Question about Kirby G5 Bagged Upright Vacuum
Replacement front and rear bearings on main shaft
Hi Could you please advise me as to how to replace the front and rear bearings on my Kirby G5?Thanks for you help
  • 231 Answers
Usually you replace the rear bearing and the complete front bearing cover assy. the rear bearing will have to be pressed off and the new one pressed in, let me know how deep you are into the project so i know where to start.
Posted on Jan 03, 2010
Can you oil the motor on a kirby
No, the motors if noisier than usual run a sealed ball bearing and they either need replacement or replace motor. unless you are at all mechanical the latter is probably the better option as the motor needs to be stripped down to press the bearings on and off.
Mar 16, 2014 | Kirby G5 Bagged Upright Vacuum
HOW DO YOU CHANGE THE BELT ON THE G5?
Hi There,
Here's a helpful video that we recorded showing you exactly how to replace the belt on the Kirby Generation vacuums, step by step. This video will also show you how to do the basic maintenance on the roller brush to prolong the life of the belt as long as possible.
If you need to still purchase the belt for your Kirby G5, here's a direct link to our website to the belt that your machine uses:
Kirby G4 & G5 Vacuum Cleaner Belt. Kirby Part # 301291A
Here's the video repair presentation:
Please feel free to ask any follow up questions if you need help, I'm always more then happy to answer any question you may have. If you found this helpful, please be so kind and leave feedback, and / or rate my repair helpful.
This is greatly appreciated, and keeps Fixya experts continue posting free repair advice here on Fixya.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 22, 2010 | Kirby G5 Bagged Upright Vacuum
How do you replace the belt on my Kirby G5 vacuum cleaner?
Hi There,
We've created a great video demonstration on how to replace the belt on Kirby generation vacuum cleaners. This will walk you through step by step on how you can replace the vacuum's belt, as well as do the basic maintenance on the roller brush to prolong the life of your belt.
I hope that this video helps you! If so, please be sure to rate my repair by clicking the 4 thumbs up icons in the top right hand corner of the repair.
Thanks again,
Chris Jones
GoVacuum.com
Apr 15, 2010 | Kirby G5 Bagged Upright Vacuum
How to change g5 belt
1)First, you turn the square belt lifter on the front of the power nozzle until the red arrows line up (belt off)
2)Remove the power head from the front of the machine. Now turn the belt lifter the other way and line the green arrows up again. This releases the tension on the belt
3)Turn it upside down and release the two clips that hold the metal baseplate on and remove the baseplate.
4)Grab the brushroll and pull it out of the power head. Slide the new belt onto the center of the brushroll. It will hang loose...it doesn't have to stretch around anything yet. MAKE SURE THAT THE BRUSHROLL SPINS FREELY!! If it doesn't, you'll burn all new belts quickly due to the added strain on the belt.
You can get a replacement belt here:
Kirby G5 Replacement Belt
Nov 02, 2009 | Kirby G5 Bagged Upright Vacuum
My Kirby 2HD has started making an odd roaring noise but still works fine. I have taken the front assembly off and cleaned and adjusted the roller and checked the belt. The noise seems to come from the...
It is quite possible, it just needs lubed. The motor comes in direct contact with dirt so, you have to make sure the front bearing has a drop of oil on it from time to time. If it starts to scream at you within one month, after oiling, the bearing needs to be replaced.
Oct 05, 2009 | Kirby Heritage II Vacuum
I have lost My Kirby G5 Manual
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11561&thid=539967
Posted by Marie1231 on Apr 23, 2008
I need to know how to use the attachments that came with the Kirby. I know how to use the shampoo/vacuum, but not the other attachments or the upholstery cleaner. Does anyone have any idea?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
1st, you need to un-hook the lever @ the top of the Kirby head, dial off the belt from the Kirby Vacuum Head using the Kirby emblem in the front of the vacuum, that also serves as a hook/spoon to dial the belt off the fan pulley. Once you have removed the vacuum head you now hook up the attachment hose to use the attachments by locking the attachment hose to the top lever. All regular Kirby attachment will fix on the attachment hose end including the spin brush if you have one with your Kirby --- using the Kirby Shampoo spray the soiled area and use the spin brush to agitate the carpet and or upholstery, try not to use to much water. If you have a Kirby shampooer – use the recovery tank on the exhaust port of the Kirby (this means that the cloth/paper bag needs to come off and install the clear recovery tank. Please refer to the Kirby owners manual for any type of trouble shooting that you might need – or please feel free to contact your local vacuum dealer in the yellow pages or contact your Kirby factory manufacturer listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 vacuum
Here is a link to the help you need,,,
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
The G5 manual is out of print, but the G6 and Ultimate G models are exactly the same and wil work perfectly for your questions.
Marci
Sep 17, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
384 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
