Question about Tricity Bendix AW1054 Front Load Washer
Machine keeps stopping
Keeps stopping on section 4 and 6, also softner section keeps filling with water
  • 1357t Apr 03, 2008
    Machine stops at the very beginning of the spin cycle.  Water runs through soap tray, is then pumped out ok, then it spins for a split second and cuts out.  Checked filter and impellor- seem ok
  • 60 Answers
I have had this problem several times before you need to replace the spped control board let me know how you make out
Posted on Sep 12, 2007
Why does it keep stopping with lights flashing when filling bobbin?
Singer 7422 keeps stopping with lights flashing when filling ...
4 hours ago - Singer 7422 keeps stopping with lights flashing when filling bobbin Machine stops ... Machine stops and red lights flash when loading bobbink.
Dec 13, 2015 | Singer Sewing Machine 7422
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Dec 13, 2012 | Washing Machines
Daughters washing machine keeps filling with water, will not stop.
Water will not shut off
1.defective timer( timer fills washer)--replace
2. Defective water level control---replace
3. Foreign particles in mix & fill valve---clean out valve
4.defective valve----replace
Sep 23, 2011 | LG WM2016C
Softner not being flushed into machine
there is only a few reasons for the softener not to filter through firstly i would surgest removing the drawer that the softner goes in & flushing it through with hot water this will help dislodge anything that may have built up inside, sometimes the fabric softner section has a top part that comes off if so remove this & flush both sections, if you can see a black sludge then it is just build up that is blocking the path stopping the softner getting through.
Hope this helps
Apr 21, 2010 | Bosch WBB24759GB Front Load Washer
Will not stop regenerating water keeps running
Check the units drain filter. If clogged up it will make this unit run constantly
Jan 24, 2010 | Culligan Sediment Water Filter Heavy Duty
Black on door seal and water filling fabric softner section in dr
hotpoint Aquarius
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 20, 2009 | Washing Machines
Washing machine faberic softner try fills with water when in use.
hot water valve inside unit may be faulty ck it to make sure that it is powering up and then make sure it is operating. the cold and hot valve are one unit on most washers so the unit is replaced as one. if its a front loader than there might be a one way ck valve malfunctioning or the unit keeping intoducing water into the unit even though it is at the level it should be at. top loader then the level sensor is jacked and needs replaced.
Jun 12, 2009 | Frigidaire GLTF1670A Front Load Washer
Water Just Keeps Filling!
replace the water inlet valve, the valve that the black hat and cold lines connect to
Apr 19, 2008 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Water keeps going and going and going!
the water is draining back to the ocean. The drain hose was not emptied properly from its last use. Put the machine in spin cycle (about 5 minutes) only to spin out the water from the outer tub completely and retry washer. If still problem, then visual check drain hose that it still has a "rising" section higher in altitude than the water level of inner tub (when working properly) before it makes a U-turn downward to send back to the ocean. You can also test the drain hose by putting machine in fill mode and crimping off the hose (fold hose over) to simulate a good drain hose. At this test, you should not "feel" water running through the hose if successfully crimped.
Jun 21, 2007 | Estate TAWS800JQ Top Load Washer
Tricity Bendix AW1054 Front Load Washer Logo
81 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
