Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
BrotherMFC 3420c Setup
Hi, I am installing my machine to a new computer, and do not have the written instructions for set up. I do not know how to go through the set up so I can print. I do not use the fax at all, so no help needethere. So far, I have never used the copier or the scanner. My only use for the machine is basically for printing un til I am more experienced using a PC. I am a late learner. I would appreciate any help given. Thank you NOTE: I was not allowed to use the correct number instead of 240c it should be 3420c
  • Anonymous Apr 15, 2008
    drivers
  • liamthedance Apr 18, 2008
    I do not have the CD to re-install my MFC-240C. The printer was not working so I wat told by a friend to un-install and reinstall. He said there would be directions on the Brother web site. I can't find any.
  • 625 Answers
Insert the cd that came with the printer. if your bootup sequence is standard, the machine will start off the C drive first then go searching out the CD. choose install off the CD. once the program installs itself and you restart, go to the printer directory and find tutorials. look in here for aids to help you print.
Posted on Sep 11, 2007
SOURCE:
How do I setup my brothermfc-490c to my pc
If you go to this link you can download the manuals and all the drivers (basically a dictionary for your computer and printer to talk to each other) you need. Once you install the drivers and follow the quick setup guide pdf you should be set to use your printer with your computer.
Good Luck and vote for me if this answer helped you out. Cheers.
May 16, 2011 | Brother MFC 490cw Color Inkjet...
Need idiots guide to install canon mp210 all in one printer
Ceck below:
MP210 series Quick Start Guide mp210_qsg_en-us_v1.pdf
MP210 series Easy Setup Instructions mp210_esi_en-us_v1.pdf
MP210 series On-screen Manual for Windows mp210sosmwin110us.exe
Feb 02, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Don't know how to print
If the driver installed correctly you should just be able to open up the file you want to print. Then go to File, Print and select the Brother printer. Click print and see if it works.
Brad Nelson
Mar 15, 2008 | Brother MFC 3420C All-In-One InkJet...
Installation disc wont install on computer
insert your cd and go to windows explorer. when your machine's directory comes up, go to where the cdrom is and click on it. it should show all the programs on the cd. where it says view, click on it and choose "list" if you can view the file extensions look for a .exe extension like: install.exe or setup.exe click on this and the install or setup should start. if it won't a problem is with your computer not the install cd.
Sep 11, 2007 | Brother MFC 3420C All-In-One InkJet...
Help!
Have you installed RAM? If not the machine will not boot. You may also need to enter the BIOS setup to set the CPU and DRAM voltages and multiplyers etc. Follow the instructions in the manual for setting up the CPU info in the BIOS. Are you sure your PSU has enough guts to run the setup? Many times have i seen setups fail because a cheap power supply has been overstretched.
Jun 14, 2007 | ASUS P5B Deluxe/WiFi-AP (P5B DELUXE /WIFI...
Machine Error 41 and USB Cable
Hi, According to the User Manual any Machine Error (XX or in your case 41) refers to a mechanical problem. You have to call Brother Customer Service (USA: 1-800-284-4329; Canada: 1-877-BROTHER; Montreal: (514) 685-6464. You can also try checking out the machine, if it is new, check that all the plastic/tape retainers are removed (outside and inside); it is also possible that there is a locking lug/nut or screw somewhere (most likely underneath) that is only needed when in transit or when shipped that must be removed/opened/released when the machine is to be in operation. The USB connection is essential, it is the PC interface (and normally should be included in the box but can be bought from any computer outlet). This is how your PC communicates what it wants to be printed to your 3420C. Hope this works for you. Good luck.
Apr 22, 2007 | Brother MFC 3420C All-In-One InkJet...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
49 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
