Question about Roper Dryers
Dryer stopped running,checked breaker,let cool,came on and stopped again,now does nothing.
  • Roper Master
  • 8,220 Answers
An expensive fix? Time to buy a new dryer?
Depends on what the problem is.
Is it electric or gas?
Is it getting power to the control panel? Check circuit breaker.
Does it start after cooling down? Clogged vent hose.
Is the start switch or door closed switch damaged?
Can you turn the drum by hand? If not bearings, glide pad or motor.
With the controls set to run, turn the drum while depressing the door closed button and see if starts. Start capacitor bad.
Thermal switch bad? Check with ohm meter.
Normally in the middle of a cycle I would pick Clogged vent or circuit breaker. Both cheap do it yourself repairs.
Jul 16, 2015 | Dryers
Lg dryer dle5001w keeps running
Hay Donald , sounds like the relay on your control board is stuck closed .replace control board, good luck APPLIANCES R EN
Feb 28, 2013 | LG DLE5001W Dryer
Dryer was running then stopped
Some driers turn off when overheated. Wait for your drier to cool down and try again. You may need to clear the vent tube which accumulates lint not caught by the drier's lint catch.
An old dryer may be drawing too much power and may have tripped the breaker. Go to your breaker box and look for a switch that is not facing the same way as the others. Push it back in position.
A digitally controlled dryer may freeze like a computer. Try unplugging the machine for 1 minute, plug back in and try again.
Apr 16, 2012 | Dryers
May Maytag dyer Performa Model number PYE3300AYW will not start the light in the dryer is off i turned to turn off and on the breaker but nothing happens. My question is that if the light needs to be...
no the light has nothing to do with the dryer not running, sounds like a breaker issue. You will need a multimeter and some screwdrivers. first make sure that the breaker has power, you will need to take the front panel off, then with the meter check for your 220 volts at the breaker(where the wires are hooked up), next check for voltage at the outlet, if all these have power then it is in the dryers cord, you will need to move the dryer out and remove the plate and check for voltage, if it does then you will have to trace it into the dryer. Good Luck Tim
Nov 25, 2010 | Maytag PYE2300AY Electric Dryer
My Kenmore Dryer stops before the time I set is up.
Sounds like the operating thermastat may be bad letting it get too hot and causing the motor breaker to kick out . When it cools it will start again. Check all thermastats.
Mar 12, 2010 | Kenmore Dryers
Maytag PYE2300AYW Dryer wont start or run. I replaced both thermal switches still nothing. What next?
Check the dryer breaker pair in the house electrical panel. Push off, then on. Try the dryer again. If works, ok. If not, recheck the breakers. If tripped again, the dryer has an internal short circuit--likely in the heating element(s). The drum must be removed to service the element(s).
Aug 28, 2009 | Dryers
Electric dryer runs but no heat Model # 96589210 65892
Check the dryer breaker pair in the house electrical panel--Push OFF, then ON. Try operation, if still nothing, recheck breakers. If tripped again, there is a short to ground within the dryer--usually the heating element.
Aug 01, 2009 | Kenmore Dryers
My dryer is not producing heat. Just cool air!
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 17, 2009 | Dryers
I ahve a Roper dryer that won't start. It started acting up a few
HI thanks for the question Thts a sure sign of a bad motor, stopping In the middle of a cycle. and then starting again, and now no start replace the motor
Nov 24, 2008 | Roper REX3614KW Electric Dryer
Dryer won't turn on
the heater element on the drier has gone short circuit.without a model no. its impossible to give more info.contact me on dazzie@blueyonder for more assistance.
Dec 29, 2007 | Dryers
Dryers Logo
47 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
