It is squeaking.
OILING
FACTORY LUBRICATED PARTS WILL PROVIDE YEARS OF HOUSEHOLD SEWING
WITHOUT ROUTINE OILING. HOWEVER, WHENEVER THE MACHINE tS BEING
SERVICED, CHECK TO SEE IF ANY PARTS NEED TO BE LUBRICATED.
OIL
APPLY GOOD QUALITY SEWING MACHINE OIL TO THE POINTS (A, B, C, D, E)
INDICATED BY BLACK ARROWS.
GREASE
WHITE GREASE IS RECOMMENDED FOR USE ON GEARS AND CAM SURFACES.
IT IS AN IMPROVED GREASE, AND IT CAN BE USED ON THE METAL AND PLASTIC
PARTS WHICH POINTS ARE INDICATED BY THE WHITE ARROWS (F,G, & H).
HOW TO ORDER
PARTS NO.
EM / 40M
DESCRIPTION
SEWING MACHINE OIL
WHITE GREASE
SOURCE: should I oil my Elna 3005 sewing machine?
Many of the new models do not require oiling.
Check the maintenace section of the manual for cleaning the shuttle area. Sometimes lint can build up and cause the machine to get noisy.
If it has been over a year since the machine was serviced, it may be time for a proffesional tune-up.
SOURCE: new sewing machine is squeaking
YOu may have bent the needle. Put in a new needle and re-thread the whole machine. See if that works.
SOURCE: My Singer overlocker is making a squeaking noise
Try contacting Singer, maybe they can email you a diagram for oiling your overlocker.
http://www.singerco.com/company/contact_us.html
