be a blocked filter, or worn brushes in the motor.
To check filter, remove lower rear panel of washer.
Remove large black hose fastened to bottom of drum
Remove and clean filter inside trhe hose.
Remove hose onto pump, and check for obstruction or blockage here.
To check the carbons remove motor from washer, and the carbons are located at the oppsite end to the motor pulley.
Hope this helps.
Dec 16, 2009 | Hotpoint Washing Machines
Hotpoint WD63 not spinning correctly
Two things to check.
Remove rear cover.
Remove large black hose onto drum
Remove and clean filter inside hose.
Next--remove top cover and check the brushes in the motor, if they are less than 3 or 4 mm long, then replace them.
Please rate my solution.
Thanks.
Nov 24, 2009 | Hotpoint Aquarius WD63 Front Load...
THERE IS A CLEAR HOSE THAT CAME OFF AT ONE END DURING A SPIN CYCLE. I NEED A DIAGRAM SHOWING WHERE IT HOOKS.
Model number please.
The clear hose goes to the water level switch in the control console and to the air dome on the side of the wash tub.
If you run the machine without replacing it correctly you will flood your laundry room.
Apr 12, 2009 | Washing Machines
Clothes still too wet after complete cycle
I would suggest that the filter wants cleaning.
To access it, remover lower rear panel of washer.
Locate and remove the large black hose on to the tub.
Be careful, as there will be water in the hose.
Remove and clean plastic filter inside hose.
Refit hose and filter..
I would also suggest that you remove motor and check the brushes for wear, whilst you have the rear panel off.
If there is less than 10mm showing, then they need replacing..
Please leave a rating for my fixya solution.
Thanks.
Feb 07, 2009 | Hotpoint WMA54 Front Load Washer
Kenmore 44092/spin cycle
It turns out that there was a sock stuck within the pump in the washing machine. I removed the back cover and removed all the excess water, because once the sock was removed, the water was free to escape. I just removed the hose that connects to the pump and felt the sock, and was able to remove it. Once I hooked everything back up, the washing machine ran great.
Apr 17, 2008 | Kenmore Energy Star 44092 Front Load...
Load remains wet after full cycle (including spin @ 1400 rpm)
Hi Paul, Assuming it is pumping out ok, Unplug the machine tip it back at an angle, underneath you will see a black hose that is attached to the bottom of the drum, remove this, take out the ball and discard it and remove anything that may be in the filter, replace the hose and try the machine.
Nov 30, 2007 | Hotpoint WMA64 Front Load Washer
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
