My cooling fan is not working in vaio fj66gp/w laptop. is it necessary
  • 31 Answers
Yes you should fix it asap, or your laptop will turnoff by it self if it over heat.
Posted on Apr 12, 2009
Cooling fan stopped working
any 18-20 volt laptop charger should work only need correct power plug and that can be easily changed if necessary with soldering iron and volt meter. using old charger plug as replacement. volt meter is used to check out correct polarity of plug before and after you re solder plug on.generally outside is -ve and center is +ve ,alternatively go to ebay or google and type in Sony Vaio PCG 7Q1M charger,or type in part number ,or try 18-20v laptop charger, that is what I do when I need a replacement charger,cost around $10 delivered usually.
Jan 04, 2014 | Sony Vaio PCG 7Q1M Laptop Universal AC...
Afghanistan
Professor Muhammad often be part cools the processor and take out the hot air from the laptop has been suspended by some dust and other and then back hot air into the Laptop exceeded the level of temperature and it is based laptop stop to protect the processor in this case has to be clean this part well inside a process need to be an expert and you can always use an external fan placed underneath This is temporary and must be clean and refrigerator always change the fan if necessary. You can find and external cooling unit is available in many stores and there are many shapes and types. Thanks .Muhammad mamdoh .from egypt
May 09, 2013 | Sony Vaio VPCF1390x Quad Windows 7 Home...
My VAIO laptop's fan is always working with sound since i upgraded BIOS!please give me tips to solve this problem
your fan will always work as long as laptop is on it just needs to be cleaned off from dust around the coolent fan so it can breath in back of fan the more dust builds the more louder the fan gets.and the more you laptop will shot down for no reason because its not geting enough of air to cool off motherboard.
Feb 26, 2011 | Sony VAIO VGN-BX561B PC Notebook
Vaio pcg-k33 power cuts off unexpectedly. Cooling fans are broken. Need a guide to open laptop and replace cooling fans.
This over heating issue is a common issue for this model of VAIO Computer. You will get a free service or replacement of parts(Battery) from the Sony Service Center. For more information please follow the link below.
Battery Replacement
Hope this will help you. All the best.
Sep 12, 2010 | Sony VAIO PCG-K33 Notebook
Sony Vaio K33; the fan seems to run all of the time, hot and nois
i had the same problem with my vaio.
when disassembling the notebook: after you remove the metal cover under the keyboard, you'll see three areas covered with black thermal tape. peel back the thermal tape and you should see tightly packed dust buildups in those areas. use a q-tip and vacuum if you can or air duster. be sure to clean the fans as well as the heatsink assembly.
once that is done, your noise level should be reduced by about 60-70%.
if you're still running hot, consider cleaning the old thermal grease off your processor and reapplying a new layer.
Apr 01, 2010 | Sony VAIO PCG-K33 Notebook
Vaio computer problem
You could have a faulty fan and/or dust clogging the fan and heat-sink assemble. This is the most likely cause of the laptop shutting down. When the CPU overheats it goes into thermal shutdown and if this problem is not fixed, eventually the CPU will fail.
Check the fan to see it it spins freely and check if the fan works when the laptop is powered up.
If the fan and heat-sink is ok, then to give the laptop addition cooling then purchase a laptop cooling pad and place the laptop in this pad (These pads have cooling fans and helps cool the laptop).
Jan 29, 2010 | Sony VAIO VGN-CS110E/W NoteBook
Turns off automatically
check your cooling fan sounds like its getting too hot
Oct 03, 2009 | Sony VAIO VGN-CS220J/W Notebook
My Sony Vaio seems to kick the cooling fan on quite a bit more than normal and even seems a bit noisy for a computer fan....is this the norm???
Fan on this model may start and stop spontaneously. This is normal. Although if VAIO is overheating this would be good idea to contact Vaio tech support.
Apr 17, 2009 | Sony VAIO VGN-CS110E/W NoteBook
SONY VAIO VGN-FJ66GP/W DOES NOT TURN ON
good morning:
can u tell me if you can hear the fan turning if not the powersupply may be shot also if you have a warranty i would call the manufacture of the computer and see if you can use the warranty to have it repaired
Feb 17, 2009 | Sony VAIO VGN-FJ270/B Notebook
Computers & Internet Logo
132 people viewed this question
David Payne
David Payne
