Question about HP ScanJet 5370C Flatbed Scanner
Windows XP not recognising HP ScanJet 5370C
I have just purchased a new computer with Windows XP. My ScanJet 5370C was working fine on the previous computer which also had Windows XP. I downloaded the driver from the HP drivers and downloads site, but the computer will not recognise the scanner. I have uninstalled and installed it several times, disconnecting the scanner, but to no avail.
  • 3 more comments
  • jmmb8 Apr 12, 2009
    The computer does not recognise the scanner.
    No, it doesn't.
  • jackEjack Apr 25, 2009
    My HP ScanJet 5370C worked fine on my desktop pc until the pc died. For my newer HP Pavillion dv5, XP OS, laptop. I successfully (I think) downloaded and installed appropriate driver from HP website. But after repeated attempts, still get error message that my laptop cannot find my scanner. --JJP
  • jmmb8 Jun 29, 2009
    No, because I contacted HP and they could not tell me when, or if, they would provide an updated driver.
  • Jose Espina May 11, 2010
    Does your new computer detect the new hardware which is your Scanner whenever you boot or connect it to your computer...?
I had the same problem. Windows will operate the scanner.
Posted on Nov 16, 2010
  • 7 Answers
If its a new computer, but with the same software, don't you think it would be the computer's problem???
Posted on Jun 29, 2009
I need a free driver for a scanjet 5370c scanner to run on Vista many thanks
hp does not have Vista drivers for your Scanjet 5370c model.
Workaround,
You can try to Vuescan program(Trial) from http://www.hamrick.com/, then install the Scanjet 5370c XP installer to your PC. Try and see whether it works!
Hope it helps.
Nov 25, 2010 | Computers & Internet
How can I get ScanJet 5370C to work on Vista Premium with my Gateway Computer.
Unfortunately HP have not created any drivers for your Scanner for Vista and I have been informed that they are not planning to either.
There is a "work around" If you download Microsoft's Virtual PC and install a copy of windows XP you would then be able to scan using the "Virtual PC" inside of your Vista operating system. Otherwise the only way out is to purchase a new scanner Sorry to be the barer of bad news
Jul 20, 2010 | HP ScanJet 5370C Flatbed Scanner
Can I get a driver to use your hp ScanJet 5370c
Yes, there is... but the catch is you have to order it from HP.
I thought it would be a free download as they providde for Windows OS, but that's not the case.
Here's a link to order it for MacOSX...
https://warp2.external.hp.com/Driver/dr_country_select.asp?Product=C8477-14328&lang=en&cc=us
Nov 08, 2009 | HP DeskJet 950c / ScanJet 5370C InkJet...
HP Scanjet 5370c problems
Scanner part of the hardware has gone defective kindly replace the scanner.
Sep 11, 2009 | HP ScanJet 5370C Flatbed Scanner
XP won't recognize HP 5370C Scanner
go to contol panel and select new hardware. then try it by reading that instruction. if its no result then u can reinstall ur Xp
Aug 03, 2009 | HP ScanJet 5370C Flatbed Scanner
HOW TO INSTALL hp scanner to VISTA
Right Click the Setup.exe file- - - ->Select Properties- - - ->Select Compatibility- - - - ->Select "Run this Programme in Compatibility For" Windows XP Service Pack2- - - - ->Also in Privilege Levels, select "Run this programme as an Administrator"- - - > Apply - - - > OK.
Now install the Scanner again with this Setup file and I'm sure you can install your Scanner in Vista and it will work for sure.
Hope this will help you.
May 02, 2009 | HP ScanJet 5370C Flatbed Scanner
How to remove & reinstall HP 5370C Scanner & 4315 All-in_One
How to uninstall the software depends on your operating system. If you have windows XP, click on the Start buton, select "Control Panel". When it opens select "Add of Remove" programs (lcick). Wait for the list of progrms to appear and then look for the HP Scanjet software. Click on it and you will be given the option to uninstall. Click to uninstall. When the uninstall has finished, restart your computer and begin the process of reinstalling the software provided by HP again. If you do not have the software, go to www.HP.com and in their "sopport" section enter Scanjet 5370 in the search list.It will give you 3 options, depending on your scnner model. You should probably select the first option 5370c. click on it and it will take you to software downloads. Select the most recent and largest file to download. This will provide the latest software for your 5370. Run the program, restart (reboot) your computer,THEN plug in your USB cord. The computer should tell you that new hardware has been found. Follwo the messages on the screen and (hopefully) your scanner sill woork. The process for Windows 98 and Vista is similr to what I have outlined for Windows XP. Good luck
Dec 03, 2008 | HP ScanJet 5370C Flatbed Scanner
HP ScanJet 5370C
Replace the R 105 with a 30E one.
I read somewhere to remove the C118, it can work without
Dec 15, 2007 | HP ScanJet 5370C Flatbed Scanner
HP ScanJet 5370C Flatbed Scanner Logo
670 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
