Question about Canon PIXMA MP830 All-In-One InkJet Printer
Change LCD screen back to English
The power went out and when I turned the printer on, The LCD display shows an unknown language. I can not find our manual. I would like to change it back to English. I have tried reseting the printer and it does not work. And I can't read the screen to even know whatever it will prompt me to do next, as I could before. Thanks,
  • 15 more comments
  • Anonymous Dec 12, 2007
    The power didn;t go out here, but all of the sudden, my printer changed to Japanese. It won't print now and has a A4 indicator lit up in the paper area. I already tyried to use the menu button and the settings button to change it back, but can not find the Japanese word there for English.
    I also tried going on my computer to see if I can change the settings back to English....help please
  • Anonymous Apr 20, 2008
    I accidentally changed the language to Japanese how can I change it back to English????
  • ThadP Apr 24, 2008
    Me too! I have the manual but can not find a laguage prefrence setting!
  • Anonymous Jul 27, 2008
    My screen is now in spanish. I have tried everything and can,t change back to english.
  • Anonymous Aug 09, 2008
    chyange from span ish to inglish
  • Anonymous Aug 18, 2008
    Want to change AOL welcome back to English, not Spanish. An AOL tech said go to AOL keyword: Change this Screen to English, but the words AOL keyword do not show on screen.
  • Anonymous Sep 10, 2008
    my welcome page keeps coming up Spanish I need English
  • incu Sep 26, 2008
    Canon PIXMA MP830 All-In-One InkJet Printer, when I turned the printer on, The LCD display shows an unknown language and the alarm led is on
  • Anonymous Sep 27, 2008
    Welcome screen is in Spanish, Change back to English language only!
  • Anonymous Oct 26, 2008
    menu display show non-english
  • Anonymous Nov 07, 2008
    when I turn on aol the welcome screen is in Spanish I want it back to english
  • Anonymous Mar 10, 2009
    i have the same problem, how can i fix it
  • Anonymous Apr 18, 2009
    How can i CHANGE MY WELCOME SCREEN BACK TO ENGLISH ?
  • Anonymous May 04, 2009
    My Aol news is in Spanish I would like to have it in English
    Need to get AOL news back in English cannot read Spanish
  • townoz May 04, 2009
    Need to change aol news to English from Spanish
  • ethelgib May 11, 2009
    WELCOME SCREEN IN SPANISH WANT BACK TO ENGLISH
Issue: How do I change the language setting of the LCD?
Solution: Change the display language settings (MP170)
LCD Appears in Japanese (or other foreign language) Upon powering on the machine for the first time, the LCD will prompt to select a display language. If a language other than English is selected, the setting can be changed by following these steps.
  1. Ensure the machine is powered on.
  2. Press the <Menu> button as many times as necessary to display [SYSTEM SETTINGS].
    1. From the Copy mode standby screen, press <Menu> 7 times.
    2. From the Scan mode standby screen, press <Menu> 1 time.
    3. From the Memory card mode standby screen, press <Menu> 6 - 12 times.
  3. Use the right arrow twice to select [OTHERS] and then press the <OK> button.
  4. Use the right arrow three times to select [LANGUAGE SETTING] and then press the <OK> button.
  5. Use the right or left arrow to select the appropriate language and then press <OK>. Choose from the following language settings.
    1. JAPANESE
    2. ENGLISH
    3. GERMAN
    4. FRENCH
    5. ITALIAN
    6. SPANISH
Posted on Sep 21, 2008
I struggled because I couldn't read the language that my printer had changed to (though I could tell it wasn't any of the ones listed above), so I couldn't see the words "System Settings". But I was able to reset it "blind" with a modification of Sheba111's Solution #2. After turning on the power, press the Copy button, then press the Menu button 7 times, then right arrow 2 times, then OK, then right arrow 3 times, then OK.
At this point, the instructions in Solution 2 are not quite enough. The languages aren't numbered and aren't readable, and the language displayed is the current one, so how do you know which one to select? You have to press the left arrow key until it no longer displays. That gets you to the beginning of the list. Then press the right arrow key, counting each press, until you have pressed it the number of times required to select your language, the press OK. For example, to get it back to English, I had to press the left arrow key several times until it stopped displaying. That got me to Japanese. I then pressed the right arrow key once to move to English (though I couldn't read what was displayed), pressed OK, and it changed immediately to English display. Also note that there are more languages (at least for my MP170) than Sheba111 lists, though the first six are those listed, in the same order.
Posted on Jun 23, 2010
Excelent solution!!! i had the same problem with japanese and my printer "speaks" english again!!! thank you very, very much
gabriel from romania
Posted on Jan 23, 2009
    New Friend:
An Unintended Language Is Displayed on the LCD
Select the language you want to be displayed according to the following procedure.
  1. Press the COPY button, wait for about 5 seconds.
  2. Press the Menu button three times.
  3. Press the button once, then press the OK button.
  4. Press the button repeatedly to select the rightmost menu.
  5. Press the button twice, then press the OK button.
  6. Use the button to select the language for the LCD, then press the OK button.
    The desired language is displayed on the LCD.
  7. Press the Stop button.
Posted on Sep 10, 2012
    Genius:
  • 2,985 Answers
If you still have the CD- the manual can be on there as a PDF file[usually more comprehensive too] Failing that an E mail to Canon support
Posted on Sep 11, 2007
SOURCE:
How to change language
Turn on the printer.
"Ready" on panel display.
Press "Menu" key.
Press the Up or Down Arrow key to show "Language."
Press the Enter key. "Language: *German" shows on the panel display.
Press the Up or Down Arrow key to get the language you want.
Press the Enter key. "Menu" shows on the panel display.
Press the On Line key. "Ready" shows on the panel display.
May 30, 2014 | Ricoh Aficio SP C410DN Laser Printer
My printer was purchased and is used in Germany. The on-screen instructions/options (eg, back to back print,etc) come up in German. Can I change that to english?.
Please follow the steps below to reset the Language on your Lexmark X3350 printer:
  1. Power off the printer.
  2. Hold down the power and + buttons simultaneously for five seconds. This will clear the language setting.
  3. The first prompt you will see is English. If this is not the language required, toggle the + and - buttons to navigate to your preferred language.
  4. Press the arrow button to select that language. The printer will save the new language setting.
Source: Wrong Language on the LCD Display of the Lexmark X3350
Sep 12, 2011 | Lexmark X3350 All-In-One InkJet Printer
The language setting has been changed to a language I don't understand. How do I change it back to english?
You may want to try the following link:
It's the manual which should show you how to maneuver through the menu screens to change the language.
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01425624/c01425624.pdf
I do hope this helps.
Best of luck!!
Mar 09, 2011 | HP Laserjet Cp2025n Printer
The display writing on the screen of the printer is in another language and i do not know how to change it to english
To change the language on this printer, do the following:
  1. Select the Copy option.
  2. Press the Option button thirteen (13) times. You should see Language on the display.
  3. Press the arrow button (-) or the (+) button to scroll through the list of languages.
  4. Press Select when the required language is displayed on the LCD screen.
Oct 04, 2009 | Lexmark X4270 All-In-One InkJet Printer
125settings for language back to English on LexmarkX
To change the language on the LCD screen of the X125 printer, please follow the steps given below:
1. With the printer power on, press the "Setup" button.
2. Then press the "Menu" button until "Set Language" shows on the screen.
3. Press the "Options" button until you see "English."
4. Press the "Start" button once and let us know the results.
Apr 11, 2009 | Lexmark X125 All-In-One InkJet Printer
How do I change the language on my printer from
Please follow the steps given below:
1. On the Operating Panel press Options (13 times) until LANGUAGE appears on the LCD screen.
2. Press the right arrow to scroll through the list of languages.
3. Press Select when the correct language is displayed on the LCD screen. This is now your default language.
4. When you power on and off your Lexmark X6100 Series, the default language is the one which remains.
The languages available and supported are the following:
English
French
German
Spanish
Italian
Dutch
Brazilian - Portuguese
Polish
Russian (PYCCKHH)
Greek (E^^HNIK^A)
Apr 05, 2009 | Lexmark X6170 All-In-One InkJet Printer
The language on my printer screen appears to be Chinese. It used to be English, but my grandson pushed buttons and I don't know how to get English back. Help-- it is a Lexmark X3470.
How to Change the Display Language on a Lexmark X3450/X3470/X3480
  1. Turn off the power by pressing the Power button once.
  2. Then press and hold both the Start button and the Power button.
  3. Once the screen displays Mfg Menu enabled, release both buttons and wait until the display shows Copies:1.
  4. Press the Mode button three times. All the indicator lights will go out and the screen will display LCD button test.
  5. Press the up arrow (pattlnk_692006_1047-up%20arrow.gif ) once. The screen will display Clean NVRAM.
  6. Press the Start button once. The printer will be reset. Afer a few seconds, the message Language: English will appear on the display.
  7. Press the up arrow (pattlnk_692006_1047-up%20arrow.gif ) until you reach your preferred language. Press the Start button once, then the Menu (pattlnk_762006_1319-menue.jpg ) button.
  8. Turn the printer off and then back on to disable the manufacturer menu (Mfg Menu). NOTE: After clearing the NVRAM, you will need to print an alignment page. The printer LCD will display this while the alignment is being performed.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 08, 2009 | Lexmark X3470 All-In-One InkJet Printer
Panel shows different language
Follow the following steps:
  1. Turn off the printer.
  2. Press and hold down the right VALUE button.
  3. While holding down the right VALUE button, press and release the POWER button.
  4. When INITIALIZING appears in the LCD, release the right VALUE button.
  5. The message VALUE AND SELECT KEYS TO CHOOSE LANGUAGE is displayed in the LCD and the currently selected language is displayed as =ENGLISH .
  6. Press the VALUE button until the desired language is displayed.
  7. Press the SELECT button and the desired language is now selected and displayed in the LCD and the printer returns to the READY state.
Feb 06, 2008 | HP Color LaserJet 2600n Printer
Changing language dell 922 printer
To change the language on the Dell 922's display, turn on the printer, then press and hold the Power and Cancel buttons at the same time for about 10 seconds. The language choices will then scroll across the LCD press the up or down arrow key till english appears, then click Menu.
Sep 15, 2007 | Dell 922 All-In-One InkJet Printer
Language
This is what Lexmark suggests: To change the language on this printer, do the following: Select the Copy option. Press the Option button thirteen (13) times. You should see Language on the display. Press the arrow button (-) or the (+) button to scroll through the list of languages. Press Select when the required language is displayed on the LCD screen. For more information, go to the following link: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&framed=&docid=ENUS16512&relevance=1
Aug 07, 2007 | Lexmark X4270 All-In-One InkJet Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
3,453 people viewed this question
Clive
Clive
old marine
old marine
Ekse
