Question about Sony Ericsson K550i Cellular Phone
My phone is not charging
My Sony Ericsson K650i, is not charging and when I connect the charger appears the red light near the on/off button
It may cause by the charger,do little shake on the plug that connect to the phone..red light appear cause by no battery at all..
Posted on Apr 13, 2009
My sony ericsson xperia mini pro wont turn on
First, check if the charging port is properly and snugly connected. Then, check your batteries. Maybe your batteries aren't charging properly. If the battery is self-replacable, try cleaning the golden battery connectors inside first. Or, your battery may need to be replaced
Feb 02, 2014 | Sony Ericsson Xperia mini pro (SK17/SK17i)...
My x8 not turn on and not charging !!!
Good morning:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 04, 2013 | Sony Ericsson XPERIA X8 Cell Phone
Why won't my sony ericsson t707 charge when the charger is plugged in???
first check whether your charger is ok, if it is working on another mobile, look for corrossion on the charging connector of your phone, if you see it corroded or clogged, power off your handset , remove battery and then clean the contacts with a pin or a small blade.
reinsert battery and try charging.
it should be working now.in a rare case if on connecting charger there is red light blinking and your set is not turning on you have a software crash and need to be updated at a service center.
regards
please comment
Jan 01, 2011 | Sony Ericsson T707 Cell Phone
Phone not turning on keep beeping red light. phone make. sony ericsson w580i
Your battery is probably out of charge.... Try charging it.... If the red light keeps on blinking even after charging it for a sufficiently long time You will either need to
1. Change your Battery.
2. Perhaps change your charger.or get your charging port checked and repaired.
Nov 04, 2010 | Sony Ericsson w580i Cellular Phone
My sony ericsson w995 won't start,ive tried charging it...but all that happens is that the red light on the back flashes...ive tried everything,please help!
Very simple.Just follow this steps:
1. Connect the charger.
2. While the charger connected, open the back cover and close the cover again. Your phone can be switched on now. This is because this phone got sensor that ensure the back cover always closed while the phone operate.
3. If the above steps not working, try remove the battery while the phone is connected with charger.
~ Please encourage me to help people like this by donating small amount to my PayPal account.Thanks dude.
My PayPal id : ruzaini88@gmail.com
Feb 19, 2010 | Sony Ericsson Walkman® W995 Cell Phone
My sony ericsson k800i wont turn on and will not charge.
Hi Fil,
This issue can be resolved only by the sony ericsson service center. As it needs to do flash on the handset. This issue can be resolved by themselves as sony ericsson only has the solution software with them.
Thanks
Aug 19, 2009 | Sony Ericsson K800i Cellular Phone
My phone will not turn on but a red light will appear in the cancel area
ur phone requires charging. either ur battery is drained or it is not charging. try connecting ur charger to ur phone and then try to start and keep it for a while and then switch it on. otherwise change ur battery.
the red light indicates no charge in battery,
Mar 26, 2009 | Sony Ericsson Walkman W810i Cellular Phone
My sony ericsson phone wont turn on
When i connect cable USB Sony Ericsson in my computer it have problem and error, can not open it.
How to format short cut key in Sony Ericsson W810i.
Jul 29, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Mobile phone
check the port of u r h/s , problem is in your mobile port, thats y u are not able to charge or syncronization
Sep 24, 2007 | Sony Ericsson K750i Cellular Phone
Sony Ericsson K550i Cellular Phone Logo
169 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
