Question about HP Photosmart 2610 All-In-One InkJet Printer
Banner printing I used to be able to print seamless banners on my hp 2610 when i was using my hp pavilion. Now I have upgraded to an hp slimline s7700n (with windows vista) and I can't manage to print without printing errors (margins at page breaks). all the settings are set to hp banner paper, etc. and i've used multiple programs to try to accomplish this (ms Pub 03 and 07, printshop). The in program print preview shows a normal banner without margins or page breaks.
  • Anonymous Mar 27, 2014
    prints banners pages and the banner is turn off in Oracle driver
  • 625 Answers
Got to be a setup problem. in your printer program there is a page for margins, page breaks. set all for zero or disable page breaks. as far as vista goes, personally I never liked it. I am running firefox and have been for the past three years. It doesn't have all the problem back doors like windows internet explorer. rarely do I ever get patches for the program - it just don't need them.AND firefox is completely compatible with 99% of all running programs.
Posted on Sep 11, 2007
SOURCE:
There are 6 print settings which do I use for best quality printing on HP Opaque Scrim paper banner style
That would be my choice and what will it do if it doesn't suit you . just waste some paper and ink
Jun 18, 2015 | HP designjet z3100ps gp large format photo...
Using hp laserjet p3005n, when I print one page it sends blank pg
Annoying but easy to solve.
Go to the printer's ip address management page from a web browser. Look under the TCP/IP address settings. Click on the advanced selection. Disable the LPD Banner page. That should fix it, if it's not under advanced poke around until you find LPD Banner Page. ;)
Oct 20, 2009 | HP LaserJet P3005n Printer
How to set the printer to print banners on continuous paper?
Depending on your printer, you may have to use a 3rd party software that tells your printer to print continuously. If your printer does not support printing full banners without a break in pages you might have to check into getting a printer specially designed for this. Many consumer printers are not meant for custom print jobs, they just use standard paper sizes. If you have your manual, I would refer to that first, but if nothing is mentioned in the manual chances are good that your printer does not support continuous printing.
Dec 31, 2008 | HP OfficeJet G55 All-In-One InkJet Printer
Banner page printing
Go to the webserver in the hp 3800 via the ip-address. There you can switch this feature on.
Jul 08, 2008 | HP Color LaserJet 3500 Printer
Banner printing on HP DeskJet 722c InkJet Printer
The problem with your printer is probably if you are using Windows XP it will not print banners from there. I downloaded drivers too and found if I went to a printer with Windows 98 and put in my software program the banner will print out. Hope this works for you. I had to find it thru trial and error.
Verron
Mar 14, 2008 | HP DeskJet 722c InkJet Printer
Printing problem
ISSUE: A blank page prints after every print job using an HP LaserJet series printer. SOLUTION: A separator page may be turned on in the printer driver, within the application, or on the network. Try printing from several applications. If a page prints out in only one application, that application may have a summary page selected to print out. If a page prints out from different applications, a separator page may be turned on in Windows or on the network. Use the following sections to turn off separator pages. Windows 95/98/Me Follow these steps to turn off the separator page in Windows 95/98/Me:
  1. Select Start .
  2. Select Settings .
  3. Select Printers .
  4. Highlight the appropriate HP LaserJet printer icon.
  5. Select File .
  6. Select Properties .
  7. In the section labeled Separator Page, select None .
  8. Click Apply .
  9. Click OK .
Windows NT 4.0/2000 Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  5. Select File .
  7. In the Advanced tab, select the Separator Page button.
  8. Delete the location for the separator page.
  9. Select OK .
Windows XP Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  3. Select Printers and Faxes .
  5. Right-click on the highlighted printer icon and select Properties from the Advanced tab.
  6. In the Advanced tab, select the Separator Page button.
  7. Delete the location for the separator page.
  8. Select OK .
Software or applications See documentation for the specific application that is printing a separator page. The following steps are an example of how to turn off the summary page in Microsoft(R) Word 97:
  1. Open Word 97 .
  2. Select File .
  3. Select Print .
  4. Select Options .
  5. Deselect Document Properties in the Include with Document section.
  6. Select OK .
Novell environments Banner pages can be sent to the printer in several different ways in a Novell environment. The following instructions detail several ways to disable the banner page. NOTE: Banner pages can also be sent from the HP Jetdirect device itself. This page can be enabled and disabled through a telnet session to the HP Jetdirect device. The telnet banner will only print in an lpd/unix ® environment. Novell's Capture Command To disable a banner page using a Novell DOS capture command at a system prompt, type the following commands: capture L=x Q=queuename NFF NB NT TI=x where:
  • L = x -- The value of x would be 1, 2 or 3 depending on the lpt port being used.
  • Q = queuename - The value of the queuename would be the Novell queue setup for this printer.
  • NFF -- No form feed.
  • NB -- No Banner.
  • NT -- No Tabs
  • TI = x -- The value of x would be the timeout amount in seconds. NOTE: If the client workstation is restarted, and if a capture command is part of a login script that is being used, these settings will be reset.
Printer Properties The banner page for Novell networks can also be enabled or disabled in the Printer Properties using the following steps:
  1. To open the Printers Folder ; click Start , Settings, and Printers .
  2. Right-click the appropriate HP LaserJet printer icon and select Properties .
  3. Select the Printer Settings , or Capture Settings tab. The banner page can be enabled or disabled here.
NetWare Clients Follow these steps to disable the banner page for Novell NetWare clients:
  1. Right-click Network Neighborhood and select Properties .
  2. Select the Configuration tab in the Network window.
  3. Highlight Novell NetWare Client and select Properties .
  4. Select the Default Capture tab. The banner can be enabled or disabled here.
Feb 23, 2008 | HP LaserJet 1010 Printer
Banner Printing
Hi Thank you so much for the best information wth banner design. i got my banner design method on here http://www.thewebpole.com/ @ from the domain name processing, with the free services of hosting, and mosr services like, * Photo Album
* Quick Blogcast
* Hosting with site builder
* Personalized Email Account
* Starter Web Page
* "For Sale" Page
* Parked Page w/ Domain
* Domain Forwarding & Masking
* 100-Pack Email Forwarding
* Total DNS Control
* Change of Registration
* Status Alerts
* Domain Locking
Jun 18, 2007 | HP Deskjet 6940dt InkJet Photo Printer
Deskjet HP 6940
this might be a software problem also. please specify which software you are using to print these banners. Thanks
Jun 12, 2007 | HP Deskjet 6940dt InkJet Photo Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
212 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
