Question about Microsoft Office 2003 Basic Edition English (s55-00066) for PC
Delayed write failed
In network shared excel file shows delayed write failed this file is read only . But this file is already shared and used multi users atatime read and write
  • shivanand Sep 20, 2007
    U have to install office xp 2003 service pack2 for this problem .
First reinstall lan card driver if it is shown same error than change the lan card . good luck
Posted on Jan 29, 2008
SOURCE:
How can i set up network file sharing
First step is to check if the file sharing option is checked in my computer folder options.
Start- My computer- TOOLS - FOLDER OPTIONS- and click on the second tab VIEW- scroll down to the last option which will show as USE SIMPLE FILE SHARING.
Level 1: My Documents (Private) loadTOCNode(3, 'moreinformation'); The owner of the file or folder has read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. All subfolders that are contained in a folder that is marked as private remain private unless you change the parent folder permissions.
If you are a Computer Administrator and create a user password for your account by using the User Accounts Control Panel tool, you are prompted to make your files and folder private.
Note The option to make a folder private (Level 1) is available only to a user account in its own My Documents folder.
To configure a folder and all the files in it to Level 1, follow these steps:
  1. Right-click the folder, and then click Sharing and Security.
  2. Select the Make this Folder Private check box, and then click OK.
Local NTFS Permissions:
  • Owner: Full Control
  • System: Full Control
Network Share Permissions:
  • Not Shared
Level 2 (Default): My Documents (Default) loadTOCNode(3, 'moreinformation'); The owner of the file or folder and local Computer Administrators have read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. This is the default setting for all the folders and files in each user's My Documents folder.
To configure a folder and all the files in it to Level 2, follow these steps:
  2. Make sure that both the Make this Folder Private and the Share this folder on the network check boxes are cleared, and then click OK.
  • Administrators: Full Control
  • Not Shared
Level 3: Files in shared documents available to local users loadTOCNode(3, 'moreinformation'); Files are shared with users who log on to the computer locally. Local Computer Administrators can read, write, and delete the files in the Shared Documents folder. Restricted Users can only read the files in the Shared Documents folder. In Windows XP Professional, Power Users may also read, write, or delete any files in the Shared Documents Folder. The Power Users group is available only in Windows XP Professional. Remote users cannot access folders or files at Level 3. To allow remote users to access files, you must share them out on the network (Level 4 or 5).
To configure a file or a folder and all the files in it to Level 3, start Microsoft Windows Explorer, and then copy or move the file or folder to the Shared Documents folder under My Computer.
  • Power Users: Change
  • Restricted Users: Read
  • Not Shared
Level 4: Shared on the Network (Read-Only) loadTOCNode(3, 'moreinformation'); Files are shared for everyone to read on the network. All local users, including the Guest account, can read the files. But they cannot modify the contents. Any user can read and change your files.
To configure a folder and all the files in it to Level 4, follow these steps:
  2. Click to select the Share this folder on the network check box
  3. Click to clear the Allow network users to change my files check box, and then click OK.
  • Everyone: Read
  • Everyone: Read
Level 5: Shared on the network (Read and Write) loadTOCNode(3, 'moreinformation'); This level is the most available and least secure access level. Any user (local or remote) can read, write, change, or delete a file in a folder shared at this access level. We recommend that this level be used only for a closed network that has a firewall configured. All local users including the Guest account can also read and modify the files.
To configure a folder and all the files in it to Level 5, follow these steps:
  2. Click to select the Share this folder on the network check box, and then click OK.
  • Everyone: Change
  • Everyone: Full Control
Note All NTFS permissions that refer to Everyone include the Guest account.
All the levels that this article describes are mutually exclusive. Private folders (Level 1) cannot be shared unless they are no longer private. Shared folders (Level 4 and 5) cannot be made private until they are unshared.
If you create a folder in the Shared Documents folder (Level 3), share it on the network, and then allow network users to change your files (Level 5), the permissions for Level 5 are effective for the folder, the files in that folder, and the subfolders. The other files and folders in the Shared Documents folder remain configured at Level 3.
Jul 20, 2010 | Microsoft Windows Vista Ultimate Edition
Tip
How to divide bandwidth in squid
What is Bandwidth throttling :
Consider we are having 512Kbps Internet connection line. And the system administrator wants to divide the whole bandwidth into two sections. Read More One for the normal users and the other for special users who need high speed internet connection. So that all the normal users can use 256 Kbps and the special users can use the remaining 256 Kbps. So in this case you have to make a bandwidth throttling to differentiate the whole single pipe line into two sections. This can be achieved using squid proxy server.
Squid main configuration file ----- /etc/squid/squid.conf
Squid log file ----- /var/log/squid/access.log
Cache log file ----- /var/log/squid/cache.log
Bandwidth throttling in squid is done using Delay Pools. Delay pools uses bucketing system.
Throttle Calculations
512Kbps(Kilo bits per second) -----> 64Kbytes -----> 64000bytes
256Kbps -----> 32Kbytes -----> 32000bytes
128Kbps -----> 16Kbytes -----> 16000bytes
64Kbps -----> 8Kbytes -----> 8000bytes
Points to remember in Delay Pools:
There are basically three things to note, they are - delay pools, delay class, delay parameters.
Delay pool --- Defines how many pools we want to use
Delay Class ---- Defines type of the pool you are going to use.
Delay Parameter � allots the restrictions and fill rate/maximum bucket size.
As I have said previously in this documentation delay pools uses bucketing system.
Now there are three types of buckets
Class 1 pool: A single aggregate bucket, shared by all users
Class 2 pool: One aggregate bucket, 256 individual buckets
Class 3 pool: One aggregate bucket, 256 network buckets, 65,536 individual buckets
If you still have any problem in the above syntax (ie) aggregate, network and individual buckets to understand, then here is a simple syntax/example for all these
For Class 1 delay pool
delay_parameters 1 32000/32000
For Class 2 delay pool
delay_parameters 1 48000/48000 48000/48000
For Class 3 delay pool
delay_parameters 2 32000/32000 8000/8000 16384/16384
Example Setup:
One 512Kbps pipe line. We want to distribute the whole pipe line into 2. One for normal users and other for special users as follows
Normal users --- 128 Kbps
Special Users --- 384 Kbps
Configuration Setup File /etc/squid/squid.conf:
Before getting into the delay pools setup first create the acl(Access Control List). Through acl you can define rules according to your requirements. Find the Access Control section in the squid.conf file.
Here is an example:
acl superusers src 192.168.1.1 192.168.1.2 192.168.1.3
acl mynetwork src 192.168.1.0/255.255.255.0
Here in the above example only three users are special users who need 256Kbps bandwidth which are listed in the specialusers label and the whole network including he special users are labeled as mynetwork.
After creating the users you have to allow them to access the internet. Below line specifies for allowing the mentioned labeled users.
http_access allow superusers
http_access allow mynetwork
Now comes the funny part Delay Pools. Here We will deal with a basic example for delay pools.
The example is as follows: We are having 512Kbps pipe line connection. We want to divide it into segments one for the special users, web servers and the other for the normal users in the organization. The special users and the web servers are given 384Kbps speed and the remaining 128Kbps for the normal users.
Delay Pools for super users:
Check for the delay pools section in the squid.conf file.
Start the configuration for delay pools as follows
########## Delay Pools############
delay_pools 2
As described above we have to create 2 delay pools, one for each delay class.
######### Defining Delay pool 1 in class 2 #########
delay_class 1 2
delay_access 1 allow superusers
The first line specifies Delay Class which defines delay pool 1 for the delay class 2.
Why we are using delay class 2 here?
The first part on the second line ie �1� defines the pool One(1)
The second part on second line defines the aggregate 48000/48000(restore/max). where restore is the number of bytes (not bits - modem and network speeds are usually quoted in bits) per second placed into the bucket, and maximum is the maximum number of bytes which can be in the bucket at any time.
The third part on second line is individual buckets again 48000/48000(restore/max). All the special users and the web servers should obtain the same speed of 384 Kbps.
The third line allows the super users to fall in that bucket.
######### Defining Delay pool 2 in class 3 #########
Delay Pools for normal users:
delay_class 2 3
delay_access 2 allow !superusers
The first line specifies Delay Class which defines delay pool 2 for the delay class 3.
The first part on the second line ie �2� defines the pool Two(2) of class three(3)
The second part on second line defines the aggregate 32000/32000(restore/max) as aggregate (ie for whole).
Note : - If you use -1/-1. �-1� indicates �unlimited�.
The third part on second line is network bucket. We have defined here 8000/8000 .
The fourth part on second line is for individual.
The third line specifies to throttle all the users except the super users.
How to check:
First set proxy settings in your browser as follows:
Go to any client machine and open an IE(Internet Explorer). Select "Tools" menu then select "Internet Options" then select "Connections" tab. After that select the "LAN Settings" button, you will get a new pop-up window there you select "Use proxy server for your LAN" check box and finally give your squid proxy servers ip address and the port on which the squid proxy server is configured. Now press "OK" and again press "OK". Cloase the window and now open a new window.
Second Check by downloading any large file
Start to download any lage file not less than 10MB size. Because when ever you download any small file it used to download it quickly. When you start downloading large file at first if you note some starting bytes of the file gets downloaded quickly and later it gets slowed down.
Keep a note on the download pop-up box which shows the speed limits in "kbps". When we start downloading note on the pop-up box the speed limits in kbps shows high value and then slowly gets decreased. This means when you start downloading the bucket gets filled and slowly it decreases and becomes stable to the specified limit in Kbps according to the configuration. Remember again as i told restore value is used to set the download speed, and the max value lets you set the size at which the files are to be slowed down from.
on Apr 24, 2010 | fedora Linux Operating System
Network Printing Issue. I'm running 2008 Domain Controller 2003 File and Print Server. Cisco 3560G switches No 3rd Party print management software User workstations are all Windows Xp Pro SP2 Printers are...
DNS errors then? can you map to the printer via hostname too? Are you sure you're not using SP3? When we upgraded to SP3, we had to use the new drivers. Try new drivers.Have you tried just rebuilding your print server? try sharing the printer off your computer in the data center and try t print to that. When you ping the data center from the user's computer... what is the delay?
Oct 13, 2009 | HP LaserJet 4250n Printer
Network access denied
Follow the steps to Sharing the files
Your computers are already connected to a network — i.e., they’re all already able to browse the Internet using the same router..
1 : Open the Network and Sharing Center window by clicking on the Windows orb in the lower left corner, and then either right-clicking on Network and selecting “Properties”, or opening the Control Panel and double-clicking “Network and Sharing Center.
2 : If your network type is “Public,” you need to change it to “Private”:
  1. To the right of the network name and location type, click Customize.
  2. In the Set Network Location dialog box, click Private, and then click Next.
  3. In the Successfully set network settings dialog box, click Close.
3 : Under “Sharing and Discovery” in the bottom half of the Network and Sharing Center window, you need to turn all the settings from “Off” to “On” by clicking on the down arrow next to each setting, clicking on “Turn on …”, and clicking on “Apply.” But see some pointers below:
  1. For the “Password protected sharing” setting: you may want to leave this “On” or turn “Off” at your discretion. (I turned mine off.)
  2. For the “Public folder sharing” setting:
    1. If you want to share the public folder so that other computers on the network can access the Public share to open files, but not create or change files, click Turn on sharing so anyone with network access can open files. This is the default setting.
    2. But if you want to share the public folder so that other computers on the network can access the Public share to open files and also create or change files, click Turn on sharing so anyone with network access can open, change, and create files.
4 : You’re done with the Network and Sharing Center window. Close it via the “X” button.
5 : Click the Windows orb at the lower left corner of your computer, and click on Computer
6 :
n the Computer window, navigate to the folder containing the file(s) or folder(s) that you want to share — e.g., “Pictures” or “Documents” or a specific file or folder within. Note: don’t open the folder itself that you want to share — just navigate to the folder that contains this folder.
7 : Right-click the folder that you want to share, and then click Share. The File Sharing window is displayed. (Click picture for a larger version.)
8 : If you have password protected sharing enabled: Use the File Sharing window to select which users can access the shared folder and their permission level. To allow all users, select Everyone in the list of users. By default, the permission level for a selected user is Reader. Users cannot change files or create new files in the share. To allow a user to change files or folders or create new files or folders, select Co-owner as the permission level.
9 : If you have password protected sharing disabled (like I do): Click the drop-down arrow inside the blank field in the File Sharing window, and select the Guest or Everyone account. Click “Add.” Then for that new account, click on the down arrow under “Permission Level” to change it to Co-owner (if you want anybody to read and modify files) or leave it at “Reader” (if you want other computers to just read but not modify your files).
10 : Click “Share”, then “Done.”
CRITICAL NOTE: If you selected “Everyone” when sharing a folder, you’re also making its contents available to any computer that joins this network. Many households, including mine, have wireless Internet via a wifi router. If you don’t have WEP encryption turned on, then I could just drive up and park on the street near your home, open my laptop, let it join your network via your wifi, and then nose around through your files. It’s particularly important that you have WEP encryption turned on for your wifi network.
Feb 18, 2009 | SAMTRON 55V 15" CRT Monitor
Microsoft Excel files: File size becomes very big while saving.
Whenever Excel closes unexpectedly, "ghost users" can remain in a "shared" workbook. Excel tracks changes in order to synchronize between users, resulting in huge file sizes. In order to fix the problem click Share Workbook (Review tab, Changes group in 2007 or Tools/Share Workbook in earlier). On the Editing tab see if there are any "Users" using the workbook. If so, remove them by clicking "Remove User." When you save again, the file should be back to normal. Being this is a Microsoft product, I want to re-emphasize the word "should" from my previous sentence...
Dec 31, 2008 | Microsoft Office Excel 2003 for PC
File sharing
it is possible
If you have multiple computers in your home and they are connected through a home network, you can share files among your computers. That means you no longer have to copy files to a floppy disk or USB flash drive to transfer them to another computer. Once you configure your computer to share files, you (or another user with the appropriate permissions) can, by using Windows Explorer, open them from other computers connected to the network, just like you’d open files that are stored on a single computer. You can also choose to have folders visible—but not modifiable—from other computers on the network.
To share files on your computer with other computers on a network, you need to:
Share a folder on your computer. This will make all of the files in the folder available to all the computers on your network (you can’t share individual files).
Set up user accounts on your computer for everyone who needs to connect to your shared folder. If any of the accounts are Limited User accounts (unless an account is a Computer Administrator account, it is a Limited User account), follow the steps in Set permissions for files and folders to enable them to open your files.
To access shared files that are on another computer on your network, you need to:
• Connect to the shared folder from other computers on the network. This procedure is described in Map a network drive.
Note: By default, file permissions only allow your user account and administrators on your local computer to open your files, regardless of whether a person is sitting at your keyboard or at another computer. It may help to keep these three things in mind when setting up file sharing:
• Files have user permission settings.
• Every computer has its own user database.
• Some accounts are administrator accounts and some aren’t.
Configure your computer to share files To share a folder on your computer so that files stored in the folder can be accessed from other computers on your home network
1.
Log on to your computer as an administrator. For more information, see Access the administrator account from the Welcome screen.
2.
Click Start, and then click My Documents.
68599-click-my-documents.gif 3.
Right-click the folder that you want to share, and then click Sharing and Security.
68599-click-sharing-and-security.gificotip.gif Tip: If you want to share your entire My Documents folder, open My Documents, and then click the Up button on the toolbar. You can then select the My Documents folder.
4.
If you see a message that reads, As a security measure, Windows has disabled remote access to this computer, click the Network Setup Wizard link. Then follow the instructions in How to set up your computer for home networking. On the File and printer sharing page of the Network Setup Wizard, be sure to select Turn on file and printer sharing. If you do not see this message, skip this step and go to step 5.
68599-click-network-setup-wizard.gif Note: If you do not see the Network Setup Wizard link or the Share this folder on the network check box, your computer probably has Simple File Sharing disabled. This is a common change made to computers used for business. In fact, it happens automatically when a computer joins an Active Directory domain. You should follow these instructions to share a folder instead.
5.
In the Properties dialog box, select the Share this folder on the network check box.
68599-click-share-this-folder.gif 6.
If you want to be able to edit your files from any computer on your network (instead of just being able to open them without saving any changes), select the Allow network users to change my files check box.
68599-click-allow-network-users-to-change-my-files.gif 7.
Click OK.
68599-click-ok.gif Windows Explorer will show a hand holding the folder icon, indicating that the folder is now shared.
To connect to the shared folder from another computer, follow the steps described in How to map a network drive.
Note: By default, only you and other people with an administrator account on the computer sharing the folder will be able to open your files. To limit access of specific users with an administrator account on the computer sharing the folder, read How to set permissions for files and folders.
Aug 14, 2008 | Microsoft Windows XP Professional
"delayed write failed" in office 2003
You will get a delayed write failed when the network is no longer connected and the user tries to save the file. are you noticing any other issues on your network?
Sep 09, 2007 | Microsoft Office 2003 Basic Edition...
Shared Microsoft Excel Wokbook problem
You copy and paste that excel file with another name in your local hard disk. Make your necessary changes and then paste it with same name on your network.
Microsoft Office 2003 Basic Edition English (s55-00066) for PC Logo
130 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
