We have the holmes air heater (fan) the instructions on the back state to unplug for ten minutes and plug back in. it has been unplugged for hours and will not re-start. I should mention that when it stopped last night, i did not know that I was to unplug it so it was plugged all night. does this make a difference.
  • 374 Answers
fan motor are equipted by overload protection on motor winding,
this is an auto reset once heat occured on motor this will open the circuit winding and if cool it will reset.but sometimes due limited service this will open permanently and will not function anymore, the motor will not run until you replace this.its look like a resistor with ambient temperature,adn volt rating.mostly this was located on motor winding.Check also if there is an external fuse on common line.if you found check if busted replace,if this still under warranty bring this to service center and claimyour warranty to resolved this unit.have a nice day don't forget to rate me, thank's
Posted on Apr 12, 2009
E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Jun 05, 2008 | Haier hwr10xc6 Air Conditioner
Hello I have a Holmes HS700 and it has been great until now. I was trying to dry something by tilting the heater but then realized it turned off each time I tilted it. Needless to say after a few...
Ed, try turning OFF the Master ON/OFF Switch and unplugging the unit. Wait 12-15 minutes and plug it back in. Turn the Master ON/OFF Switch to ON and set your controls as you normally do. Hopefully the heater reset itself turn that 12-15 minute timeout. In the future don't tilt the heater and activate the tilt switch. Its like a Pin Ball Machine, you loose your turn if you tilt it.
Hope that helps to solve your problem.
Apr 14, 2011 | Holmes Products Heating & Cooling
Compressor won't keep running
unlikely unless you have put in too much refrigerant
indicates a faulty start/run capacitor for the compressor
Oct 25, 2017 | Amana ABB222ZDE Bottom Freezer...
Whirlpool stopped blowing cool air. Unplugged
It sounds as if your defrost timer has failed. Unplugging the unit over night allowed the unit to defrost. If unplugging it overnight or by using a stnd fan blowing into the freezer section for 90 minutes results in the fan blowing cold air then your unit is not defrosting. Most often the defrost timer is the problem. However there could be other defrost circuit like the thermostat or the defrost element. In order to provide you with the correct solution and defrost timer location you should privde your model number for further instructions.
Jan 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer not freezing and blowing luke cold air. Fan running full time.
rotate the defrost heater timer until it clicks and see if the defrost heater is working
Jun 02, 2009 | Refrigerators
I have the holmes HQH307 and it went out the caution light and the power light is on i unplugged it and hit reset a day later I turned it back on it stayed on about 3min and went back off. what should i...
Facing forward in the heating area at the top, between the elements is a round disc like object, about the diameter of a nickel. That's the thermal circuit breaker. With the power unplugged, try to clean the surface of it with some alcohol on a long cotton swap. Then use a can of compressed air and lightly blow at it with the guster. You'll need a long plastic blow tube to reach it. Make sure it is dry and that you actually forced the air into the breaker behind the disk to clean it out inside too. You can tell because as you blow around the edge it will lift the disk. You'll see.
I hope you can accomplish this and that it works for you. You could take the unit apart. But it is quite difficult to get it back together. As the grill, which you will have to remove, was not really intended for reassembly. Honestly, this is not a serviceable unit and I would not suggest taking it apart unless you have a lot of patience.
That part you are cleaning is not available, neither from the part manufacturer nor Holmes. They want to sell you a new heater. I won't buy anything else from Holmes now. Delonghi is the company I will try next for a heater. I'll see how that goes and if parts are available to service the unit in five years.
Dec 05, 2008 | Holmes Products HQH307 Compact Heater
Heater wont blow hot air anymore.
In all probability the heating element has failed and the cost to repair would be more than the cost to replace it. Inexpensive heaters do that over time.
Dec 01, 2008 | Holmes Products HFH111TU Compact Heater
"Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Aug 03, 2007 | Sharp AF-S85FX Wall/Window Air Conditioner
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
