Question about NetGear FSM7326P Networking Switch
Netgear fsm7326p L3
Bridging to segments 10.175.8.x and 10.175.16.x. When on a client on the either segment getting intermittent time outs when pinging, but no latency, reply at 1ms. When pinging resources on same segment no issues. Config has been in place for over a year, just started a few days ago. Any ideas?
    Scholar:
  • 47 Answers
Any new additions to the router table? Since the two segments are probably outside of your subnet mask, each connection has to check the router table to figure out how to get there... so maybe the router table is getting super long, and it's timing out before it hits the right line. Could also be Is there a process that's occuring simultaneously that could be be taking a lot of bandwidth, such as online backups, etc.
Posted on Sep 11, 2007
SOURCE:
NetGear FSM7326P reset to factory default
Netgear FSM (and GSM) switches have an RS232 serial console port. Connect to that using Hyperterm, PuTTY, Xterm etc. at 9600-8-N-1, and power up the switch. Early in the boot process, it will give you a choice of normal operation, or the boot menu. Select the boot menu before the time runs out (usually a couple seconds), and one of the options will be to reset the switch configuration, including the password.
As far as I know, there is no way to recover the password and leave the configuration intact.
Mar 01, 2012 | NetGear FSM7326P Networking Switch
How do I set my Hager timer EH711 to on at 7pm and off at 7am
Resourceful do-it-yourselfer will find following information helpful for solving problem.
Max Load 1000Watts incandescent
http://waterheatertimer.org/How-to-program-Hagar-timer.html#700-series
Manual uses several languages including English
http://waterheatertimer.org/pdf/Hager-EH711-Timer.pdf
Hagar 700 series analog timer has mechanical dial that rotates as time passes.
Segments located on outer edge of dial are moved down-and-out, or up-and-inward to set on-off times.
As dial rotates, segments move lever that turns Load on-off.
With segment timers, all consecutive segments between on and off times have to be pushed in place.
Since EH700 series timer has NO NC terminals, segment position is determined by how timer was wired.
This is because segments-in and segments-out turn different terminals ON.
As a result, the best way to set this timer is to push 10 consecutive segments down-and-out.
Leave rest of segments up-and-inward.
Then manually rotate timer dial to watch when Load turns on-off.
Hagar analog timers also have a switch located in bottom right.
This is the manual override switch.
Set switch in position "I" and then rotate timer dial to watch when Load turns of-off.
Set switch in position "O" and then rotate timer dial again to watch when Load turns of-off.
Manually rotating dial and experimenting with segments and switch will tell resourceful do-it-yourselfer exactly how to set timer.
Once segments and switch are set, then rotate timer hands until current time shows on analog dial face.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 17, 2011 | Hardware & Accessories
I have a westell adsl2t router and it is connected to my DI-624m wireless router and I just want to encrypt the connection to secure it.
open a browser from a computer that is connected to the router (preferably wired) and in the address bar, enter http://192.168.0.1
the login is admin and the password is blank.
click WIRELESS on the left
you will then be on the wireless setup screen.
Enable the type of security you want, and the key or passphrase.
For instance, if you want something easy to remember, set the security to WEP and use your 10 digit phone number as the WEP key.
Change the SSID to something other than dlink while you're there.
That's all there is to it. Apply the changes and you're done!
Feb 27, 2011 | D-Link DI-624M Router (DI624MRE)
Hpm 24 hr manual timer , i dont know how to get it working
HPM 24 hour timer has segments located around dial.
http://waterheatertimer.org/Woods-timers-and-manuals.html#HPM-dial
http://waterheatertimer.org/images/hpm-24hr-timer-500.jpg
Segments appear to move up or down.
Other similar timers: Segments down = Load ON; Segments up = Load OFF
Press several segments down.
Plug timer into wall.
Plug 240Volt load into timer.
Manually rotate timer dial clockwise to see if segments down turn load on or off.
There is also a 2-position slide-switch located on top of timer.
Move slide switch to each position to see which is need for timer to turn load on-off.
After positions are defined, push segments down or leave segments up for times you want load to turn on.
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Timer dial rotates as time passes, and segments move a plastic lever that turns load on and off
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 20, 2011 | Hardware & Accessories
When I connect my router to my modem, I cannot surf the net, nor can I access my router homepage. I have my modem in bridge mode, but I appear to have no connection.
I would set it up in 'router' mode. Bridge mode is for a specific application for an intranet (not internet).
Bridge Mode Router Mode Does not block any broadcast or multicast Blocks and provide protection against broadcast storms Transparent bridge and can pass Non-IP protocols Only IP protocol is supported PPPOE protocol Pass-through No PPPOE protocol pass-through Able to transport VLAN tagging Doesn't supports VLAN No network segmentation. One broadcast domain Network segmentation (Clients can be on different IP subnet) Can only relay the DHCP client's request to the external DHCP server Can Act as DHCP server & relay which Prevents IP conflict & DHCP Injection Bridges maintains bridging table (Mac) & STP can be used to avoid loops No STP feature; maintains routing table External bandwidth Controller can be used to control the speed of the clients by Mac or IP address External bandwidth Controller can be used to control the speed of the clients by IP only In client device, it uses MAC address to associate which requires WDS compatible AP Use SSID to associate, work with any 802.11a/b/g AP
Dec 30, 2010 | Linksys BEFSX41 Router (DHBEFSX41)
How can I tell if I have pressed "down" to turn lamp on? I don't see a difference.
Are you talking about raising and lowering the segments?
See images of timer segments and pins.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
If your timer style is not show, add a comment.
You posted under Woods 59200 timer.
There are segments located around edge of dial.
Each segment represents 1 hour
Timer arrives with segments pushed down.
To set timer, raise the segments up for all times you want timer OFF
Leave segments down for times you want the timer ON.
Dec 14, 2010 | Woods 59200 Lamp and Appliance Timer with...
I cannot figure out how to set my outdoor timer to control my Christmas lights. How do I set the pins?
There are 4 basic pins/tabs/segments for timers
Pins move back and forth
Segments lift up
Segments pull out
Segments push down
Each type of pins/segments are located on dial.
Dial rotates as time passes.
The pins/segments contact on-off lever and cause lever to move.
Lever movement opens and closes electrical contacts.
The little plastic parts and motors wear out.
Make sure pins/segments are pushed all the way into place.
Check override switch is clicked to TIMER
Rotate dial until current time lines up with arrowhead marker
To check operation of timer, manually rotate dial to watch lights turn on-off.
Troubleshoot:
Lights must be on.
Bulbs are good.
Receptacle has power.
Check timer in different receptacle.
If dial does not rotate or pins/segments don't turn lights on-off, timer might be bad.
Dec 12, 2010 | Garden
How do you set the timer
You posted under mechanical outdoor timer with time dial located on face.
If you have different timer, add a comment.
Instructions:
There are segments or pins located around outer edge of dial.
If timer has segments.
Pull these segments outward, or leave them in place to set on-off times.
Pull out a few segments and then rotate dial clockwise to see if lights turn on or off with segments out.
Then pull out segments for the times you want timer to turn on-off.
If timer has pins.
Click pins outward, or leave them in place to set on-off times.
Click out a few pins and then rotate dial clockwise to see if lights turn on or off with pins out.
Then pull out pins for the times you want timer to turn on-off.
Some timers also have an override button located on inner dial or somewhere on body of timer.
Move this switch to TIMER or AUTO, depending on your timer
Dec 05, 2010 | Stanley 38445 TimeIt 24Hour Daily Outdoor...
Cannot set it.
773ea72.jpgImage shows Deihl timer >> notice that segments located at top of timer are moved inward. This is how you set on-off times. Segments pushed in cause timer to turn ON. Segments out, then timer is OFF. Each segment represents 15 minutes, so for 2 hours, you move 8 consecutive segments. To set current time, rotate dial until current time lines up with arrow..
If timer is not rotating, then it is not wired correctly, or it does not have power, or timer has gone bad.
Drawing of SPST timer wiring for 120Volt, 240Volt or 24Volt circuit.
Up-vote if this answer helped. Thanks for the feedback.
Oct 14, 2010 | Diehl TIME CLOCK- 120V 24 HOUR
The instructions indicate to push the outer segments down with pen, etc to set timer. I can't get the segment to go down.
Generally the segments are already pushed down when you buy timer.
Instruction usually say, pull up all the segments, and after pulling up all the segments, then push down the segments for the hours you want the timer turned OFF or ON depending on timer
51ec3fc.jpgSegments on GE 15207 timer
Oct 12, 2010 | Hardware & Accessories
NetGear FSM7326P Networking Switch Logo
308 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
