Question about Brother XR-65t Mechanical Sewing Machine
My needle broke and a piece of metal fell out of machine
I was sewing and my needle broke. The metal that holds the needle in place fell off and another long piece of metal fell out. The long piece is part way straight, and then curves around perpendicular to the strait part doing a 3/4 turn. I am not exactly sure how to put it back together.
  • 4 more comments
  • taytin May 09, 2008
    Nothing else fell off just the piece that holds the needle and it wont stay on.
  • Anonymous May 27, 2008
    the part that holds the needle and the little straight pice of wire fell off my brother sewing machine how do i get this back on my machine
  • Anonymous May 28, 2008
    I have the same problem how do i get it back on
  • Anonymous May 29, 2008
    can this promblem be fixed
  • Rosie-Mom Jul 14, 2008
    I was sewing and I hit a pin. The metal that holds the needle in place fell off and the thread glide fell off. The needle clamp won't stay on nor will it hold the needle in place. I have looked on line and found a replacement part, hate to pay $30.00 when I am not exactly sure how to put it back together. Can I get directions?
  • rachelzart Dec 03, 2008
    I, too, hit a pin and the piece of metal holding the needle fell off the metal rod piece above. After some close inspection, I am pretty sure that there is some sort of tiny allen wrench or screwdriver that fits in the liitle hole on the same side of the metal as the needle screw handle.(right side) This little tiny screw tightens and untightens the pressure against the metal rod, so I think if I can find the correct allen wrench to untighten it, I will be able to slide it back on and then retighten the screw once it is in place. The little curved metal piece that looks like a spring is the needle guide and goes into the bottom of the metal piece and up through the hole on top. Whether or not you have a clear passageway is also dependant on the tiny screw location.
Totally happened to me last week. I discovered that the metal piece that fell off and holds the needle has a small screw that holds it in place. It needs an Allen wrench (tiny one) to tighten it back into place. I just lucked into figuring it out.
Posted on Feb 17, 2009
How does this part go back on
Posted on May 29, 2008
3 Suggested Answers
SOURCE:
mohammed387
  • 1952 Answers
SOURCE: My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Posted on Aug 31, 2008
I used a 5/64" allen wrench to replace the needle bar. A simple fix which cost me a kiss (to my husband) instead of 109.95 to the service tech.
Posted on Sep 09, 2011
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
Metal boot shape piece goes inside needle bar then needle they keep falling out. Metal fell out trying to change
Would you please say what model you have? I gather that there's now a problem with your needle clamp, and it won't hold needles? Those clamps can be replaced inexpensively--you just slide the old one off and the new one on--but I could be more specific about where you can buy a replacement if you supplied the model number.
Jul 02, 2015 | Singer Sewing Machines
MY BOBBIN CASE FELL OUT TWO PIECES HOW DO I PUT IT BACK TOGETHER
I assume you actually mean the metal ring that holds the small round case that the bobbin itself sits in. There are usually two arms that swing in to hold that larger metal ring in place and then there is a plastic and metal piece that sit behind the large metal ring. fit the plastic piece that may look somewhat like a scoop next to the metal piece that usually has the post the the bobbin fits onto and has a quite sharp tooth on it. The metal ring then goes on to hold those two pieces in place and the two arms swing in to hold the metal ring into place. The bobbin or bobbin case now can be put back in. Hint on metal ring placement: they almost always have a notch that goes at the very top where the arm on the bobbin case sits in when it is in place. You may find it easiest to do this with the machine laying on its back so you don't have to have 4 hands to hold everything in place while putting everything back in.
Feb 22, 2011 | New Home HF-2022
The thing you put the needle in and their is a wire thing that goes in there...that piece fell out and needle won't stay in...it's a brother XR-35
What fell out was the needle clamp gib - a small wedge-like part that presses on the needle to hold in place.
You may be able to get it repaired or replaced.
Search online for parts, or ask a sewing machine service tech for an estimate for having the machine repaired.
Mar 19, 2010 | Sewing Machines
I have a Bernette 50 sewing machine....i was sewing velcro....the screw assembly on the post where the needle goes into fell off and the thread guide fell off it....i can't tell if it is broken or just...
That can be tricky. Some thread guides and needle clamps have to be assembled and then slid up into place with the needle screw holding it together. Some have a set screw to hold it.
Jun 27, 2009 | Bernina Bernette 75
this sounds like the needle guard it is usually held on by the same screw that holds the needle clamp it should fit so that it comes across the needle at the front to stop your fingers being sown but not interfere with the needle try turning by hand before turning back on.
Jun 05, 2009 | Brother XR-65t Mechanical Sewing Machine
Brother XR-65t Mechanical Sewing Machine Logo
494 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
