Question about Crosley CDE6000 Electric Dryer
Dryer doesnt work
All my wires are hooked up on my dryer but nothing works
  • Crosley Master
  • 8,220 Answers
I am an authorized crosley repair man. The fuse mounts on the rear wall on the right hand side of the heater element. When it blows the problem is usually a ball of lint in the filter housing or a bad blower wheel.dryer doesnt work - ba7d2fe.jpgThe kit comes with 2 fuses. One for gas and one for electric dryres. Use the fuse with the same color dot as your old one. DEAD DRYER
Posted on Apr 12, 2009
Wont work
try wiring it up with both the constant power and the switch power directly to your battery. if it works, then your switch wire inside the vehicle isnt a 12v output.
if it doesnt, then something is wrong with your head unit
Apr 26, 2017 | Kenwood KDC-HD455U
My 12inch speakers work in my house but when I hook them back up to my truck they dont work . My amp used to have a red light on it but now it doesnt work i bought a new amp and speakers and still nothing...
Could be a number of things. Check all the fuses (the power wire, the amp). Make sure your ground wire hasn't worked loose. Make sure your remote wire hasn't worked loose either (sometimes vibration causes loose crimped wires to come out behind the head unit). Happy Hunting
Aug 20, 2011 | Car Audio & Video
My gas dryer doesnt want to start. I push the start button and doesnt turn on. I checked the outwlet box were it is plugged into and it works because I connected a lamp it turned on. So I took apart the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Dryers
My dual xd7500 cd player doesnt turn on anymore while hooked up only the power button light turns on nothing else works this is hooked up in my bedroom but the problem should be the same as in car can...
Is the red wire in the back hooked up to a power source? You will need that in order for it to turn on. It is the wire tells the radio to turn on when you turn your key.
Oct 18, 2009 | Dual XD-7500 CD Player
Dryer doesnt work at alll you push the start
make sure the door is shut good nd tight check the breaker for 220 volts
Jul 11, 2009 | Frigidaire FEX831CS Top Load Stacked...
Dryer will not start
if you are sure that your door switch is ok than you have a bad motor
but double check the door switch  the door switch has two wires take them off and connect them together if that makes the dryer work its a bad doorswitch if it doesnt help you have a bad motor
Jun 07, 2009 | Roper RES7648E Dryer
Cd player accepts cd's, but doesnt work.
CHECK OUT IF THE LENS IS WORKING OK.....
May 22, 2009 | iLO XM-MP3-CD Car Stereo
Moved dryer, hooked up wrong, not working now after re-hooked up
have you check outlet with a voltmeter or even checked breaker? Is your new rect' a 3 or 4 prong outlet? If you hooked up red's to black and black to reds it still should have worked. The 220 volt heating element is between the red's and blacks the 110 circuits would be between a red or black to white wire.
May 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Whirlpool Dryer
NEED A NEW TIMER NOTHING YOU CAN DO ABOUT THAT
STEVE'S APPLIANCE
516-300-3249
Apr 06, 2009 | Whirlpool LER5636P Electric Dryer
Crosley CDE6000 Electric Dryer Logo
150 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
