Question about Speed Queen Washing Machines
Commercial Speed Queen Front Loading Washer
It is giving me the code "E d f"...I don't have a service manual or anything that will tell me what this code is. I have tried cleaning the filter down below and thought that took care of it, but the code came back on the display when i went to try to run it again. I have checked the breakers and the LED panel.
  • rhr_warrior Nov 23, 2009
    i have several speed queen comm. washers and all of them are starting to not work. put money in and the door does not lock to begin start up. what could it be..
  • 177 Answers
SOURCE: 2 problems with speed queen washing machine
The motor is not starting this is the humming noise not a good sound, try it in spin to see if the motor runs in this direction. You may have a motor issue because of the water leaking on the motor?
Now that you have the front panel removed you can look for leaks, you will need a flash lite, start a cycle on the small setting and look for where the water is coming from. If it is coming from the center of the tub above an aluminum case which is the transmission you need a tub seal, if the water is coming from somewhere else it could be a pump, or hose, or ?
Posted on Jul 16, 2008
  • 135 Answers
SOURCE: Filter? Is there a filter I should be cleaning out periodically?
There is no filter to clean in your machine.....any lint or other build up is designed to go out with the drain water...
Posted on Jul 30, 2008
defadad
  • 351 Answers
SOURCE: commercial speed queen won't agitate
sounds like it is in the gearbox, possible broken gear
Posted on May 27, 2009
localwonder
  • 6784 Answers
SOURCE: LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Posted on Jun 21, 2009
milten1
  • 1304 Answers
SOURCE: How do you dissasemble a speed queen commercial
in orde to open it
you will need specalty hub tools to get it out
Posted on Oct 05, 2009
Speed Queen front load commercial washer - error code ed44. What does this mean/
Overcurrent Shunt Detection,Circuit Fail Error
Hardware failure. Unpower to clear error. Replace drive board if error persists.
May 04, 2017 | Speed Queen Washing Machines
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
We have coin operated washing machines is there a sheet to show us how to change the price
http://www.pwslaundry.com/c-295851.4-commercial-speed-queen-swfx71n3000-front-load-washer-parts-for-repair-service.html
You want the one that says Programming...
Dec 31, 2012 | Speed Queen Swfx71_N3000 Commercial...
Speed Queen model no.AFN50RSP111TW01 Washer makes humming sound all the time in off position,i am being told by dealer that its the transformer which is normal,replaced transformer and still hums,unplugged...
Usually a transformer hums when it does not have the proper voltage being supplied to it. I would check this first. If the voltage is correct contact a parts supplier and request a new transformer. Speed Queen has a great parts warranty. As Speed Queen is really a commercial machine it is not unusual to have them make more noise than other manufactures.
Dec 18, 2010 | Speed Queen ATS90AWN Front Load Washer
Washer pauses at various points in all cycles
Peace friend,
ngfam1 at your service
Tell the dealer you want a different make!
IT'S EASIER TO KEEP CUSTOMERS THAN TO FINED NEW ONES!
We have been selling appliances for over 65 years!
And you will only see one GE appliance on my showroom floor!
Whirlpool or SPEED QUEEN! ARE THE BEST!
HERE IS MY STORY FOR YOU!
AFTER 6 YEARS AND THREE repairs.
I threw GE in the trash and bought a Speed Queen Commercial grade washer and, I AM 53 YEARS OLD AND THIS IS THE LAST WASHER I WILL EVER BUY!
tHEY ARE TESTED AT 8 loads a week for 25 years!!!!!!!
The washers and dryers today use so much less water,electricity,and detergent that they pay for them selves after a only a few years.
My advise is, it is cheaper to buy, run, and operate a new efficient machine! You will see you water and electric bill reduced!!!!!!!!!
Speed Queen commercial grade top loader uses only 34 gallon of water compared to the others at 48-54 gallons!
THE FRONT LOADER,
(GET THIS) ONLY 13.9 GALLONS of water and washes in 35 minutes and the clothes are cleaner and last longer cause it uses water agitation instead of a vain to wear out your clothes! How about spinning at 1000 RPM and the clothes come out so dry they are only in the dryer half the time than all the other machines! Thus half the gas or electric bill!!
All my employees have replaced their laundry pairs with Speed Queen!
My Guys call it the, "No brainier Machine!"
I hope you can utilize the good advice I so enjoy sharing with all the good people we talk to!
ngfam1
Bless You
Please give me a good rating before you sign off here at fixya.com
Aug 31, 2008 | GE WCVH6260F Front Load Washer
Washing Machines Logo
535 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
