Question about Home
Need owners manuel for whirlpool accubake stove RF378LXKT
Ould like to get users manuel for whirlpool accubake system model RF378LXKT. I purchased stove used and would like o know how to care for stove.
jyackle5
  • 8197 Answers
SOURCE: care manuel for whirlpool electric self cleaning range
Go here and find your range. once you find click on it. go to literature to get your manual.
http://www.whirlpool.com/catalog/category.jsp?categoryId=76
Good Luck and Please Rate
Posted on Jan 11, 2009
  • 31 Answers
SOURCE: stove top works, display unit and oven does not
I would have to say that u need to remove the back painl and look for a ground wirer that is broken or burnt in half. make sur that u unplug the oven first.when u find the problem just replace the wirers
Posted on Feb 08, 2009
SOURCE: Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
I just had my ignitor replaced. The ignitor glowed but it must pull a certain amount of amps before it will allow the gas valve to open. Once the ignitor starts glowing the gas should come on within 30 seconds. Now that I saw it done I realize it was something I could have done myself. Be sure the tech does not try to slip you a used ignitor as mine tried.
Posted on Jun 10, 2009
  • 30 Answers
SOURCE: oven temperature
From the manual: Touch and hold CUSTOM BROIL for 5 seconds. A tone will sound, and “C” will appear on the display. Repeat to change back to Fahrenheit.
Posted on Sep 18, 2009
fixyourboard
  • 310 Answers
SOURCE: whirlpool accubake system model#RBD275PDS15 has
This could be either a problem with the keypad or the control. Here's the manufacturer's "recommended repair procedure":
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control.
... not so good, they want you to replace the keypad and if that doesn't work replace the control board ... both very expensive!
First I suggest trying to clean up the keypad ribbon connection into the control board ... this is free! We put a procedure on our website that describes how to do it, heres the link:
http://www.fixyourboard.com/techzone/ovens/keypad_tail_clean/keypad_tail_clean.html
If you come to the conclusion that the failure is due to the control board, we can have a look at it for you if your comfortable to remove it. We repair oven controllers.
Or, if you want to send us the keypad and control board as a unit (they are bolted together) we can determine which is the problem and repair as needed.
Best Regards,
Bruce
Posted on Oct 03, 2009
Whirlpool accubake gas stove. Burners work,oven does not, and display is out. Stove is 11 years old.
Grant Schertzer, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Grant Schertzer ), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool Kitchen Ranges
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
My stove made this zapping noise, sparks came out the bottom and then tripped the breaker.
You need to have the stove looked at by a qualified appliance tech. The fact that the stove sparked and tripped the breaker indicates a short some where in the stove and it is very unsafe to use it. Leave the breaker off until you have the stove serviced.
May 23, 2014 | Whirlpool Gold GW397LXU 30" Slide-in Gas...
Whirlpool gold accubake system in loc mode cant get it off the ..
daddysgirl,  You do not indicate the model number or the age of the stove.  Early model self clean stoves used a 'oven lock door handle.'  Later model stoves do not use such a handle but is electronic. I believe this is the one that you own.  You also don't indicate it the door is indeed "LOCKED" or does the console just says that it is locked. If you press START... does the oven actually come on and heat to desired temperature?  If not... I believe that you have a touchpad control problem.  You can unplug your stove from the wall or turn off the stove's 220VAC 50 amp circuit breaker located in your main electrical panel. If possible leave off over nite and then reapply power the next morning.  If you still have the same oven contol problems, then you will have to replace your oven Electronic Control Module (ECM).  It sounds like the "touchpad" portion is defected but unfortunately it usually comes as a part of the ECM.  The oven ECM is very expensive ($150-275. retail) plus labor to install.  Hopes this helps you!  HandyHenry
Jan 31, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Oven not working on wirlpool accubake system
I have a Whirlpool Accubake System stove / oven. About 50 p% of the time I go to push the "Bake" and "Start" button, it goes to "Cal" or "EO -F2-" what ever that is. It won't let me clear it . Needless to say I am not happy with the fact that when I go to bake something, the oven doesn't work!!! Please help!
Oct 15, 2008 | Whirlpool Kitchen Ranges
Whirlpool gold accubake system stove/oven
Can you unplug the plug for a while? Are you the new owner ?
Do you have home owner insurance?
Jun 24, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Home Logo
245 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
