Question about Motorola Mobility H350 Wireless Headset
Pairing hi, i have a motorola h350 bluetooth. i have lost the instrucions and do not know how to put the piece into pairing mode. i have tried holding the cal button for 6-10 seconds but, it lights up after a couple seconds then switches off despuite me still holding the button. if anyone knows where i can find an oline manual or has a solution, it would be much appreciated.
How do I snc my h350 bluetooth with Samsung blackjack?
Posted on Nov 12, 2009
Turn your Bluetooth on Go into your phone go to tools. Choose Bluetooth, then choose options go down to add new, then you will have 2 choices and choose searchand the devices will and and then the should work
Posted on Sep 26, 2007
  • countreeboy Sep 26, 2007
    But keep in mind both devices should be charged
Trying to set up my motorola h350 bluetooth to my samsung s30 phone.
Turn your H350 on by pressing and holding the black "Talk" button on the side of your headset. Hold it until the blue status starts to flash. To turn the H350 off, simply hold the talk button until the headset turns off.
Pair your headset with your cell phone by entering into your cell phone's bluetooth menu--Menu > Settings > Connection > Bluetooth Link > Setup (see Resources below).
Put your Motorola H350 into pairing mode by holding the "Talk" with the device turned off. Hold the button until the status light on the side of your headset begins to flash, and turns back into a solid blue.
Back in your phone's bluetooth menu, choose the option to "Search/Discover" bluetooth devices. And when your phone recognizes your H350, select the headset and enter "0000" as the passcode.
Thank You
Sep 05, 2010 | Motorola Mobility H350 Wireless Headset
I cant pair motorola H350 to Voyager
Can you pair the voyager with anything?
Are you putting the bluetooth headset into pair mode correctly?
Feb 06, 2009 | LG VOYAGER VX10000 Cellular Phone
Maual for Motorola H350 bluetooth headset
To pair your bluetooth with your new phone...
Step one: make sure bluetooth is fully charged. While off, press down and hold the mulitifunction key on the bluetooth until light remains on.
Step two: put your phone in discoverable mode and click on add new device to search.
The phone will then find the bluetooth.
Jan 17, 2009 | Motorola Mobility H350 Wireless Headset
I have a LG scoope that I'm trying to hook my motorola H350 up to it. I lost the instructions and I don't really know if it will go with it. I need help!!!!!!
The quick answer is that you can put it into pairing mode, and your phone should recognize it. To put into pairing mode, push and hold the large power/answer button for at least 6 seconds. The light will start flashing, indicating that it is in pairing mode. Go into the Bluetooth menu on your phone and make sure Bluetooth is turned on, that your phone is visible, and that you can search for new headset devices. Make sure the headset is still flashing. When you discover the headset in the phone, it may prompt you for the code. I believe the pairing code is "0000". Add the device to the phone. You should now be able to use it with your phone.
If this doesn't get you there, do a search for H350 Manual to get a pdf of the user manual and quickStart guide.
Jan 12, 2009 | Motorola Mobility H300 Wireless Headset
H350
for more clear instructions go here
http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step 1.
Before you can use your headset, you must
pair (link) it with your phone.
Step A - PUT HEADSET IN PAIRING MODE
Note: To turn off headset, see "Turning On and Off" on the
reverse side of this guide.
PAIR
Your Phone
Select (Menu) > Settings > Connection >
Bluetooth Link > Handsfree > Look for Devices.
The phone lists all Bluetooth devices it finds.
Select Motorola H300.
Press OK or Yes to pair (link) the handsfree
device.
Enter the passkey 0000 and press OK.
Note: Passkey cannot be changed
from 0000.
Step B - SET THE PHONE TO LOOK FOR
YOUR HEADSET
When your headset is successfully paired
Dec 11, 2008 | Motorola Mobility H300 Wireless Headset
How do I put the Blue Tooth device into pairing mode?
first switch on ur mobiles bluetooth connection......... then switch on ur moto H350..... then it automatically ask to pair with ur mobile jst accept it........ and then enter the pass code 0000.........kkkk... then it get paired... kk..........
Oct 26, 2008 | Motorola Mobility H350 Wireless Headset
How to set up bluetooth
go into bluetooth menu and get phone to search for the headset, have the headset turned on, and make sure it is in pairing mode. The instructions should tell you how to do this.
Jan 11, 2008 | Motorola Mobility H350 Wireless Headset
Pairing motorola h350 with sony ericsson w580i
All you have to do is-------- hold the call button on the bluetooth (make sure the bluetooth is off at first) hold it untill the light turns on steadily not flashing but steadily. now it is in pairing mode go to the phone turn on bluetooth, and go to handfree. now press add and it will search and hopefully pick it up.
P.S i had the same problem until i tried holding it longer :D
Dec 16, 2007 | Motorola Mobility H350 Wireless Headset
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
User Manual for the Motorola H350 Bluetooth headset!
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/H350_QSG.pdf
Jun 08, 2007 | Motorola Mobility H300 Wireless Headset
Motorola Mobility H350 Wireless Headset Logo
480 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
