Question about Ricoh Aficio 2016 All-In-One Laser Printer
When i copy a print i saw code like 302
I face problem when i am print any document . How solve my problem
  • 37 Answers
Sc 302 = Charge roller current leak
1 .check charge roller
2.pull pcu out and see that it slots in correctly
3.check for any lose or bend silver plates when pcu is pulled out
Posted on Jan 07, 2008
My Dell AIO 926 printer remains in copy mode. How do I change it to print?
If you printer not show normal mode then go to run and type printer spool. If not solved then go to control panel and Administrative Tools and click services option and search print spooler stop and start. I hope solved you problem. If not solved then one time printer off and some time wait and restart.
If more problem face then contact good printer support technician.
TechSupportPrinter
Thanks.
Jan 14, 2014 | Dell 924 All-in-One InkJet Printer
Can print from computer but page comes out blank when trying to copy a document placed on the glass
In order to copy a document correctly, the document must be facing down onto the glass (text or images facing down), and oriented so that the (typically) top-right corner matches with the triangle next to the glass. Close the lid, then press 'Resume' or one of the buttons labeled 'Start Copy'. This should allow the printer to correctly copy the document.
Thank you for using FixYa! If you require additional assistance, feel free to reply to this solution, and I'll be glad to help you further.
Mar 28, 2011 | HP PSC 2210 All-In-One InkJet Printer
How do u load paper? front or back side up?
Hi, It dosen`t matter how you load paper, Copy paper are blank on both side, now if you are reusing paper with prints on one side then you do it by trial and error.
Now if you meant how to load document on top, then that`s a different story, most fax machines require that you put the document face down. I would suggest that you make a copy from a document face down and if it comes out ok, fine, if the copy comes out blank then you need to put the document face up instead.
Hope this helps.
Mar 13, 2010 | HP 1040 Plain Paper Inkjet Fax
I AM USING KYOCERA 8030 IT NETWORK CONNECTED EVERY TIME I PRINT IT PRINTS TWO BLANK COPIES WHY?
are you facing same problem with other document like notepad ...... please check it please ..... open a notepad type some thing like test print and give print and check its comes blank pages or not .... if its not coming please check the document setting how many pages your document heaving you can give number pages you want to print ....... if you facing same problem with notepad please post you comment ........... and try to uninstall the printer driver and reinstall it ..............
Dec 29, 2009 | Kyocera Office Equipment & Supplies
My printer says copy but not print how can i solve this when i copy nothin is on the sheet it prints how can i print my document
Place any document on the scanner glass of the printer and press copy.The printer will copy your document.If we want to print any document from computer,the Kodak home center should be installed on your computer.If you have not has the software,download it from www.kodak.com/go/aiodownloads. Your issue will be solved.
Dec 03, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer goes through motions to copy doument but pages are blank
From Kodak's website: Question : Why are prints from my all-in-one printer blank? Answer : There may be multiple reasons why your prints are blank. To resolve this problem, we have an easy Step-by-Step Solutions and Repair tool.
Within the tool, select Print quality, then Blank prints.
Start @ this link:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=10355
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Need manual for Delta 10'' compound power miter saw MS 250
If you can't print from your computer, or local library, find a local print shop or copy shop that is willing to download and print a .pdf file for you.
Then go to this link and you'll be able to download a pdf file with the manual you're seeking: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A05737.pdf
If this solves your problem, please take a second to rate this post and let us know! Best wishes!
Mar 18, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Printer problem
try to un-install the printer and re-install it again and see if this will work with you
Feb 09, 2009 | Canon Office Equipment & Supplies
Missing the manual - how to collate??
By using the Duplex button on your machine, you can set the machine to
print copies on both sides of paper.
1 Press Duplex.
2 Load originals face up in the ADF.
3 Press the Scroll buttons until the binding option you want appears.
Off: Prints in Normal mode.
1->2Side Short: Prints pages to be read by flipping like a note
pad.
1->2Side Long: Prints pages to be read like a book.
2->1Side: Scans both sides of the original and prints each of them
on separate two papers. (SCX-6322DN only)
2->2Side: Scans both sides of the original and prints them on both
sides of a paper, this function produce exactly the same print out
from the original. (SCX-6322DN only)
2->1Side Rotate2: Scans both sides of the original and prints one
of them on separate two papers, but the information on back side
of the original is printed 180° rotated. (SCX-6322DN only)
4 Press OK to save your selection.
If the mode is enabled, the Duplex button is backlit.
Collation
You can set the machine to sort the copy job. For
example, if you make 2 copies of a 3 page original,
one complete 3 page document will print followed by a
second complete document.
1 Press Copy.
2 Load originals face up into the ADF.
For details about loading an original, see
page 5.1.
3 Enter the number of copies using the number
keypad.
4 Press Menu until Copy Feature appears on the
bottom line of the display and press OK.
5 Press OK when Copy Collation appears.
6 Press the Scroll buttons to select Yes.
7 Press OK or Start to begin copying.
One complete document will print
http://www.websitetoolbox.com/mb/copierquestions
Jan 23, 2009 | Samsung SCX-6322DN All-In-One Laser...
Printing problems Kyocera KM 2050
try setting the driver to KPDL mode in the settings section of the driver
May 07, 2008 | Office Equipment & Supplies
Ricoh Aficio 2016 All-In-One Laser Printer Logo
434 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Inky Fingers
Inky Fingers
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
