Question about Meade DS114-EC Telescope
Stripped threads on barrel of focuser
The barrel's thread which are plastic ride on a metal gear. Plastic threads got stipped. Where can I buy a replacement part??
    Genius:
  • 1,027 Answers
Meade sells replacement parts.
Posted on Apr 13, 2009
I NEED TO FIND OUT HOW TO THREAD A KENMORE 15819802 SEWING MACHINE
Take the machine to a Hancock, Jo Ann or similar sewing crafts store and they will be happy to show you how to thread the machine.
Dec 31, 2016 | Kenmore Sewing Machines
When should I pipe thread on copper, metal or plastic?
Seems a question with many possible answers.
1) Are you asking if you should thread the pipe?
2) What size pipe?
3) Threads on copper, not normal, not possible in most cases.
4) Thread Plastic? Only if it is Schedule 80 or above.
5) Thread metal. Assuming galvanized or black iron, this would be normal.
I need a lot more detail to intelligently answer the question.
Gary C
Oct 14, 2014 | Water Heaters
I have a Hans Grohe shower head extension #27479000 that requires a 1/2" male NPT nipple extending 5/8" from the finished wall surface. I found the female pipe thread in the 27479000 is threaded...
NPT and NPS are the same. Screw away! If your female thread is plastic and your male thread is metal, you must be careful not to overtighten as overtightening can crack the plastic on the female thread. Good luck, and don't forget your teflon tape. 4 to 5 wraps is good unless you have heavy duty gas piping teflon, then use less.
Apr 14, 2017 | Hansgrohe Plumbing
I have a tp104 p3 intermatic timer and the clock is not working it looks like the motor for the gears are working but the clock will not turn
Motor has plastic gears.
Timer wheel has metal gears.
If metal gears are not turning, and clock is turning, plastic gears are probably stripped.
And metal gears might be dirty and rusted.
Look close where plastic and metal gears meet.
2 solutions:
1) clean metal gears and replace clock motor
T-104 takes T-100 series 208-277V clock motor
Add a bit of white grease where trippers meet metal lever
Grainger sells parts.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
2) buy new T-104 and swap out insides without changing box
Nov 12, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
It will start just fine but will not move
Check the plastic gear where it meets the metal gear. These plastic gears stip real easy on these. Have had a few of the Traxxas
Apr 17, 2010 | Traxxas T Maxx 3.3 Monster Truck
Stripped connection at the cold water intake into washing machine
If your inlet valve itself is stripped then you have to replace the valve. The plastic thread is part of the inlet valve. If its only the screen in your inlet valve you can remove the screen and replace it. However if you crossthread anything plastic it HAS to be replaced.
If you give me your model number of the washer usually the wpl 4318046 can be used as an inlet valve which is a cheaper alternative than your local parts distributor would tell you. GE parts on avg are 30% more expensive than anything else. On ANY ge appliance there is usually a way around there replacements with some minor altercations. I wish this site had a way you could contact me directly. I just joined so am not an expert yet but ive done my time in the field. If i could give you any expert advise its DONT BUY GE, OR LG.
Let me know if this helps.
Jan 22, 2010 | GE Washing Machines
I can't get the head off of my ryobi weed wacker, the screw just keeps spinning, any secret to doing this?
Either the bolt has stripped out the plastic piece that holds the spool on, in which case you will need to buy a new plastic piece.
Or, the bolt is stripped where it threads into the metal insert.
Pull outward and unscrew counter clockwise.
Jim
Jun 14, 2009 | Craftsman Gas Mini - Tiller/Edger
My drain hole is stripped on my hayward pool pump. the threads are completely gone as i was trying to put a metal fitting in the hole for the use of an ozone generator. can i re thread the hole? it is a...
There are a couple of ways to do this repair, First way is to buy a reducer bushing (threads on the inside and smooth surface on the outside), drill out the hole to tightly fit the bushing, and prime and glue it in place. The second way is to buy a tap (the next size up), buy a brass reduser bushing with threads on both the inside and outside. If you dont have enough material to inxdease thr hole size, then you will need to buy some J.B. weld and fill the hole, wait 16 to 25 hours to drill and tap
Jun 14, 2009 | Hayward SAND FILTER, PRO SERIES
Want to know how to remove the bottom wash arm.
Insert a flat blade screwdriver and pop it out. Vitally
May 13, 2009 | Dishwashers
Speedometer malfunction
Possibly stripped the plastic gear at the transmission case where the speedometer cable enters. You can unscrew the cable from the transmission case and the gear should be sitting right there. Pop it out and see if the gear threads are stripped.
May 02, 2009 | Dodge Ram Pickup 3500 Cars & Trucks
Optics Logo
239 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
