Question about Olevia LT42HVi 42 in. LCD Television
After about 45 minutes flickering horizontal
After about 45 minutes flickering horizontal white lines appear on screen. Switching off for a few minutes the picture is normal again for a short time, then problem re-occurs. Sound is OK. Any ideas please?
  • j_clark798 Apr 12, 2009
    The problem is with a TV not a computer ?
  • 4,234 Answers
It would seem that the video processing section is sensitive to heat. You do not indicate how old the set is, so if under a year, it should still be under warranty and you should request warranty service. Provide as many details about when the problem occurs so that it can be reproduced.
If the unit is out of warranty, check to be sure that any fans on the top or botton are free from dust and are turning. Also, you can open up the back and carefully reseat all of the cables and connectors. A bad connection at one of those could show up like this too. If all of that fails to resolve the problem, then the unit will need to be seen by a servicer. There are no user servicable parts inside other than the actual boards and those are not cheap. It is possible that a servicer may spot something that we can not see, being remote and all..
Good luck and keep us posted.
Dan
Posted on Apr 13, 2009
  • 191 Answers
Please reinstall the video drivers, provide me your computer details i'll find updated drivers
Posted on Apr 12, 2009
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
My moniter screen go's dark with a bright horizontal white line in center ..it flickers
the driver board is bad in the monitor. Has it been in a place that is super hot like in a car? If the verticle driver chip disconnects from the matrix driver array, it will all squish into a single line in the middle of the screen like you are describing.. might try opening and blowing where the driver board connects to the LCD matrix (bunch of connectors on a plastic flat cable/bus connecting to the end of the LCD panel.. heating them could allow them to reconnect.. Its worth a try, right? It has worked for me about 60% time.
Feb 03, 2014 | Envision Computers & Internet
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
White horizontal lines flicker and screen goes off.
check the wiring inside the monitor, pull the sceen out and move the wires with the screen on so you can see when it's working. then tape the wires where it works.
Dec 16, 2009 | Proview PL926WBi 19" LCD Monitor
Horinzontal white line with sound
vertical collapse. usually not to expensive to fix.
Jun 02, 2009 | Toshiba 32A33 32" TV
White horizontal dashed lines appear and at top of tv screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 13, 2017 | Apex Digital GB43HD09 43" Rear Projection...
Intense white & coloured horizontal line on black background on startup
I wouldn't attempt as the capacitors on a tv store around 25000 volts this is more than enough to kill you and they keep there charge even when the tv is off. Either take it to a repair shop or put that money towards buying a new tv - Do not even attempt to open the tv. (It sounds like maybe a tube has gone or the electromagnet that makes the beam move vertically is gone.
Sep 03, 2008 | Televison & Video
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Horizontal lines
sometimes I encounter vertical lines below..... when i tap the sides it clears for a time being  but after a few moment again appears
Dec 06, 2007 | AOC 19LVWK LCD Monitor
Flicker-Blinking on picture
Too late now but I hope you had it serviced while it was still on parts warranty. With a couple of exceptions, service on those is by major pcb replacement.
Jun 04, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Olevia LT42HVi 42 in. LCD Television Logo
305 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
