Question about Toshiba 55H70 55" Rear Projection Television
Toshiba 55" TheaterWide TV powers on, then loses image
The TV will power on, and hold a steady image for a few minutes, then at random times a colour will fade, and at many times only small slivers of the images are available. Anybody know why this would happen and how to fix it? If a repairman is needed a quote would be nice, so im not getting ripped off.
  • 87 Answers
Normal repairs are 200-400 dollars service calls are75-150 depending on area and should go towards estimate but not refundable. It sounds like a problem that a tech should see first.
Posted on Apr 12, 2009
My toshiba theaterwide hd 51h83 no picture no sound when plug in blue screen come on then go off in 3second then red light next to power button blinking no picture
call toshiba customer care. Seems like software issue. I had the same. I was told to put 2 special files on a usb drive, connect it to tv, to reflash to tv software. it came back to life after that.. just try..
Nov 23, 2012 | Toshiba 51h83 51-inch Hdtv-ready...
Picture but no sound on a Toshiba Theaterwide HD tv
Hello Iam wondering have you tried to see under the TV setting Audio and see if the fuctions are muted
or try to unplugged the tv and wait for a few minutes plug it back in.
Also when th tv is turn back on or unplugged and plugged back in see if the power button light
flashes red
And listen to the speakers to see if there is a faint crackling
Sep 12, 2008 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Toshiba Theatrewide
If the light is on a steady red, thats an indication that the lamp is bad, or the lamp circuit is bad. If you replace the lamp, and the set still does not come on, this is going to be a tough one if you are trying to trouble shoot it without a manual. You can get a manual here http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=62HM94e Start with the power supply, and see if the regulator is working. If so move on to the lamp ballast circuit. If you need an owners manual, you can get one from here http://www.tacp.toshiba.com/tacpassets-images/models/62HM94/docs/62HM94_om_e_rev1.pdf Good Luck
Aug 12, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
I have a toshiba 52hm84 green light blinks 10 but the red lights steady i change the lamp still same.no picture
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem.....
Dec 31, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Toshiba 50HP16 Plasma tv has sound, no picture. Screen is flashing like a camera flash....on-off at random. Volume works with remote. No menu. Screen flickers/flashes. Power light in front is green. TV is...
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Oct 07, 2009 | Toshiba TheaterWide 50HP16 50 in. Plasma...
52-52 HM84 there is sound no picture there is flashing green light and steady red light. Television shuts down after a few minutes. Thanks Felipe philnedy@yahoo.com
Seems like you might have a bad CAP " capcitor in your powers supply unit. How you can tell this? Opening up the unit and do a HI POT test on your power supply unit and check for faults. You have to be qualified to check this and know what your doing otherwise you could recieve a nice jolt and pay a few hundred for a EMS to revive your heart. So leave this one to the experts if you do not know the logistics of this issue. Assuming your asking me a repair tech would consitute you do not know whats going on seek qualified help.
1. replace powersupply unit
or
2. Rebuild power supply by replacing the caps inside that have tested bad.
Good luck to you on whatever your situation may be but as always Thanks for asking me first!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 23, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
My Magnavox tb110mw9a converter loses programming randomly.
Badge #7067 is giving you a load of bunk. I have had one for 8 months and the only time I have reprogrammed it was when all TV was to go digital. Even when our power goes out the converter remains programmed.
I would keep calling back. Chances of getting the same guy is slim. Insist on a replacement.
You can also go online at http://www.funai-corp.com
Wayne
Sep 04, 2009 | RCA Analog (RCA) to Digital (VGA)...
I have red power light blinking,tv wont turn on
I'm not sure of a Toshiba TV but my Phillips and a friend of mine's Mitsubishi TV do this very same thing when the system has detected a voltage spike. Usually this is caused by static discharge (let me guess you have carpeting). Unplug the unit and hold the power button for 10 seconds and leave it unplugged for 5 minutes. Then plug her back in and give it a whirl.
Give us an update.
Mar 31, 2009 | Toshiba TheaterWide 62HM94 62" Rear...
No image
sounds like the power supply has gone down poss. one of the electrolytic capacitors. common problem if the lampunit does not work
Dec 13, 2017 | Toshiba TheaterWide 52HM94 52" Rear...
Toshiba 55H70 55" Rear Projection Television Logo
216 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
