Question about Memorex MT2271 27" TV
Memorex 20" Flat Screen TV - MT2012/24
I can't figure out how to disable the SAP
    Genius:
  • 1,139 Answers
Have you tried to press button 5 on the remote? Hear is a link to the closes model I could find http://www.memcorpinc.com/manuals/MT2025D_031207_ENG_SPA.pdf
Posted on Sep 11, 2007
SOURCE:
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
I would like to remove the voice over settings on my TV but unsure how please can you help? The make of the TV is Technika. Thank You
You probably have the second audio program (SAP) turned on. Return to the initial set up procedure and disable SAP.
Dec 26, 2014 | Televison & Video
Turn off stereo sap in tv
buy an rca universal remore for 8.00
Oct 14, 2013 | LG Televison & Video
How to I disable the SAP function on RCA FLAT 19 INCH screen?
Hello
From its main Menu, surf towards its sound Menu.
By using UP/DOWN buttons of the remote handset, select SAP
SAP (Second Audio Program) (for analog channels only) Plays the
program's audio in a second language, if one is available. The TV displays
the word SAP in the channel banner when you tune to a program that is
broadcast with SAP information. SAP audio is broadcast in mono. SAP is also
used to broadcast a program's audio with descriptions of the video for the
visually impaired. Press the right arrow button to turn SAP on or off.
OK.
Sep 22, 2011 | RCA TruFlat 27F520T 27" TV
SAP possibly enabled and need it off on channel 10 San Diego, CA Mintek TV model where do we find SAP on the remote control or TV settings?
A lot of times the remote will have it marked as MTS, this will enable or disable Mono, Stereo, and SAP.
Oct 05, 2010 | Televison & Video
I HAVE A MEMOREX TV HOW CAN IGET THE SAP OFF MY TV WITHOUT A REMOTE
Access the menu options by pressing the buttons on the TV or get you a cheap RCA or GE universal remote.  Program the thing using the access codes provided and then turn the sap off using the remote.
Oct 29, 2009 | Memorex MT201224 20" TV
TV problem
Might be as simple as you have the SAP or second audio progam turned on, go in to the sound menu of your set and see if it's set to S.A.P if so turn it to Stereo
May 15, 2008 | iLO 2600 Television
No sound on channel 7
In audio menu, find selection for SAP and change to stereo...
Let me know if more help needed, provide Model #..........T.
Dec 11, 2007 | Toshiba 20AF44 20" TV
MONO - SAP
In the audio menu, you should be able to select stereo or turn off sAP -- you may have to unplug the set for about 20 seconds and restore power to reset it, or return it if the problem doesn't go away. If you end up replacing the set, try for a JVC, Panasonic or Toshiba if you can switch. I think they will last longer for you.
Jan 09, 2007 | Akai LCT2701TD Television
19 inch portable TV Memorex
Hi! I realize that you posed a couple years ago, but I am having the same problem with my relatively new Memorex MLT 3221 model. How did you solve it??? I have tried every 'layman' solution that I can think of! Please help!
Dec 31, 2006 | Memorex MLT2022 20 in. EDTV-Ready LCD...
Memorex MT2271 27" TV Logo
407 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
